What to do when you meet connect server failed issue? Fortunately, you can get 9 different ways to fix it in this in-depth article. Among these methods, we offer you a special solution that not only solves the connect server failed problem, but also solves other iOS and Android problems
You are trying to log in to your mail and the error pop-ups telling you that “Cannot Get Mail – The connection to the server failed“. Don’t you worry! because we have a solution for you. In this article, you will not only get to know why the connection to the server fails but also how you can avoid them in the future. To solve the connect server failed problem, we will need to understand it first.
If you want a quick and guaranteed 90% chance of fixing the problem, then you better use iPhone repair software. Among the iOS system repair software available in the market, AnyFix is highly recommended. It is designed to get iPhone/iPad users out of software problems and data loss dilemmas. So, it allows you to repair iOS and fix various iPhone problems, including connect server failed issue, stuck on factory reset, iPhone black screen, attempting data recovery cannot be completed, etc. Supports all iOS versions and iPhone/iPad models. Follow below steps to fix iPhone connect server failed issue.
Step 1. Free download, install, and run AnyFix on your computer. From the home page window, select System Repair.
AnyFix System Repair Option
Step 2. Connect the iPhone to your computer and select the App Issues from the program window. Then click on the Start Now button to proceed.
AnyFix System Repair App Issues
Step 3. Choose the Standard Repair option from the program window and follow the screen instructions to put your iPhone into recovery mode.
AnyFix Standard Repair
Step 4. Confirm the device information and click on the Download button to download the device firmware package.
Click Download to Add a Firmware
Step 5. Click on the Fix Now button to start the repair process. Wait till the process finishes and make sure that the device stays connected to your computer.
Repair Is Completed
You may have a problem with the server directly, but it could be your internet connection in most cases. Your wifi router or Mobile data can sometimes hinder your login details and stop you from connecting to the internet.
Every device perceives data differently, so it is expected it has its capabilities for connecting to the network. It is said that whenever a problem arises, look for the simplest explanation. And most of the time, it is the solution.
So, the first thing you will be required to do when presented with the server connection failure is to look at your Network device simply.
Try applying the following fixes and check if the problem is resolved.
Restart Wi-Fi Router
Note: before pressing the button to restart the router, it’s advised to wait for at least 2-3 minutes.
Another of the simplest solutions to the server connection issue is restarting your phone.
Follow the following steps if you encounter this issue on your iPhone:
iPhone Re-enter Your Mail Account
Sometimes changing the sync time on your iOS device will help you resolve server connectivity issues. And please note this option is only available for iOS 8 to iOS 13.
Follow the steps mentioned below.
Change the Mail Days to Sync Option on iPhone
It might seem trivial. But region, date, and time can affect your server connectivity. It is one of the most commonly ignored issues. Date and time settings can change in the following conditions.
Follow the steps below to ensure the date and time are properly synced.
Turn off Automatically Date&Time
Now, this is a Tech expert process. Here the user will need to change the server settings manually from the phone. So if you are an experienced user. Follow the steps mentioned below.
Enter Info and Password
A firewall is one of the features that can disturb your syncing with the mail and cause issues such as “Connect server failed.” The firewall in android and especially iOS devices cannot be disabled. It could be possible if you have administrative access to your phone. But the general audience does not have a simple way of disabling the firewall.
Although there could be another alternative that is disrupting your access to the server.
Note: This fix works with both iPhone and Android.
Disable Firewall on iPhone or Android
The server connectivity issue can bugger you a lot. You may keep thinking How do I fix email not connecting to the server? You may have tried many ways, but what if there was a simpler method? And that method would be to change your password. You may have logged in from the same email to any other internet site. This puts you at risk for data theft. Also, if your account is active on another device, it can disrupt your data connectivity. To solve this.
Change the Apple ID password on your iPhone
The mobile phone world is so reliable that we forget to notice how far we humans have come technologically. This technology is helping the world in numerous ways. But there are errors, and then there are fixes. Following the steps mentioned above, you will be able to fix the Connect server issue in no time. However, of all the solutions, we recommend using AnyFix, as it not only solves the Connect Server Failed problem, but also other problems related to iOS.
