Fix iPhone Stuck on Setting Up Apple ID after Upgrading iOS
Sometimes, your iPhone can get stuck on the setting up Apple ID screen. If this happens, you cannot proceed with the setup process and as a result, you cannot use the phone. This guide teaches several ways to get your iPhone out of the stuck mode.
Author Avatar Joy Taylor Last Updated: Jul. 25, 2024
New iphone taking forever to set up. This is my first iPhone, and I selected “manual setup”. I have been stuck on the “set up your Apple ID” for the past 30-ish minutes. I have tried to force restart twice and still no change. Is this normal? And if not, what are the next steps? Thanks!
iPhone Stuck on it may Take a few Minutes to Set Up your Apple ID
Fix iPhone Stuck on Setting up Apple ID Issue
Apple provides you with a really easy way to set up your new iPhone. If you have bought a new iPhone, let’s say the upcoming iPhone 14, you can simply boot it up and follow the on-screen process to set it up. However, sometimes users experience issues setting up their device as the above user said. What if your new iPhone comes into this problem in the near future?
AnyFix – Fix iPhone Stuck on Setting up Apple ID Easily
Free download AnyFix to 1-click repair all the iOS system issues quickly, including the iPhone stuck on setting up Apple ID problem.
If you are frustrated by not being able to properly set up your device, there are several ways to get around this issue on your iOS-based device. The following guide describes those methods and tells you how you can implement them. Once you have performed these methods, you should be able to set up your new iPhone without any issues.
Further Reading: How to Fix iPhone Quick Start not Working
How Long Will Setting up Apple ID Take
Setting up a new iPhone is extremely easy, thanks to Apple for making the process so efficient. Whether you have ever set up a new iOS device or you have not, you can still set up your new iPhone in a few easy taps. Setting up an iPhone should take no more than a few minutes provided you are not restoring any backups on your phone.
If you are restoring an iTunes backup or files stored in iCloud backups, the setup process could take a bit longer as it needs to fetch the files from your computer or iCloud and restore them on your device.
The following steps briefly show how you can set up a new iPhone.
  1. Turn on your shiny new iPhone and select a language that you want to use.
  2. Unless you want to transfer data from another iPhone, tap on the option that says Set Up Manually.
  3. Connect your iPhone to your WiFi network by selecting a network from the list.
  4. Your iPhone will then ask you to set up a security option like a Face ID or a passcode.
  5. Follow the on-screen instructions and your iPhone will be set up.
Add a Security Option to the iPhone
Add A Security Option to the iPhone
How to Fix when iPhone 17/16/15 Stuck on Setting Up Apple ID
If your iPhone gets stuck on the setting up Apple ID despite following the standard setup process, there may be an underlying issue causing your phone to get stuck. The following are some of the fixes that you can apply to your phone and see if your issue gets resolved.
1. One-Click Fix iPhone 17/16/15 Stuck on Setting Up Apple ID
If you can be sure that the problem is caused by a system error, you need an iOS system repairer to fix the iPhone stuck on setting up the Apple ID issue. A third-party app, AnyFixiOS system recovery, allows you to fix almost all kinds of errors and issues on your iOS-based devices.
You can use the app’s System Repair feature to go deep down into your phone’s core software and fixes it for you. Not just the iPhone stuck on setting up the Apple ID problem, you can also use it to fix problems as iPhone stuck on lock screen, iPhone stuck on update screen, iPhone stuck on restoring from iCloud, iPhone won’t reset, etc.
AnyFix – iOS System Recovery
  • Fix iPhone stuck on setting up Apple ID with one click.
  • Fix all the problems you may encounter when shifting to a new iPhone.
  • All iPhone models are supported, including the newest iPhone 14.
  • Highest ever success rate guaranteed.
The following shows how to fix the “iPhone stuck on setting up Apple ID” issue.
Step 1. Download the AnyFix for your Windows or Mac computer and install it. Connect your iPhone to your computer, launch the app, and click on System Repair.
AnyFix System Repair Option
Step 2. Select Start Now on the following screen to begin fixing your iPhone.
Step 3. Choose a repair mode to fix your device. Basically, the Standard Repair mode can solve your problem; if it didn’t, try the other two modes.
AnyFix Standard Repair
Step 4. Follow the on-screen instructions and your iPhone will eventually be fixed.
Repair Is Completed
Repair Is Completed
2. Try to Restart iPhone First
No matter what error or issue you experience on your iPhone, the first thing you should do is to reboot your device. Rebooting your iPhone is actually a magical process in many ways. It clears up the temporary files and configurations on your phone. This gives your phone a chance to clear any problematic files that may be causing issues with the setup process.
Also, rebooting an iPhone is a pretty basic process. It does not harm your device in any way you can do that by just pressing a button on your phone. The following shows how to restart various models of the iPhone.
Restart an iPhone X or Later
Press and hold down either the Volume button and the Side button, drag the slider, and your phone will turn off. Press and hold down the Side button to turn your phone back on.
Restart iPhone X or Later Models
Restart an iPhone SE, 8, 7, 6, or Earlier
Press and hold down the Side button, drag the slider, and your phone will be off. Press and hold down the Side/Top button again to power on your phone.
Restart iPhone 8 or Earlier Models
3. Remove and Reinsert SIM Card
When you boot up your iPhone, one of the things that your device does is detect your SIM card. This SIM card is how your phone gets network signals and is able to perform network tasks like making calls and receiving messages. This needs a working and properly inserted SIM card.
If you are new to the iPhone and you have never used one before, you might need some assistance in setting up a new SIM card on your phone. This is important because if your SIM card is not properly inserted, your iPhone will not recognize it. As a result, your device could get stuck on the setting up Apple ID screen and will not move past that.
The best way to fix this issue is to remove and reinsert the SIM card into your iPhone. You can do that as follows.
Eject and Put Back the SIM Card into the iPhone
  1. Turn off your iPhone.
  2. Pull out the SIM card tray from your iPhone.
  3. Remove the SIM card from the tray.
  4. Put the SIM card back onto the tray.
  5. Slide the tray back into your iPhone.
  6. Turn on your iPhone and it should let you proceed with the setup process.
4. Force Restart iPhone
You can force restart your iPhone to try and fix the issue if the normal restart did not work for you. Force restart basically forces the iOS operating system on your phone to turn off. It then instructs it to turn back on again.
Try to Hard Reset iPhone
You can force reboot most models of the iPhone by pressing and holding down the Home and Power buttons at the same time. When your phone reboots, you can try setting it up and it should work this time around without any issues.
Bonus Tip. Move Data from Old iPhone to New iPhone 17 without Apple ID
If you want to sync data from the old iPhone to your new iPhone at any time, AnyTrans is here to help you with ease. It can migrate data from Android or iOS devices to the new iPhone. Now, you can get the latest version of AnyTrans and use Phone Switcher (as shown below) to set up your new iPhone.
Choose Phone to iPhone on Phone Switcher
If your iPhone ever gets stuck on the setting up Apple ID screen, you may download AnyFix to fix the problem. And if you want to transfer all the data from the old iPhone to the new one, AnyTrans can do that for you. Download them to solve your problem with ease.
