Why Cash App Unable to Sign in on This Device? How to Fix?
Are you seeing the Cash App unable to sign in on this device error? This article offers practical ways to fix it. We will explain why you’re getting this error message and how to fix it in five easy ways. No matter if you’re an iPhone or Android user we’ve got the solutions curated to your needs.
Author Avatar Joy Taylor Last Updated: Jul. 08, 2024
Are you dealing with the ‘Cash App unable to sign in on this device’ error? Well, you are not alone. Various Cash App users have been facing this issue when trying to log in to the app. While this unexpected error may cause distress, don’t worry about it. There are various effective ways to fix it and reaccess your Cash App account.
That being said, this article will get to the root of the Cash App sign-in error. We will also introduce the best ways to resolve this issue once and for all. So are you ready to rid of the sign-in error in the Cash App? Let’s get started!
Why Is the Cash App Unable to Sign in on This Device
Cash App is a handy app to send and receive money for both iOS and Android users. But, recently several Cash App users have been anxious about being unable to sign in to the app. Let’s quickly gauge the causes behind this error before we talk about how to fix them.
  • Unstable Internet Connection: Slow and unstable connections are unable to provide enough resources to ensure the smooth running of the app.
  • Incorrect ID or Password: Another reason can be using incorrect login credentials to sign in on the Cash App. If your ID or password does not match up, the Cash App will not be able to sign you in.
  • Log in from Multiple Devices: Using multiple devices with the Cash App without logging out, can compromise your account security. Hence, the Cash App may restrict you from signing in.
  • Outdated Cash App: Apps are updated to fix the bugs in the older versions and improve their features. An outdated Cash App can malfunction and result in sign-in errors.
Grasping all the factors behind the Cash App’s unable to sign in error, let’s move forward and find out how to fix it.
How to Fix Cash App Unable to Sign in on This Device
Despite the reasons holding you back from accessing your Cash App account, there are ways around it. Below we have assembled some essential ways to fix the Cash App unable to sign in on this device error. So, let’s get right to these.
Way 1. Use a Stable Network
If you are using an internet connection with significantly fewer Mbps, connecting to a faster internet can fix the issue. Plus, using unknown public networks puts your device’s security at risk. Your data becomes vulnerable to attack resulting in loss of private information. This can lead to the Cash App cutting down your access to your account.
But, this can be easily resolved by establishing a stable network connection with your phone. Read on below to find out how to achieve this. Here are the steps to connect an Android or iPhone to a stable network.
Step 1. Access your iPhone’s “Settings” and tap “WiFi” to access the internet settings.
Step 2. Connect to your home network or “Local Network” if it is available.
Step 3. Switch to Cellular Data If you do not have a private connection. Access it by heading to “Settings.” Choose “Cellular” and turn on “Cellular Data.”
Turn off Cellular Data on iPhone
Turn on Cellular Data on iPhone
Step 4. For Android, go to the “Settings” app. Then, choose “Connections” and press “WiFi.”
Step 5. Turn on the toggle for WiFi if you have access to your home wifi. Otherwise, connect to the cellular data.
Step 6. Tap on “Data usage” under “Connections” to turn on your Android’s cellular data. Press on the Toggle for “Mobile data” to turn it on.
Once you are done, sign in to the Cash App again. This would resolve the ‘Cash App unable to sign in on this device’ error. However, if that’s not the case, you can try our next fix.
Way 2. Log out from Other Devices
Have you ever accessed your Cash App account using different devices without logging out? If so, then it is another reason for the sign-in problems with the Cash App. The app is simply trying to keep your data safe if it is accessible through multiple devices. So, logging out from all the devices should fix the issue for you. Let’s explore the steps to do it below.
Step 1. Click on your profile icon to access your Cash App account settings.
Step 2. Scroll down and tap on “Privacy & Security.” Then tap on the “Change Cash PIN” button.
Turn off Content & Privacy Restrictions
Click Content & Privacy Restrictions
Step 3. Type in your old PIN. Then set a new PIN code and retype to confirm it. This will sign you out from all other devices.
On some versions of Cash App, you can access the “Sign out all other devices” option under Privacy and Security. Simply tap this option to sign out of all the other devices.
Way 3. Update Cash App
You can easily resolve the Cash App’s “unable to sign in on this device” error by updating to the most recent version. This strategy is especially useful if you have the automatic updates for your apps turned off. You can check for the updates on the App Store or Google Play as per your device.
