Are you also struggling with the constant crashing of TikTok? Then you’ve come to the right place. In this article, we not only let you know does TikTok keep crashing, but also provide 7 solutions to TikTok keeps crashing for iPhone and Android users.
TikTok is one of the most used applications right now. With the advent of technology, entertainment has evolved the most. Besides watching many video recordings, you can likewise make your own on TikTok to showcase your talent. You can also cash your account if you get a certain amount of followers. You can select the genre and see all the related media available with simple swipes.
So with TikTok being so popular, what are the problems that users don’t want to encounter? One of these problems is that TikTok keeps crashing problem. In this situation, whether for both regular users and a blogger, this can make a big difference in the perception of using TikTok.
So to learn why this problem happens and how to fix it, let’s move to the next section.
Just like other applications, you might encounter problems when using TikTok. You might face audio and video quality problems, uploading problems, etc. Among them, we will discuss the TikTok crashing issue.
TikTok users can experience unexpected application crashes. Users can fix themselves most of the time, while others are caused by the actual server, which users can not fix.
There might be multiple reasons behind TikTok crashing. Let’s see what they are,
Sometimes, TikTok can crash due to server problems that force individuals to close the application. The crashing of TikTok will result in losing unsaved work. You might lose the video you were making or editing. The users cannot fix this. The company has been working to make its servers foolproof.
Unstable internet access would result in the loss of connection with the server. You will need a stable internet connection. Any unsaved video editing will be lost.
You must download the latest version of TikTok to avoid circumstances where it might crash, and you lose unsaved video making/editing.
Sometimes, the TikTok app might crash because of too many cached files. We will discuss how to resolve it in the next section.
Most of the time, your phone storage is compromised. Less phone storage makes it problematic for applications to work effectively.
Phones with less than 3 GB RAM have encountered TikTok app crashing.
You can resolve the TikTok application crashing with some solutions. Non-technical and easy to do. Let’s see what they are and how you can perform them.
Restarting the TikTok application can resolve to crash. To do so, follow the steps given below.
If you are using an iOS device:
If you are using an android device:
To clear cache files of TikTok on Android and iOS devices, then follow these steps,
To delete TikTok app
To reinstall the TikTok app
To delete the TikTok app
To reinstall the TikTok application
Alt text: Steps to reinstall the TikTok app on an Android.
When you use the above methods, you will find that often the problem of TikTok crashes is not completely solved. It may appear to fix it briefly, but the problem will recur later on in your usage. This is certainly very annoying and frustrating. In order to solve the problem once and for all, you will need to seek the help of a professional fix tool.
PhoneRescue for iOS is designed to get iPhone/iPad users out of software problems and data loss dilemmas. So, it allows you to repair iOS and fix various iPhone problems, including the tiktok crashing issue, stuck on factory reset, iPhone black screen, attempting data recovery cannot be completed, etc. Supports all iOS versions and iPhone/iPad models. Follow below steps to fix the TikTok crash on iPhone/iPad devices
Get the latest version of PhoneRescue for iOS on your Mac or Windows PC. Go to Device Rescuer and tap Repair iOS System. And, make sure your iPhone is connected to the computer.
Please choose a repair mode. The Advanced Mode will restore iPhone to normal and won’t erase existing data.
Follow the on-screen instructions to enter recovery mode. And, click the Download button below to get a matching firmware for your iPhone.
Once the firmware is downloaded, PhoneRescue will start repairing. Wait for complete, you can use TikTok normally. Also, you can try the Standard Mode to repair.
As one of the most comprehensive Android data management/recovery/system repair/unlocking software on the market, solving the TikTok crash problem is a piece of cake for DroidKit.
It also easily helps your phone to get rid of the black screen, constant reboot and other problems. The best part of DroidKit is that you don’t need to root the device before getting the issues fixed. That means you won’t lose the data while fixing the devices.
Let’s take a look at the steps to use DroidKit to fix the TikTok crashing issue.
Step 1. Download and install DroidKit on the computer you are using. Connect your device to the computer as well.
Step 2. Launch DroidKit. You will find there are a lot of functions on the screen. Just choose System Fix function.
Step 3. Tap the Start button to go on issue fixing. You will see so far the function to fix system issues can only apply to Samsung devices.
Step 4. Follow the on-screen instructions, you will be asked to download the firmware. Once the firmware was downloaded, you need to put your device in download mode. Seconds later, DroidKit will start to fix the issue your device met.
Step 5. Minutes later, you will find your device gets restarted again which means the fixing process is completed.
Millions of people make and edit videos on TikTok. You can showcase your talent, your products, and your services. You can resolve the TikTok crashing problem yourself. From the above article, we reached at a conclusion that for repairing TikTok crashing on Android and iPhone, nothing can beat PhoneRescue for iOS and DroidKit at the first place. Whether you are having problems with app crashes, black screens or constant phone reboots, we can bring your device back to normal quickly and easily.
