How to Fix iPhone Volume Low Easily
This article will show common causes of low iPhone volume and also provide 12 troubleshooting methods. There’s also a powerful iOS repair tool for system-related audio issues.
Author Avatar Joy Taylor Last Updated: May. 10, 2024
I know some people love to have iPhone volume low willingly. But if it happens during an important call or while playing some video, it’s extremely frustrating. And surprisingly, it’s a common problem encountered by many iPhone users in this world. If you are also having this issue, then believe me, you are not alone! Since many people face this issue, there are also many possible solutions for this. And that’s what we’ll be telling you here!
In this article, we’ll be showing you 12 simple methods for fixing iPhone volume low. We’ll also reveal an excellent iOS repair tool to fix any possible system error. But before that, what do you think is causing this iPhone volume low issue? Let’s find out first!
What Causes iPhone Volume Low?
There are several reasons why your iPhone’s volume is persistently low. Understanding the root cause is the first step toward getting that sound back up! Let’s look at some of the common culprits:
  • Software Issues – Software errors or bugs within the iOS operating system cause many issues. These glitches can also interfere with the volume controls and cause unexpected sound issues.
  • Accidental Muting – It’s easy to accidentally touch the volume buttons or the mute switch on the side of your iPhone.
  • Dirt and Debris – Dust, lint, or other gunk might be clogging up your iPhone’s speaker or headphone jack. This can physically obstruct the sound and make it seem low.
  • Bluetooth Mishaps – If you’ve connected your iPhone to a Bluetooth speaker or headphones in the past, it might still be trying to send audio to that device.
  • Outdated Software – Running an old version of iOS could lead to compatibility problems or performance issues affecting your iPhone’s sound.
Your iPhone may have any one of these reasons. Therefore, you have to try multiple methods to fix it.
Fix iPhone Volume Low via Professional Tool Directly [Easy & Safe]
If you suspect the low volume issue stems from a deeper system error, rather than a hardware problem, one of the best solutions is to repair your iOS system.  A specialized iOS repair tool can be invaluable here, and one of the most effective options in the market is AnyFix – iOS System Recovery.
AnyFix is an excellent iOS system repair and recovery tool designed for everyday users. If your iPhone’s audio issues are related to software hiccups, AnyFix can diagnose and resolve a broad range of problems with ease. It gives a user-friendly interface and powerful capabilities for both beginners and more techy individuals.
Key Features:
  • AnyFix can fix over 150 common and complex iOS, iPadOS, and tvOS problems.  From frozen screens to iPhones stuck on the Apple logo, AnyFix can fix it all.
  • You get three different repair modes. Standard Repair (no data loss), Advanced Repair (fixes more stubborn issues, data erased), and Ultimate Repair (revives dead devices, data erased).
  • With this tool, you can fix iPhone issues in 3 steps and 5 minutes. No long time waiting any more.
  • AnyFix can also help fix various iTunes errors, like iTunes not recognize iPhone, cannot sync data to iTunes, and more.
Steps to Fix iPhone Volume Low with AnyFix
Step 1.  Freely Download AnyFix and connect iPhone with the USB cable > Once the interface is below, click the System Repair mode.
AnyFix System Repair Option
Step 2. Connect your iOS device to your computer. Then choose issue types like Device Bug and click on the Start Now button.
AnyFix System Repair Device Bug
Step 3. Select iPhone Problems and tap on Start Now > Choose Standard Repair mode to continue.
AnyFix Standard Repair
Step 4. Verify your iPhone’s model and other details that are displayed on your screen. Click “Download” to get the firmware package specifically designed for your device.
Step 5. Wait for a few minutes and then you will see the Repaired Completed page as follows.
Repair Is Completed
Repair Is Completed
12 Common Ways to Fix iPhone Volume Low
Before going into more complex solutions, there are several simple things you can try to address the low volume problem on your iPhone. These methods target common causes and can often resolve the issue without needing advanced troubleshooting.
Way 1. Clean Your iPhone Speakers Slot
Dust, lint, and debris can accumulate in your iPhone’s speaker slots, muffling the sound. Cleaning the speaker slots can often lead to a surprising boost in volume.
Here’s how to do it:
Step 1. First, prepare a soft-bristled toothbrush, a toothpick, and some rubbing alcohol.
Prepare the cleaning material
Step 2. Use the toothbrush to gently dislodge any visible debris from the speaker openings. If some grime is still stuck, carefully use the toothpick to loosen it.
removing dirt with toothpick gently
Step 3. For extra cleaning power, dip the toothpick’s tip in a tiny amount of rubbing alcohol, but make sure it’s not dripping.
Way 2. Check the iPhone Case and Screen Protector
Sometimes, a bulky phone case or a poorly fitted screen protector can partially block your iPhone’s speakers or microphone. This obstruction might cause the audio to sound muffled or quieter than usual.
  • Remove the case. Take your iPhone out of its case and test the volume.
    Remove the case and screen protector
  • Inspect the screen protector. Ensure that the screen protector isn’t covering any speaker openings or the microphone.
  • Re-test and adjust. If it improves the volume, get a more compatible case or a different screen protector.
If the iPhone volume is still there, then try restarting the device.
Way 3. Restart Your iPhone
This classic troubleshooting trick can work wonders for a surprising number of issues. A simple restart forces your iPhone to refresh its system and clear up minor software glitches that might be causing the low volume problem.
