If iPhone keeps flashing Apple logo and will not move past that, there may be an issue with your phone’s system. There are various ways to fix the iPhone flashing Apple logo issue and the following guide covers some of these methods for you.
System issues will cause the iPhone flashing Apple logo. To bring your iPhone back to normal, free download AnyFix to fix with easy steps. No data loss and the latest iPhone 16 series are supported.
My new iphone 12 pro is just flashing the apple logo off and on after doing restore through iTunes. What do I do?
– An iPhone user from the Apple community
Sometimes your iPhone will not work the way it is supposed to. One of the issues you could experience is that the iPhone keeps flashing Apple logo as the above user described. So you can not enter the home screen and will be stuck on the Apple logo screen forever. Why Apple logo keep flashing and how to fix this issue? The following post shows several efficient ways to fix the iPhone flashing Apple logo issue on your iOS device and use your phone normally as you would.
System issues and hardware damages will cause the Apple logo flashing problem. Here are the common causes for iPhone flashing Apple logo:
1. Restore Errors: Some iPhones are just flashing Apple logo on and off after doing restoration through iTunes. If that happens, the iPhone keeps flashing Apple logo and resetting the process.
2. Water Damage: Other users found that their iPhone flashing Apple logo after water damage, and then get a black screen.
3. Update Errors: A random shut-off on and won’t turn on, a blinking Apple logo can happen during the system update process and an update file gets crashed. And updating to the latest iOS version, for example, iOS 18.
If you’re meeting the above situations and the iPhone flashing Apple logo issue, keep reading the following methods to fix it efficiently.
What do I do when my iPhone is flashing the Apple logo? You should first try to force restart the device. This will reboot the iOS system and remove some system errors. After restarting, you can check if the iPhone flashing Apple logo is fixed.
If simply force restart iPhone not working for your device, using third-party software will always repair iPhone/iPad system issues quickly and easily. AnyFix – ios system recovery is designed to solve all kinds of system issues and iTunes errors on your iPhone, such as blinking Apple logo, iPhone won’t restore, iPhone is stuck on a black screen, iPhone/iPad disabled connection to iTunes, etc. Besides, you can update your iPhone to fix iOS bugs that cause Apple logo flashes. It also provides you with 1-click to enter/exit recovery mode or reset your iPhone. Check more main features of AnyFix below:
Follow the detailed steps to get your iPhone out of the iPhone flashing Apple logo trouble.
Step 1. Download AnyFix and run it on your computer > connect your iPhone to the computer > choose System Repair at the top of the page.
AnyFix Main Screen
Step 2. Here you will see 7 options. Click on the Screen Stuck option, then tap on Start Now to go on.
Step 3. Choose Standard Repair that will not erase data on your iPhone and fix the flashing Apple logo issue.
AnyFix Standard Repair
Step 4. Get the iPhone into recovery mode > and then AnyFix will download the right firmware file on your computer > After the download, click on Start Standard Repair.
Step 5. Once it finished the repair, you can see the Repair Completed page below and get your iPhone back to normal.
Repair Is Completed
The other iOS system repair tool you can try to fix the iOS system to get rid of the flashing Apple logo with PhoneRescue for iOS. It provides you with 2 system repair modes to save the iOS system from any breakdowns, like Apple logo flashing on iPhone, bypass support.apple.com/iphone/restore screen, frozen iPhone, stuck in recovery mode, etc. And it can also protect your important data from losing while fixing the issues. It supports all iPhone models and iOS versions, including iPhone 16 and iOS 18.
Check the steps below to fix iPhone flashing Apple logo:
Step 1. Get PhoneRescue for iOS on your Mac/Windows. Go to Device Rescuer and choose Repair iOS System.
Click Device Rescuer and Choose Repair iOS System
Step 2. Choose Advanced Mode (no data loss) or Standard Mode.
Step 3. Follow the on-screen instructions to enter recovery mode.
Enter Recovery Mode
Step 4. Click the Download button to get a matching firmware package for your device. After that, PhoneRescue will start the repair process.
Click Download to Get Firmware
Step 5. Wait for the iOS Repairing to be Completed, and your iPhone will be restored to normal, restarting immediately.
iOS Repairing Completed
Another way to fix iPhone flashing Apple Logo is via hard reset. Hard resetting your device does not delete the device but refreshes the operating system. This gives your phone a chance to fix faulty files and let you use your phone normally. The following steps to hard reset an iPhone vary with the iPhone model you have.
Hard reset an iPhone with Face ID and iPhone 8 (Plus)
Step 1. Press the Volume Up button and let it go.
Step 2. Press the Volume Down button and let it go.
Step 3. Press and hold down the Side button and you will see the Apple logo on your screen.
Hard Reset an iPhone 7 or iPhone 7 Plus
Step 1. Press and hold down both Volume Down and Sleep buttons at the same time.
Step 2. Let go of the buttons you have been holding down when the Apple logo appears on your screen.
Hard Reset an iPhone 6s, iPhone 6s Plus, or iPhone SE (1st generation)
Step 1. Press and hold down both the Home and Power buttons at the same time.
Step 2. Release both buttons when the Apple logo appears on your screen.
Using iTunes to update or restore your device will solve Apple logo flashing on iPhone. Each of these options resets your device differently and you will see how they work in the following steps.
Step 1. Connect your iPhone to your computer via a USB cable and launch the iTunes app.
Step 2. Enter the recovery mode on your iPhone. You can do it for various iPhone models as follows.
Reboot the iPhone into Recovery Mode
Step 3. iTunes on your computer will prompt you to either update or restore your device. If you click on Update, it will update the iOS version on your iPhone and will not delete your data. If you click on Restore, your iPhone will clean install an iOS version and delete everything on your phone.
Fix the iPhone Flashing Logo with iTunes
Depending on what option you choose, iTunes will either update or restore your device. Your iPhone will no longer show the flashing Apple logo on your screen.
There are 5 proven ways we have introduced for fixing iPhone flashing Apple logo, of which AnyFix and PhoneRescue for iOS are highly recommended to fix iOS system issues without data loss. Download AnyFix now and say goodbye to iPhone flashing Apple logo issues.
