iPhone ear speaker not working? This is an annoying problem. But no worries, we will introduce some effective ways to fix ear speaker not working on iPhone. Try them out and bring your ear speaker back to normal.
AnyFix can help check and fix iPhone ear speaker not working issues quickly and securely without data loss. The advanced system repairing technique makes it easier to locate the problem and make a solution. Download AnyFix now and bring your iPhone ear speaker back to normal.
There are numerous reasons why iPhone ear speaker not working issues could stem up. Below, we have the list of why your iPhone ear speaker isn’t working:
1. Low Volume: Your iPhone volume has a significant effect on whether or not you can hear your respondent during a voice call. If you have a low volume the audibility falls and you may think your iPhone speaker isn’t working.
2. Presence of Dirts in Speaker: The ear speaker which is usually situated at the top of the phone could be filled with dirt that blocks the transmission of sound from the respondent thereby causing the underlying issue.
3. Connectivity Issues: Are you a fan of headphones such as AirPods, earbuds, and others? If so, and you are experiencing ear speaker not working issues on your iPhone, then it could be a connectivity issue. It’s either you’ve made the wrong connection or the headphones aren’t in proximity to your iPhone.
4. Software Issues: Here is another common reason your iPhone ear speaker isn’t working. When you run your iPhone on obsolete iOS or damaged firmware, it displays several issues and ear speaker not working is one of them.
5. Use of Unfitted Accessory: Certain accessories like screen protectors and others that don’t fit your iPhone could also be the reason why you are faced with ear speaker not working issues.
With any of the 7 troubleshooting solutions recommended below, it’s possible to fix ear speaker not working on iPhone issues from the comfort of your home:
Did you connect your headphones to your iPhone and forget to disconnect it before using the ear speaker for your voice call? This could result in the underlying issue as audio will only be transmitted to the headphones. However, you can resolve the problem by simply exiting the headphone mode on your iPhone.
A simple guide to complete this is shared down here:
Noise cancellation is an advanced feature integrated into an iPhone to reduce the ambient noise from the surroundings during a voice call. Though this is good, it might not be needed at some point. In case you have the feature enabled on your device, you should turn it off to fix the ear speaker not working problem encountered on your iPhone.
Follow these steps to turn off noise cancellation on your iPhone:
Turn Off iPhone Noise Cancellation in Settings
For those ear speaker not working issues caused by system crashes, it’s better to check and fix with AnyFix – iOS system repair tool. It’s skilled in fixing any system-related issues such as iPhone dictation not working, ear speaker not working on iPhone, and more. The software powers a brilliant system repair algorithm that focuses on the underlying issue and not your iOS or data. Thus, you need not worry about data loss when using AnyFix.
Key Features
Stepwise Guide to Repair iOS System to Resolve Ear Speaker Not Working on iPhone:
Step 1: Launch AnyFix. Navigate to where you have System Repair and hit Repair Now.
AnyFix Main Screen
Step 2: Proceed to link your faulty iPhone to the computer with the aid of a USB cable. If the connection is done properly, the following screen will come up:
Select Device Bug on the left sidebar and click on Start Now.
AnyFix System Repair Device Bug
Step 3: Choose a repair mode from the 3 options provided on the subsequent screen. Select Standard Repair mode.
Head to the bottom of the screen and click on Standard Mode.
AnyFix Standard Repair
Step 4: Next, your iPhone will be scanned and a suitable firmware package will be recommended. Tap on Download to proceed.
Wait until the download is over, then click on Start Standard Repair when the next screen appears.
When the firmware is downloaded, you can click Fix Now. AnyFix will start checking your iPhone and resolve the ear speaker not working issues quickly.
Flexibility in usage is one of the great qualities of an iPhone and one way to experience this is in the selection of your audio destination. You are allowed to select where your audio should be transmitted, whether via ear speaker, headphone or microphone. Since the underlying issue deals with the ear speaker, you should select ear speaker as your preferred mode audio destination.
To do this, here’s the quick guide you should follow:
Force restart is one of the basic solutions often used to clear the errors and bugs that are causing it to malfunction. It refreshes the entire system and improves the RAM thereby optimizing its functioning.
To do a force restart on your iPhone, you know what model you are using as the procedure differs. Use one of the following illustrative guides that suit you from the procedures below:
iPhone 8/X and Later Model
Your iPhone screen will quickly go blank and then display the Apple logo afterward which signals that you’ve successfully force restarted the device.
iPhone 7 series
iPhone 6/5 and Older Models
Force Restart iPhone of Multiple Models
As previously mentioned, when dirt is trapped in the ear speaker of your iPhone, the audibility is affected. Checking and cleaning the ear speaker from time to time is an effective solution to fix the issue.
To do this, follow the step-by-step guide below:
Note: This operation can be performed at any time to avoid future occurrences of ear speaker not working issues.
With factory reset all wrong custom settings and harmful apps that might be responsible for ear speaker not working problem will be removed as your iPhone is returned to factory mode just like when you newly bought it.
To avoid data loss, we strongly suggest that you backup your device before performing a factory reset on it. Follow these steps if you’ve done this:
Factory Reset iPhone with Erase
You may also like: How to Factory Reset iPhone Without Passcode
Now you know why your iPhone ear speaker may fail to emit sound properly and the best solutions to reinstate its operation. This post presented 7 free ways to resolve iPhone ear speaker not working issues, choose and apply the one that’s easiest for you. However, our most preferred solution is the one requiring an iOS system repair tool- AnyFix. The software handles this type of problem excellently without causing any damage to any of the data you have in your storage.
