Haptic feedback keyboard for iPhone arrived with iOS 16. It vibrates when you press a keyboard key. But in case your haptic feedback is not working, we’ve concluded several effective fixes for this you.
Apple recently added the capability to enable haptic feedback in iOS 16. Haptic feedback is actually the short vibrations that you feel while typing. But, sometimes, it doesn’t work the way it should.
Don’t worry, in this article, we have mentioned 8 ways to resolve this issue. With these solutions, you can fix the Haptic Keyboard Feedback not working on iOS 16. And you can get back to your wonderful typing experience with the help of these methods. More than that, we also offer more than just a way to fix haptic keyboard not working, like black screen, stuck on update.
But before going towards the solutions, have you enabled the feature from the settings? If you haven’t, then here’re the steps.
The default keyboard on iPhone now includes a new haptic feedback option with the iOS 16 update. When activated, pressing each key causes a tiny vibration while typing, providing haptic evidence that the word was tapped.
Only iOS 16 users will see the Keyboard feedback option. Therefore, you must install the iOS 16 update.
On an iPhone, the haptic feedback for the Apple keyboard is disabled. Therefore, to use it, you must first enable it; otherwise, keyboard haptics won’t work.
Following these instructions will enable haptic keyboard feedback on iPhone with iOS 16:
Step 1. Open your iPhone’s Settings.
Step 2. After selecting Sounds & Haptics, select Keyboard Feedback.
How to Activate Keyboard Haptics on iPhone
Step 3. Turn on the option beside the Haptic. All done. You may now open Apple Keyboard in any application and type while experiencing little vibrations.
If your haptic keyboard is still not working, We’ve listed seven methods for your assistance.
If you’ve been looking for this function for a while but are frustrated that the iPhone keyboard doesn’t vibrate while you type, you’ve come to the right spot. Let’s look at fixes for the iOS 16 iPhone haptic keyboard not working.
There are indeed 8 methods described in this article, but of these, we recommend that you try PhoneRescue for iOS first, which offers you a 98% chance of getting your device back to normal while providing you with 2 fixes. This cannot be achieved by the following methods.
PhoneRescue for iOS is designed to get iPhone/iPad users out of software problems and data loss dilemmas. So, it allows you to repair iOS and fix various iPhone problems, including the iPhone haptic keyboard not working, stuck on factory reset, iPhone unable to activate, attempting data recovery cannot be completed, etc. Supports all iOS versions and iPhone/iPad models.
Here are the steps to fix haptic keyboard not working:
Get the latest version of PhoneRescue for iOS on your Mac or Windows PC. Go to Device Rescuer and tap Repair iOS System. And, make sure your iPhone is connected to the computer.
Choose Repair iOS System
Please choose a repair mode. The Advanced Mode will restore iPhone to normal and won’t erase existing data.
Select the Advanced Mode
Follow the on-screen instructions to enter recovery mode. And, click the Download button below to get a matching firmware for your iPhone.
Download Matching Firmware
Once the firmware is downloaded, PhoneRescue will start repairing. Wait for completed, and your iPhone will be restarted normally. Also, you can try the Standard Mode to repair.
Most likely, you haven’t yet upgraded to the latest software if you can’t find this feature on your iPhone. Follow these steps to upgrade your iPhone:
Step 1. Open your iPhone’s Settings and go to General.
Step 3. Choose Software Update from the options.
Check Software Update
Step 4. Click Download and install if iOS 16 is available for you.
If the method detailed above does not help you, you can return to the settings and quickly turn off the keyboard’s haptic feedback before turning it back on.
Follow above-mentioned steps in “How do I activate keyboard Haptics?” to Turn Haptic Feedback Off and On.
Here are the steps: Access Settings > Choose Sound & Feedback > Select the Keyboard Feedback option > Switch off the haptics feature > After a brief delay, turn the toggle back on.
Restart the device if your iPhone’s haptics still doesn’t work after trying the fixes mentioned above. That will repair any transitory bugs or problems that may be affecting haptics.
Hold and press the Power button until the Power slider appears to restart your iPhone. To switch off your iPhone, move the slider to the right. When your iPhone is off, Hold the Power button down until the Apple logo appears, then let go.
All system vibrations can be enabled or disabled in the accessibility settings. The keyboard’s haptic feedback won’t function if this setting is disabled. Therefore, you must initially check to see if your device’s vibration feature is disabled, and if it is, you must turn it on.
Step 1. Click the Settings application.
Step 2. Go down the page and click Accessibility.
Step 3. Select Touch under Accessibility from the menu.
Click Touch Button under Accessibility
Step 4. Turn on the vibration toggle here.
Depending on your requirements, you can upgrade the keyboard on your iPhone. For instance, numbers-row keyboards are available. But if you want to use your iPhone’s haptic feedback feature to its most potential, we suggest switching to the standard iOS keyboard. Here’s how to manage your iPhone’s keyboards and select the default.
Here’s how to use the Apple Keyboard and delete any other keyboards on your phone.
Step 1. On your iPhone, start by opening the Settings app.
Step 2. Click to General and choose the Keyboard option from the menu.
Keyboard option under General Settings
Step 4. Click on Keyboards at the top. All the keyboards installed on your iPhone will be listed for you to see.
Step 5. Tap Edit in the top-right corner to delete a keyboard.
Step 6. Tap the red minus icon you want to remove on the left side of the keyboard. This step can remove the standard iOS keyboard in a foreign language.
Remove Keyboard in iPhone
Step 7. Press the Delete button next to the keyboard’s name.
Step 8. After removing the keyboard, tap Done in the top-right corner.
Here’s how to return to the default keyboard if you don’t want to delete any keyboards.
Step 1. Open any app, such as Messages or Notes, to bring up the keyboard.
Step 2. At the bottom-left of the keyboard, long-press the globe icon.
Keyboard in Messages
Step 3. Choose the default iOS keyboard from the list of available keyboards.
If all methods fail and your iPhone’s haptic keyboard is still not functioning, you can try changing it back to the factory defaults. While your device’s location, permission, notifications, and other settings will be reset, none of your data will be lost.
Step 1. Tap on General after opening Settings.
Step 2. On the bottom, select Reset Phone.
Step 3. Next, select Reset All Settings by tapping the Reset button.
Reset All Settings on iPhone
If clearing all settings doesn’t resolve the iOS 16 haptic keyboard bug, the next step has reset and should be taken.
A hard reset, also known as a force restart, is the best method for resolving many bugs. So be sure to attempt this tried-and-true solution.
Follow these steps to hard reset your iPhone.
Step 1. Press the volume up button and let go of it quickly. After then, press and then let go of the volume down button.
Step 2. The next step is to keep your finger pressed on the side button until the Apple logo appears on the screen.
How to Hard Reset an iPhone
All done! We hope you were able to get your device’s haptic keyboard fixed. Which of the strategies mentioned above have you found to be the most effective? If you have used the reset function to repair your device but have erased your data, you can still download PhoneRescue for iOS to help you recover data from your device and iTunes and iCloud.
