How to Fix Unable to Load Photo on iPhone
If you cannot load your photos on iPhone, you have come to the right spot. Here we will show you several easy methods to fix the cannot load photo iPhone issue.
Author Avatar Joy Taylor Last Updated: Dec. 20, 2024
PhoneRescue for iOS – Fix Photo Load Issue Without Data Loss
Free download PhoneRescue for iOS to fix unable to load photo error on iPhone with ease. PhoneRescue can help you fix the photo load issue with a few clicks. No viruses and malware, no data loss.
Being unable to load photos on an iPhone is a common issue for users. This issue can happen for several reasons, such as iCloud photos not syncing, not having enough storage, slow network connections, or software glitches. Unable to load photo error is not a big trouble, but it is still frustrating when you try to view photos or find important information on them. Fortunately, this article covers 6 effective solutions of how to fix unable to load photos on iPhone. Let’s start now!
Method 1. Force Quit
Like any other smartphone, iPhone apps crash too. And like any other app, the gallery app is not an exception. It might be a temporary gallery issue if you can’t load your photos. To fix this issue, force-quit and reopen the app.
Here are steps to force quit an App:
Step 1. Double-click the Home Button (for iPhones with a physical home button) or Swipe Up from the Bottom of the Screen and pause (for iPhones without a Home button).
Step 2. Find the Photos App: Swipe left or right to find the Photos app that is having trouble loading.
Step 3Swipe Up on the Photos App: Swipe the app’s preview of the screen to close it. This will force the app to quit.
Step 4Reopen the Photos App: After closing the app, go back to the Home screen and open the Photos app again. Check if the photos now load properly.
Method 2. Delete and Recover the Photo
iPhone users will experience an ‘unable to load picture’ error if they try to open a specific picture file. It might be a result of a broken or incomplete download. If this happens, you will have to delete the Photo and recover it from iCloud.
Step 1. To delete, long press and tap the small trash can at the bottom right side of the screen.
Step 2. To recover a deleted picture, click ‘Albums’ at the bottom-right > Drag down and tap ‘Recently Deleted.’
Step 3. After finding the deleted Photo, touch & hold, and tap ‘Recover.’
Choose Recently Deleted and Click Recover
Method 3. Check Your iPhone & iCloud Storage
If you are still experiencing the same error, you should check how much space you have left on your iPhone. When you are using something other than iCloud+, this can happen. If you use iCloud to sync all your photos, you may have used up your 5GB of free storage. To check your iPhone storage:
Step 1. Open ‘Settings’ on your iPhone> Find and click ‘General.
Step 2. Then click ‘iPhone Storage’ on the screen to check the iPhone storage.
Check iPhone Storage
On top, you’ll see your remaining storage. Your iPhone storage bar is full and you should free up the space. You may need to delete all photos on your iCloud account. After that, log back into iCloud and reinstall all of your photos.
Method 4. Fix iOS System Issues
If all methods mentioned above cannot solve your problem, your iOS system might fail. It is very necessary to clear the errors in the system. Considering the hassle and time-consuming to seek help from Apple technicians, you have a better choice – PhoneRescue for iOS. As a professional iOS system repair tool, PhoneRescue can fix the “unable to load photos” error effortlessly. Its high success rate and fast repair process make this tool stand out from competitors. Thanks to the easy steps and intuitive interfaces, you can fix your photo issues with a few clicks. PhoneRescue for iOS can also solve other problems, including recovering deleted photos, fixing frozen iPhones, etc.
Main Benefits of PhoneRescue for iOS:
  • Fixing the inability to load photos on iPhone without data loss.
  • Simple and fast beyond imagination, fix system issues within minutes.
  • Safe system repair process without viruses and malware.
  • Allowing users to fix almost all iOS system issues, including blue screen, reboot loop, etc.
Here are steps to fix unable to load photo iPhone with PhoneRescue for iOS:
Step 1. Launch PhoneRescue on your Windows or Mac computer. Then choose the Repair iOS System option in the Device Rescuer panel.
Click Device Rescuer and Choose Repair iOS System
Step 2. Connect your iPhone to your computer. Then choose Advanced Mode first.
Choose Advanced Mode
Step 3. Then it will ask you to put your device into recovery mode. The detailed guide will be shown on the screen, just follow it.
Enter Recovery Mode
Enter Recovery Mode
Step 4. Click Download to get the corresponding firmware for your iPhone. Remember to check the device information first.
Click Download to Get Firmware
Step 5. After that, it will start to fix system errors. Please wait for a while and you will get a message telling you that the repair is completed.
iOS Repairing Completed
Method 5. Turn off the Power Saver
If you turn on the low power mode on your iPhone, you might decrease its performance. Apple says using the iPhone’s low-power mode may affect your iPhone’s functionalities and slow it down. This may also include the pausing of iCloud Photos. So try turning off the power saver to remove the ‘cannot load photo’ iPhone error as the following steps.
To deactivate low power mode, open Settings > Battery > Toggle off Low Power Mode.
Method 6. Update Your iOS Version
Are you still encountering the ‘unable to load photos’ error? This may be because your iOS device needs to be updated to the latest operating system. Some apps that you download might conflict with another program. Therefore, your device may need to be compatible with the new version of your photo library. To do that, follow the steps:
Step 1. Go to the Settings app on your device, and then you can see several options, just select General.
Step 2. After that, scroll down and click on Software Update. And tap on the Automatic Updates option.
Update iOS on Your iPhone
Tap on Automatic Updates
Step 3. Now you have to turn on ‘Download iOS updates.’ Lastly, turn on ‘Install iOS Updates. Just like your iPhone will be able to update to the latest version of iOS automatically.
FAQ about Unable to Load Photo iPhone
Q1: Cannot Load Photos after the iOS Update?
If the unable to load photo error message still appears after trying all recommended fixes, it’s time to contact Apple Support. You just need to send an email to the support team. They’ll guide you through the steps you can take for a permanent fix.
Q2: Fix Unable to Load Photo Having Full Storage
If you have used all your iPhone storage, then you can use your free 5GB iCloud storage. If you have also used your iCloud storage, then you need to delete some extra images/videos that you no longer need. You can also upgrade to iCloud+ if you want more storage. Upgrading to iCloud+ may also remove the error.
Q3: Why does it say unable to load photo on iPhone?
The “Unable to Load Photo” error on an iPhone can happen for several reasons. It may occur if the photo is stored in iCloud and the device has trouble syncing or loading it. It can also happen if there isn’t enough storage on the iPhone, or if the photo file is corrupted. A poor Wi-Fi connection or software glitches can also prevent photos from loading properly. In some cases, outdated iOS versions might cause this issue as well.
In this article, we mentioned 6 easy methods to fix photo load issues. Following the steps above, you can easily resolve the annoying mistake. If the basic solution cannot solve your problem, PhoneRescue would be a good choice for the high success rate in fixing the inability to load photos on your iPhone. With the user-friendly steps, no technical skills are required to fix the photo load error. Free download PhoneRescue now!