Here’s how to restart:
  1. Press & hold the side button until a slider appears on the screen. This step may vary depending on your iPhone model.
  2. When the “Slide to Power Off” slider appears on the screen, drag it to the right.
  3. After your iPhone turns off, press and hold the side button again until you see the Apple logo.
    Restarting iPhone
    Restarting iPhone
If the volume is still low, then check your call volume settings.
Way 4. Turn up iPhone Call Volume
Your iPhone cleverly has separate volume settings for things like videos and phone calls. If the volume during calls seems too low, it’s likely the call volume specifically needs adjusting.
Step 1: Make a phone call to a friend, or family member.
Step 2: While the call is active, press the volume up button on the side of your iPhone until you reach the desired level of loudness.
Step 3: Make sure you can comfortably hear the person on the other end of the line.
What if it doesn’t solve the issue? Then check the silence switch!
Way 5. Flip the Silence Switch
This one is a quick fix that’s easy to overlook! There’s a physical switch on the side of your iPhone that instantly mutes all sounds. It’s easy to accidentally bump this switch, which can lead you to believe your volume is broken. But in reality, your phone is just silent!
Let’s make sure that’s not causing the problem:
  • Find the switch button. Look for it on the left side of your iPhone, above the volume buttons.
    Flip Switch on iPhone
  • Check the color. If you see a little bit of orange showing near the switch, that means your phone is in silent mode.
  • Push the switch upwards to turn off silent mode.
Now your iPhone will play call and notification sounds again.
Way 6. Turn Off iPhone Noise Cancellation
Noise cancellation is a handy feature on your iPhone that aims to reduce background noise during phone calls. However, sometimes it can interfere with the overall volume output.
Here’s how to disable it and see if it helps:
  1. Open the “Settings” app on your iPhone.
  2. Scroll down and tap on “Accessibility.” Then choose “Audio/Visual.”
  3. Locate the “Phone Noise Cancellation” option and toggle off the switch next to it.
    Turning off iPhone Noise Cancelation feature
If the iPhone volume low situation is still present, then check Bluetooth.
Way 7. Turn Off iPhone Bluetooth
If your iPhone is paired with a Bluetooth device, it might still try to send audio to them even when not in use. Turning off Bluetooth forces your iPhone to use its internal speaker.
  • Open the “Settings” app and tap on “Bluetooth.” You can also swipe down from the top right corner of your screen to open the Control Center.
  • Check the Bluetooth connection. Tap the blue Bluetooth icon to turn it off.
  • After turning off Bluetooth, try playing some audio or make a phone call to see if the volume has improved.
    Turning off Bluetooth from the control panel
Way 8. Use Speaker Mode
Speaker mode can be a temporary fix if your iPhone’s built-in earpiece speaker seems quiet.
To activate it during a call:
  1. While on a phone call, look at your iPhone’s screen. You should see an icon that looks like a speaker.
  2. Tap the speaker icon. This will route the call audio through your iPhone’s bottom speaker.
  3. To switch back to the earpiece speaker, tap the speaker icon again.
If the iPhone volume low situation is still present, then there’s a chance that your device is in headphone mode.
Way 9. Check if Your iPhone Is Stuck in Headphone Mode
Sometimes, your iPhone might think headphones are still plugged in even when they’re not. This can lead to no sound coming from the speakers.
Here’s how to check and fix it:
  • Look at the top of your iPhone screen. Do you see a small headphone icon next to the volume indicator? If so, your iPhone is stuck in headphone mode.
    Check if the iPhone is in headphone mode
  • Try plugging in and then unplugging a pair of headphones a few times.
Way 10. Update Your iPhone
Apple regularly releases software updates that include bug fixes, performance improvements, and new features. Sometimes, audio glitches can be resolved simply by updating to the latest version of iOS.
Here’s how to check for and install an update:
  • Find the “Settings” app on your iPhone and open it.
  • Tap on “General” and then select “Software Update.”
    Opening System Update settings
  • If a new update is available, tap “Download and Install.” Your iPhone will handle the rest.
What? Your iPhone is up to date. Then there’s no way left but to reset this device.
Way 11. Reset All Settings
A complete iPhone reset can always be tried to solve any system issue.
This option resets various settings on your iPhone back to their defaults. It will clear things like network settings, custom ringtones, and more.
  2. Tap on “General,” then scroll down and select “Transfer or Reset iPhone.”
  3. Choose “Reset,” and then tap on “Reset All Settings.”
If the iPhone volume low situation is still present even after all the above methods, then leave it to the professionals.
Way 12. Contact Apple Support
If you’ve tried all these solutions and your volume is still low, it might indicate a hardware problem with your iPhone’s speaker. In this case, getting professional help is the best course of action.
Here’s how to reach Apple Support:
Step 1: Go to Apple’s support website and choose your iPhone model.
Apple Support Webpage Interface
Step 2: Select your preferred option like live chat, scheduling a phone call, or finding a nearby Apple Store.
Step 3: Describe the low-volume problem and the steps you’ve already taken to fix it.
They’ll give you a detailed solution for this issue.
Having the iPhone volume low can be a major inconvenience during important calls and videos. Luckily, there are easy solutions to this problem! In this article, we have explored common causes of this problem and provided 12 potential fixes. From restarting the device to updating it, you can try every single method until your volume is back to normal.
But, if you suspect a deeper system error is the culprit, a powerful tool like AnyFix can be used. AnyFix makes it easy to tackle iOS system problems and restore your iPhone’s audio to full volume.
