11 Methods to Fix iPhone Stuck in Boot Loop
It is a terrible problem that your iPhone stuck in a boot loop. You must worry about whether your phone works again because there are many important data on your phone. So in this article we will talk about how to fix iPhone boot loop.
Author Avatar Joy Taylor Last Updated: Jul. 25, 2024
AnyFix – Fix iPhone Stuck in Boot Loop in Clicks
iPhone stuck in boot loop? Just download AnyFix to 1-click fix iPhone boot loop without hassle. No skills are needed. No data loss. Supports all iPhone models and iOS versions, including iPhone 15 and iOS 17.
Have you been into situations like the Apple logo on the iPhone displays for a few seconds, then suddenly disappears and reiterates? This means that your iPhone has suffered the common iPhone boot loop problem. Honestly, this is very bad because your iPhone will continuously restart and cannot be usable. So why does this problem happen and how to fix? Don’t worry! This article gives you 10 feasible solutions to fix iPhone stuck in boot loop. Please continue reading the following content.
What Causes iPhone Boot Loop?
We should not only pay attention to how to fix the problem of iPhone stuck in the boot loop, but also point out what causes iPhone boot loop. This is an important premise, so we can try to avoid this kind of problem from happening again. There are common reasons why the iPhone stuck in the boot loop:
  1. Updating Software Failed: Usually, it is because your updating iOS process gets halted accidentally, then it might lead to the occurrence of an iPhone stuck in boot loop. Even after completing the update, your phone might malfunction and have this issue.
  2. Trying to Jailbreak iOS: It is very dangerous to jailbreak your iPhone. If not finished, your iPhone will break down and cannot be able to perform again.
  3. Unstable Connection: When updating or backup data with iTunes, the unstable connection between the iPhone and computer also will lead your iPhone stuck in boot loop.
After getting the reasons for iPhone boot loop, you may attach importance to the solutions. 10 methods can help you solve iPhone stuck in boot loop. Among them, we recommend you take the first 2 solutions as they fix all system errors at once with simple steps.
1. Fix iPhone Stuck in Boot Loop in Simple Clicks Directly [Safe & Easy]
If you are looking for an easy way to fix iPhone stuck in boot loop without any data loss, AnyFix – iOS System Repair must be your optimal choice. Providing 3 repair modes, this software is designed to make every effort to ensure you can fix 150+ system problems on your iPhone, iPad, iPod touch, or Apple TV, like stuck on Apple Logo, iPhone stuck on update loading screen, the device won’t charge, iPhone won’t turn on, etc. and the success rate is the highest ever. And here are the key features of AnyFix.
Key Features:
  • Fix 130+ iOS system issues and 200+ iTunes errors, like iPhone screen frozen, touch screen not working, boot loop, iTunes won’t recognize iPhone, etc.
  • Just click the buttons to repair issues in 3 minutes. No long waiting and use your device as normal immediately. No skills are needed.
  • Use standard mode to fix system issues without data loss. All the important contents on your device will be safe and sound.
  •  Support all iPhone and iPad models, including iPhone 15. Cover all iOS versions, like iOS 17.
Now you can free download AnyFix on your computer and use it to fix iPhone stuck in boot loop without data loss.
How to Fix iPhone Stuck in Boot Loop with AnyFix:
Step 1. Free download AnyFix on your computer and open it. Choose System Repair function.
AnyFix Main Screen
Choose System Repair on the Homepage
Step 2. Connect your device to the computer. Select Screen Stuck and click Start Now.
Step 3. 3 repair modes for you to choose. To avoid data loss, you can choose Standard Repair first.
AnyFix Standard Repair
Step 4. Download the firmware to start the fixing process. When repair is completed, you will see the interface below.
Repair Completed
Repair Completed
2. Fix iPhone Stuck in Boot Loop without Data Loss [Hot]
When you encounter iPhone reboot loop and seek help on the network, you will find that the usual methods are not perfect and most will wipe your device’s data. In this case, we recommend that you try PhoneRescue for iOS. PhoneRescue for iOS is designed to make every effort to ensure you can fix the many system problems on your iPhone, iPad or iPod touch, like iPhone bootloop, stuck on Apple Logo, iPhone won’t turn on, the device won’t charge, iPhone stuck on lock screen, etc., and the success rate is the highest ever.
  • Easy to operate. Even if you are not familiar with computers, you are fully capable of repairing your device by following the PhoneRescue for iOS steps.
  • Will not leak or erase data on your device. PhoneRescue for iOS offers 2 repair modes to maximize the security of your data and meet different repair needs.
  • Multiple supported device types. PhoneRescue for iOS supports almost all iPhone, iPad, and iPod touch models, and the latest iOS 17 and iPhone 15 are also supported.
  • Many other useful features. You can also use PhoneRescue for iPhone boot loop data Recovery. It allows you to recover all data types, like photos, videos, etc., without backup, from iCloud, and from iTunes.
Now, please refer to the following steps to fix iPhone stuck in boot loop.
Step 1. Get PhoneRescue for iOS on your computer. Open it. Click Repair iOS System under Device Rescuer.
Choose the Repair iOS System Mode
Step 2. Here are two repair modes that you can choose. Advanced Mode enables you to restore iPhone without data loss. If you also want to reset your iPhone to factory settings, you can choose Standard Mode.
Select the Advanced Mode to Fix Your Bricked iPhone/iPad
Step 3. Follow the on-screen instructions to enter recovery mode > Click Download button to get a matching firmware package.
