This article provides 12 easy ways to fix the AKAuthenticationError 7005 with complete step-by-step guides. Whether it results from poor network connections, incorrect time zones, or deeper software issues, you’ll find a solution that works best for you.
Facing the AKAuthenticationError 7005 when resetting your phone or Apple ID? Well, you’ve landed in the right place to find a solution!
Several users have complained about the 7005 authentication error. It can hinder you from resetting your Apple ID and phone before reselling or giving it away, which can be frustrating.
But don’t worry! There are ways to get past this error without getting any technical help. This article offers twelve practical ways to fix the Authentication Error 7005 with stepwise guides.
So let’s get started!
AK Authentication Error 7005 is the verification error commonly occurring when factory resetting an iOS device. Your iPhone or iPad displays this message when verifying your Apple ID or password fails.
AKAuthenticationError Error 7005 Message
Most users have faced this error when resetting their phone. However, it can also occur when trying to erase your Apple ID or signing in to iCloud. Let’s see what the root causes of this error are.
Getting the AK Authentication error 7005 can be annoying, especially if you don’t know what’s causing it. But don’t worry! Various factors can trigger this issue. Here’s a look at what these are.
Let’s consider these reasons and find out how to fix this error!
Are you ready to get past the AKAuthenticationError 7005? Here are twelve easy ways at your disposal. Go through each of them to find the one that works perfectly for you!
Connecting to a stable internet connection is one of the common ways to fix the verification failed error. This will ensure your phone can connect to Apple’s servers properly and prevent authentication issues.
Here are the steps to check your network or WiFi connection.
Step 1. Access your iPhone’s “Settings” menu and press the “WiFi” option.
Step 2. See if the WiFi is turned on. The toggle switch next to Wifi will be green if turned on.
Step 3. See if your connected network is active. A “No internet connection” next to the WiFi implies your phone is disconnected.
Check the network connection
Alternatively, try browsing Safari or using any app that requires an internet connection. This will give you an idea about the speed of your internet connection.
However, this method may not always work. Let’s see another way to fix this issue below.
Is your iPhone or iPad running a VPN in the background? That could be another cause for the authentication error. Turning the VPN off can help you get past this issue quickly.
Let’s see how to turn off the VPN on iPhone and iPad.
Step 1. Unlock your iPhone and access the “Settings” app.
Step 2. Find the “VPN” option and tap the toggle to turn it off.
Turn on VPN in Settings
Step 3. If you don’t see the toggle, tap “VPN” to access its settings. Then, press the toggle next to “Status” to disconnect the VPN.
Disconnect the VPN
This should fix the AK Authentication Error 7005. However, you may not be using a VPN to begin with. This method will not work for you then.
But don’t worry! Keep reading for another effective solution!
Verification Failed error 7005 can also occur due to random glitches with your iOS system. Restarting your iOS device is a quick way to fix it. The restart process can differ for various iphone models.
Use our guide below to restart your phone.
iPhone X, 11, or later
iPhone Hard Reset the device
iPhone 6, 7, 8, and SE (2nd, 3rd gen.)
Press and Hold the Side Button
iPhone SE (1st gen.), iPhone 5, or earlier
Press and Hold the Top Button
Let’s move forward and discuss another way to fix the AK Authentication Error 7005.
Apple’s servers expect the date and time settings between them and your phone to match. An incorrect time zone can hinder the verification process and lead to errors.
A quick fix for this is to set your date and time settings to update automatically. Let’s see how to do it.
Step 1. Go to your iPhone/iPad’s “Settings” menu and tap “General.”
Step 2. Scroll down and press the “Date & Time” option.
Step 3. Tap the toggle for “Set Automatically” to update your date and time settings.
Enable Date & Time to Set Automatically
This should solve the failed verification issue and the error 7005. But if that’s not the case, don’t panic. Below, you’ll find a sure fix to eliminate this problem.
If all the above methods fail, there might be a hidden issue with the iOS system. It can cause random errors and significantly limit your iPhone/iPad’s performance. However, you can fix this issue instantly with a system repair tool like AnyFix.
AnyFix is an advanced repair tool that handles over 150 iOS software issues effortlessly. Whether it’s authentication problems, frozen screens, or touchscreen issues, AnyFix can fix them all.
Let’s see how to use it to fix the AK Authentication Error 7005 instantly.
Step 1. Download and install AnyFix on your PC. Open it and select the “System Repair” tool from the main screen. Then, click “Repair Now.”
Click System Repair
Step 2. Connect your iPhone and computer with a USB cable and unlock your phone. Wait for your phone to be detected. Then click “Start Now” to begin.
Click Start Now
Step 3. Select the level of repair you want on the next screen. Choose “Standard Repair” to keep your phone’s data safe, and click the “Standard Repair” button.