Here are the steps to update the Cash App on both Android and iPhone.
Step 1. Open the “App Store” on your iPhone device and type in “Cash App” in the search bar.
Step 2. Select Cash App from the search results and look for the “Update” option next to it.
Step 3. Tap on the “Update” button to get the latest Cash App update.
Step 4. Once the update is installed, head back to your Cash App and log in.
Android users can follow the same steps by searching for Cash App in the Google Play Store. This should easily resolve the Cash App unable to sign in on this device error. However, if you do not see any pending updates, you can use the next method to fix this error.
Way 4. Close Running Apps
Sometimes, too many apps in the background can slow down the performance of your device. The best workaround for this is to close all the running apps whether you’re using an Android or iPhone. The process of doing this is different for different platforms and devices.
Read through the following instructions to close the background apps on your device.
Step 1. On your iPhone’s Home Screen, swipe up from the bottom. Stop in the middle while still pressing to see all the background apps.
Step 2. Slide to the side to find the apps to close. Then swipe up to close the chosen app.
Step 3. For Android, tap on the three vertical lines near the bottom left on the Home Screen.
Step 4. Tap on “Close all” to turn off all the running apps at once.
Now, open the Cash App, and sign in again. You will be able to access your account without much trouble now. However, the problem may persist for iOS devices. But, don’t worry. Below we have a sure fix to solve the Cash App unable to sign in on this device error once and for all.
Way 5. Repair System without Data Loss
The iOS system can interfere with the apps’ performance for more than a few reasons. You can restart your device or manually try to fix the system. However, it is associated with high risks of data loss during the process. AnyFix – iOS System Recovery is an efficient iOS system repair tool for situations like these. It can tackle over 150 different types of glitches with your iOS system in clicks, including black screen, stuck on Apple logo, boot loop, etc.
No matter the reason behind the Cash App’s unable to sign in on this device error. AnyFix will have the app up and running in no time. Plus, it gives you the power to preserve your iPhone’s data during the process. Let’s find out how to use this powerful tool to sign in to Cash App successfully.
First, download and install AnyFix on your Windows or Mac. Then use the following easy steps to fix the iOS system.
Step 1. Open AnyFix on your PC. Select the System Repair tool and click on the Repair Now button.
AnyFix System Repair Option
Step 2. Connect your iPhone to the computer. Once it is detected by AnyFix, click on the Start Now button.
AnyFix System Repair Device Bug
Step 3. Select the repair level from the three levels available. Select the Standard Repair mode if you want to keep your iPhone’s data.
AnyFix Standard Repair
Step 4. Next, Anyfix will quickly search for a suitable firmware for your iPhone to fix its system. Click on Download once done to download the firmware for your iPhone.
Step 5. After the firmware is successfully downloaded, click on Start Standard Repair to initiate the process to fix the iOS system.
Step 6. A Repair Completed window will show up on your screen indicating the completion of the repair. Click OK to close the window.
Repair Is Completed
Repair Is Completed
So, there you have it! A simple and quick way to fix all the glitches with your iOS system. Now, go back to Cash App and sign in. You won’t have any issues signing in this time.
Now, let’s move forward and find out how to access your Cash App account when switching to a new phone.
How Do I Log into My Cash App on My New Phone?
Have you switched to a new phone? If so, you must wonder how to access your Cash App account on the new device. It is a simple process.
Just recheck the email or phone number associated with your old account. This is because the Cash App will verify your identity by sending you a code on your account ID before letting you transfer to the new phone.
Read through the following instructions to log into Cash App on your new device.
Step 1. Open the Cash App on your new device. Enter the “Email ID or Phone number” associated with your Cash App account.
Step 2. Press “Next” and the Cash App will send a verification code to your email or phone number.
Step 3. Copy and paste or type in the code in the required field and tap on “Next.”
Step 4. Enter your debit card details and tap on “Link Card” or you can skip it if you wish to.
That’s all! Now you are successfully logged in to your Cash App account on the new device.
Cash App offers an easy and secure way to handle your online transactions. So, when an error message displays ‘Cash App unable to sign in on this device’, that can be vexing. But you don’t have to get distressed with our full guide on fixing this error. Go ahead. Give these fixes a try and find the solution that works best for you. All the methods offer promising solutions. But among all, AnyFix will do the job once and for all without any intricate steps. It is fast and efficient, providing iOS solutions just a few clicks away!