Download Matching Firmware
Step 4. Minutes later, you’ll see iOS repairing completed page and then you can reboot the device to use it normally.
iOS Repairing Completed
3. Update iTunes to the Latest Version
Most people suffer from the boot loop iPhone problem and can’t connect iPhone to iTunes. iPhone stuck in boot loop while you try to update iOS by using an old version of iTunes. What you need to do is to check if an iTunes update is available. Please refer to the following steps to update iTunes to a new version to fix iPhone boot loop.
Open iTunes and click “Help” and “Check for Updates” and then follow the instruction to install the newest version.
Check for Updates
Check for Updates
4. Fix iPhone Stuck in Boot Loop via iTunes
After upgrading iTunes, you can break the iPhone boot loop and fix this iPhone by taking the assistance of iTunes/Finder (Mac with macOS Catalina or higher).
Step 1. Please launch iTunes and connect iPhone 14, iPhone 13, iPhone 12, or any other iPhone model to computer with a cable.
Step 2. Within a few seconds, iTunes/Finder will detect a problem with your device and display the following pop-up message. At this time, please click “Restore” button to go on.
Restore the iPhone with iTunes or Finder
Step 3. If you won’t get the above pop-up message, then you can manually restore your phone as well. Just click on the “Summary” button, and then click “Restore iPhone“.
5. Force Restart Your iPhone to Fix iPhone Stuck in Boot Loop
How to get iPhone out of boot loop? Don’t worry, here is a common way, which is force restart your iPhone, when your iPhone has a problem, but it may not always take effect. But as we all know, restarting can always solve some iPhone problems, so just follow the steps below to fix iPhone stuck in reboot loop.
Force Restart Methods of Different Models iPhone
For the different model of iPhone you need to hold different keys at the same time:
  • For iPhone 6s/6 and earlier, press the “Home” button and “Power” button at the same time and hold on for seconds until you see the screen go black, you can release both of them. Then press the “Power Button” and hold until the Apple logo comes up then let go of the button.
  • For iPhone 7 and 7 plus: Please press and hold the “Power” button and the “Volume Down” button of your iPhone simultaneously. Once you see the screen go black, you can release both of them. Then press the “Power Button” and hold until the Apple logo comes up then let go of the button.
  •  For iPhone 8, iPhone XS, iPhone XR, iPhone 13 and iPhone 14: Press and release the “Volume Up” key and repeat the same with the “Volume Down” key. Then hold down the “Power” key and wait for the Apple logo to appear. Finally, enter your password to start your iPhone.
6. Enter Recovery Mode with iTunes to Fix iPhone Stuck in Boot Loop
You can repair system problems by putting your iPhone into recovery mode. But it should be noted that entering the recovery mode will result in the loss of device data, so please make sure that you have backed up the data in the device before starting to enter the recovery mode. To fix iPhone stuck in boot loop in recovery mode, you can follow the guide below.
Step 1. Please turn your iPhone off.
Step 2. Open iTunes/Finder in PC/Mac and connect one end of the USB cable to the computer. Make sure the iTunes program is not running.
Enter Recovery Mode
Enter Recovery Mode
Step 3. The different models iPhone follow different steps:
  • iPhone 8 and later: Connect the other end of the cable to your iPhone, and at the same time hold down the Side button.
  • iPhone 7 /7Plus: Connect the other end of the cable to your iPhone, and at the same time hold down the Volume Down button.
  • iPhone 6S series and earlier: Connect the other end of the cable to your iPhone, and at the same time hold down the Home button.
Step 4. Please keep holding the Side/ Volume Down/ or Home button until the iTunes logo appears. It means that your phone is now in Recovery Mode.
Step 5. Then you will see a window pop up in iTunes offering to let you Update or Restore the phone. Please click Restore to resolve the problem.
Restore iPhone iPad in Recovery Mode
7. Restore iPhone from Backup
In some cases, restoring the previous backup to the computer can help user’s iPhone to get out of the iPhone keeps restarting loop situation. So here is how to fix a boot loop iPhone via restore.
  • Open iTunes and click “Summary” and “Restore Backup”.
Click Restore Backup from iTunes
8. Update iOS System
If you still can’t fix the iPhone boot loop problem after checking iTunes, you can check to see if you have your version of iOS, as sometimes iPhone boot loop problems are caused by an older OS version. For example, if some new apps are not compatible with an older iOS version, your iPhone may get stuck on the boot loop. And this kind of problem can often be solved by upgrading the iOS version. Follow the guide on how to fix iPhone boot loop.
To update your iOS system, go to Settings > General > Software Update. If an update is available, click Download and Install” to update.
9. Clean up Apps to Fix iPhone Stuck in Boot Loop
If your iPhone stuck in boot loop, you may need to clean up your apps to fix this issue. Perhaps, you only need to clear the cache of the application to free up more storage space.
You can Go to Settings > Select All Apps and click it > Tap on the app that needed to clear cache and select storage > Clear cache. In other cases, you need to delete unused apps or applications that frequently cause problems.
10. Reset All Settings to Fix iPhone Stuck in Boot Loop
Because some settings may cause the iPhone boot loop issue, you can try to reset all settings to get iPhone out of boot loop. Also please note this will erase all your data in iPhone.
Please head to General>Reset>Reset All Settings.
How to Reset All Settings on iPhone
11. Check the Hardware at Apple’s Support Center
If none of the above methods helped you fix iPhone stuck in boot loop, then we suggest you go to the Apple after-sales center to check whether the phone hardware has a problem. It is necessary to judge whether the hardware is damaged since any improper hardware changes will cause the device to malfunction.
Check iPhone Internal Hardware
If you have fixed iPhone boot loop by using the methods in this article, we hope you can share it with your friends and families who suffer from such issues. If you want the easiest method, we highly recommend you free download AnyFix or PhoneRescue for iOS to fix iPhone stuck in boot loop. Let us know if you have any other problems with the iOS system.
