Generally, Find My iPhone should always update your location without your consent. However, if it fails to, then there must be something wrong. Join us as we walk you through the reasons why Find My iPhone isn’t updating your location and how to fix the problem without hassles.
Location sharing is now a thing among iOS users since the integration of location services feature into iPhones and iPads. You can now send your current position to friends and families to keep them abreast about where you are without having to write a detailed guide.
The location services feature works with all GPS-based apps that you have on your iPhone including Find My iPhone. It keeps your location information updated from time to time so whoever you are sharing your location with isn’t misled.
However, for some reasons, Find My might fail to update your GPS location. If this is a problem you are dealing with right now and looking for a comprehensive guide that covers how to fix it, you are on the right page. Prior to discussing the solutions, let’s begin with the reasons why Find My iPhone isn’t updating your location.
Some of the reasons why Find My iPhone isn’t updating your GPS data is shared down here:
Having discussed the reasons why Find My iPhone is not updating your location, let’s move into the solutions. The troubleshooting techniques below are some of the handy solutions you can use the fix the issue whenever you notice it on your iPhone:
Performing a system restart is the first thing to do when you experience something like on your iPhone. This solution lets you refresh your device by wiping all bugs and glitches that are causing Find My iPhone not to update your location. In fact, the RAM is also cleared in this process so your device can run at optimal level.
Restating an iPhone is extremely easy but the procedure differs for the different iPhone models. Use the guide that suits your phone model from the procedures below:
iPhone X/11 and Later Models
iPhone 6/7/8/SE (2nd Generation)
iPhone 5/1st and Earlier Models
Restart Your iPhone When Your iPhone Not Updating Location
If the aforementioned solution fails to fix the problem on your device, then you should check if Find My and iCloud are enabled on your iPhone. The Find My and iCloud feature must be active before location services can share your real-time GPS with it. Failure to do so can cause the underlying issue.
Here’s the simple guide to confirm if Find My and iCloud are both enabled via Settings:
Note: When the icon beside the Find My iPhone feature turns green, then you’ve successfully enabled it.
The location services feature is paramount when dealing with any GPS related operation on an iPhone. If the feature is turned off, your real-time location won’t be available on any app or platform using your GPS and Find My iPhone isn’t left out.
With this in mind, we strongly suggest that you enable location services on the device so Find My iPhone can continue updating your location. Below we have the quick guide on how to get this done:
Enable Location Services on iPhone
Once done, try checking if Find My iPhone has started updating your location.
Another stress-free solution to fix Find My iPhone not updating location is checking your network connection. Sometimes your internet connection may be down and the underlying issue will happen.
To check your iPhone network connection, we suggest you apply the following tips:
Check iPhone Network Connection
Updating your device to the latest iOS can also fix Find My iPhone not updating my location issues. This solution removes all bugs and errors that are responsible for the problem you are facing by replacing the previous version with a newer one.
Follow this quick guide to update your iOS to the most recent one:
Update to The Latest iOS Version
Are you still experiencing the same issue on your iPhone? If so, then the system might be corrupt and need repair. You need a professional iOS system repair tool like AnyFix to come to your rescue in this case.
AnyFix is a powerful tool that can repair all iOS issues with a few clicks. To put it simply, AnyFix is a tool that can provide the final solution for resolving numerous iOS device difficulties without causing data loss. It is a very complex iOS repair solution that powers the mind-blowing features needed to save your iPhone from over 150+ faults without sacrificing its integrity. You can also use it to resolve Find My iPhone not updating location.
Step 1. Freely Download AnyFix and connect iPhone with the USB cable > Once the interface is below, click the System Repair mode and click on Repair Now.
AnyFix System Repair Option
Step 2. Choose Update Issues and the click the Start Now button.
AnyFix System Repair Update Issues
Step 3. Then choose the repair mode. You can try Standard Repair first.
AnyFix Standard Repair
Step 4. Click the Download button to download the firmware for your iPhone. Then click Start Standard Repair to start repairing. Minutes later, you’ll see iOS repairing completed page.
Repair Is Completed
Hopefully, fixing Find My iPhone not updating location can be fixed using any of the solutions recommended in this post. We discussed the reasons why you are experiencing this and the best ways to fix it. All the recommended solutions are free and simple to implement.
However, the most trusted approach is the one involving the AnyFix iOS repair tool. The software packs everything needed to restore operations to normal on an iPhone or iPad. Download, install and try AnyFix out!