Click Standard Repair
Step 4. AnyFix will now search for the firmware to fix your iPhone’s system. Check the configuration profile information and click “Download” for the file.
Click Download
Step 5. Check if the configuration file is downloaded. Then click “Start Standard Repair” to initiate the repair process.
Click Start Standard Repair
Step 6. AnyFix will begin the repair process to fix your iOS system’s authentication errors. A “Repair Completed” message will appear once the repair is complete.
Repair Completed Successfully
That was effortless, right? AnyFix makes removing errors easy and ensures a smooth iOS experience. Now, let’s move ahead and explore another method to fix this error.
Sometimes, the cause for the AK Authentication Error 7005 might lie on Apple’s end and not yours. You may see a verification error when using a specific service. Apple’s servers for that service may be down at the time.
Here is how you can check the status of the Apple Servers.
Step 1. Go to the Apple System Status page. Look for the service you were trying to use when the error occurred.
Step 2. Make sure that the service has a green indicator next to it. A red indicator would mean that it is down.
Now, let’s explore how to fix this error using iCloud.
You can also get past the AK Authentication Error 7005 by refreshing your iCloud account. This means signing out and signing in to your Apple ID.
Step 1. Access your iPhone’s “Settings” app and press your name at the top.
Step 2. Move down to the end and tap the “Sign out” button. Enter your password and tap “Turn off.” Then press “Sign out” once more.
Sign Out Apple ID
Step 3. Restart your iPhone and go to “Settings.” Press the “Sign in” option to sign in with your Apple ID and password.
Sign in with your Apple ID
Some users have faced the authentication error when signing out of Apple ID. So, this method may only work for some. Keep reading for another solution to resolve this error.
Using an outdated iOS version can also trigger the authentication error 7005. You can solve it quickly by updating to the latest software version. Just ensure your phone is fully charged and has enough storage for the update.
Let’s see how to get the latest iOS update on iPhone.
Step 1. Access your iPhone’s “Settings” app and tap “General.”
Step 2. Select “Software Update” on the new screen. This will trigger the iPhone to look for the latest updates.
Step 3. Once the update is available, press “Download and Install.” Then tap “Install” again to begin.
Install the Software Update
Your device will restart after it’s updated. And you won’t be dealing with an authentication error. Not you? Here’s another solution to get rid of it!
Turning on two-factor authentication is another way to remove the AKAuthenticationError 7005. Enabling it will require an additional code for the verification that will help you get past the error message.
Here are the steps to turn the Two-Factor Authentication on.
Step 1. Access “Settings” on your iPhone or iPad. Press your name at the top of the screen.
Step 2. Tap “Password & Security” and press the “Turn on two-factor authentication” option.
Tap Two-Factor Authentication
Step 3. Type your Apple ID password and tap “Next.” A new screen will open. Here, answer the security questions.
Enter Apple ID Password and Security Answers
Step 4. Type your phone number in the required field to receive the verification code and tap “Next.” Enter the verification code sent to you.
Enter the Phone Number and Verify It
Alt text: Enter the phone number and verify it
That’s all. This should help remove the authentication error. However, if the 2FA is already enabled but you still have the error, our next solution can be helpful.
Network connectivity issues can also cause the AKAuthenticationError 7005. If your iPhone or iPad is connected to a stable network but you’re still having the error, resetting network settings can help.
Let’s see how you can do it with the steps below.
Step 1. Go to your iPhone’s Settings and press the “General” option.
Step 2. Scroll down and press “Transfer or Reset iPhone.” A new screen will open up.
Step 3. Tap “Reset” on the new screen and choose “Reset Network Settings.”
Reset the network settings
You should know that resetting will erase all of your saved WiFi passwords. So, proceed with caution. You can also try the following solution if this method does not work.
Erasing Apple ID when it’s being used with other apps can also trigger the verification error. These apps may include the App Store and iTunes. Signing out from these apps should resolve this error.
Here are the steps you can use to sign out.
Step 1. Access the “Settings” app and tap your Apple profile at the top.
Step 2. Press the “iTunes & App Store” option. A new screen will open up with your Apple ID displayed at the top.
Step 3. Tap on your Apple ID and choose “Sign out” from the pop-up.
Click on Apple ID
That’s it. This should solve the verification error. However, you can contact Apple Support as a last resort if it does not.
Suppose none of the methods above work for you. Then, you can contact Apple Support and get their help in resolving the AKAuthenticationError 7005.
You will get in touch with an Apple representative and receive instructions for the error. However, this can take a long time. For a faster solution, head to a nearby Apple Store and get help from them immediately.
We have provided a complete guide on how to remove the AKAuthenticationError 7005. There are twelve solutions at your disposal that are effective and also easy to follow. However, they may only work for some device types.
You don’t need to go through them all to find the best fix. Use AnyFix for a one-click solution to resolve this error once and for all. It is easy to use and helps you regain control of your device one quick fix at a time!
