Whether you find a blurry square on your iPhone screen after an update, or other reasons, you can fix it within the snap of a finger using the guide provided in this post. We’ve outlined four (4) powerful solutions and an ultimate repair tool to resolve blurry square issues on any iPhone.
Hi. Unfortunately, my iPhone 12 Pro Max showed a blurry square at the top left corner of the display screen a few days after updating to iOS 14. I’ve tried some tweaks like restarting it but all effort was futile. Please, is there anyone who has an idea on how to fix this?
If the scenario above sounds familiar, you aren’t alone. Several iOS users have lodged complaints about the sudden appearance of blurry square/rectangle at the upper left corner of their screen for unknown reasons. While the situation is no fun, finding the solution is crucial.
There are several ways to fix blurry squares on an iPhone right from the comfort of your home at a zero cost fee. Here, we will discuss these solutions. However, before delving into them, let’s discuss the reasons for the blurry squares.
Apple smartphones are one of the best mobile devices available in the global market. These devices are well-designed with all physical components intact. Your iPhone shouldn’t show a blurry square at the top of its screen unless the following issues arise:
Having discussed the various reasons why you may encounter a blurry square on an iPhone screen, let’s move a step further into the solutions.
Fix the blurry square on your iPhone screen without stress using any of the solutions given down here:
When you come across the blurry square on your iOS display, the first solution you need to implement is force restarting. This solution repairs nearly all issues you encounter on an iDevice. It works by clearing the bugs, and temporal glitches that might be disrupting your device’s operation.
Force restarting is very simple to employ as it involves turning on and off your device. Also, it’s free to implement. Apply the appropriate procedure for your iPhone mode to force restart your it so you can get rid of the blurry square appearing on your screen.
iPhone 8/X/11/12/13/14 series and SE (2nd and 3rd Generation)
iPhone 7/7S
iPhone SE (1st Generation)/6/6S and Earlier Generations
Restart Different Modes of iPhone
Undoubtedly, the operating system of an iDevice is an essential component that plays a crucial role in its performance. And for this reason, Apple schedules a regular update regularly, which you must download. Failure to install the update often results in phone malfunctioning causing blurry squares to appear.
To clear this blurry square issue, we recommend that you update your iOS. Follow these directions to do that:
Update iOS to the Latest Version
Your phone will download the update, and will automatically go off to install it. Be patient for the installation to complete, then check your device for the blurry square. It should be gone.
Ever tampered with your iDevice’s display settings? If so, chances are that you will encounter the blurry square issue. You can resolve this by editing the features underneath your iDevice display settings menu.
Here are the instructions you need to do that:
Decrease Brightness on Your iPhone
Still seeing the blurry square on your phone screen after implementing the aforementioned solutions? Try resetting it to factory settings. By doing that, you get the chance to reset previous changes/customizations you made to your iPhone.
Apply the instructions below to reset your iDevice to factory settings:
Choose Erase All Content and Settings
Lastly, we have the use of an iOS repair tool to fix the blurry square screen on your iPhone. There are lots of this tool on the net, but the majority of them perform woefully. AnyFix is the only tool tested and trusted by experts to fix blurry screens.
It is an incredible software program committed to fixing/repairing iOS related issues. With this program, you can easily fix more than 130 issues on an iDevice without losing data. Moreover, you can also use it to clear iTunes errors on your iPhone.
Now, follow the steps below to fix the iPhone camera shaking problem.
Step 1. Go to the AnyFix website and get the newest AnyFix > Connect your iPhone to the computer > Choose the System Repair function on the top of the page.
Choose the System Repair Function
Step 2. Click the 50+ iPhone Problems button > Tap on Start Now to the next step.
Select 50+ iPhone Problems and Click Start Now
Step 3. Here are listing 3 modes for you to repair your iPhone. In most cases, the Standard Repair mode can solve your problem. If not, try the other two modes.
Choose One Repair Mode
Step 4. All you need to do is to wait for a while. Once the repair journey is finished, you will see the Repair Completed message on the screen.
Repair is Completed
Flickering or glitching isn’t a new thing on iPhones. Reports from experts suggest that the issue could be as a result of bug attack, damaged firmware, or virus attack. It can also be caused by a broken screen when your device falls/hits on a hard surface.
Regardless of the cause of the glitch, you can fix it using AnyFix, except for the case of broken screen. A damaged screen would require replacement by an experienced engineer.
Whether you just got your iDevice or have been using it for a while, you can improve the screen quality easily and quickly. All you need is to adjust the display and brightness settings to suit your viewing. To do that, open Settings > Display & Brightness. Move the brightness slider right or left till you get the quality you desire. You can also try to turn on/off the light or dark mode feature too, and your screen will adjust accordingly.
Alas, you can now fix the blurry square issue you are experiencing on your iDevice. Each of the solutions provided are free and easy to employ. Apply one or all to get rid of blurry screen without stress. However, we recommend the use of AnyFix to quickly fix the issue. The software repairs blurry screens without compromising users’ data.
