Want to find an excellent tool to install the .ipsw files? Follow this post to get the top 4 .ipsw install tools to help you easily fix the iPhone/iPad/iPod, etc. upgrade and downgrade issues.
Free download AnyFix to 1-click fix 130+ iOS errors, including installing IPSW without iTunes.
Files with the .ipsw file extension are the files of Apple products like iPhone, iPad, iPod, and iTunes for restoring, downgrading, or updating the new iOS version. Sometimes, you may fail to update the iOS or encounter the iOS updating error due to the corrupted .ipsw file. On the other hand, you may find the upgraded iOS version is not as comfortable as the one that is not upgraded. Therefore, you might prefer to use the oldest version.
It is easy to find solutions online in terms of how to upgrade the iOS for we always talk about it. However, there is little information and solutions available for downgrading iOS. Then what should we do to tackle this problem? Here, we must mention the .ipsw files which can help us a lot. Anyway, follow this article to get the top 4 .ipsw files installation tools to upgrade or downgrade the iOS at ease.
AnyFix is a professional iOS system repair tool that enables you to fix various Apple products’ issues including updating or downgrading iOS with several simple clicks. It can fix iOS system problems as iPhone stuck on verifying update, iPhone stuck on update screen, iPhone stuck on preparing update, iPhone won’t update, etc.
Besides, AnyFix can also fix errors related to iTunes. For instance, iPhone won’t update on iTunes, iTunes could not back up the iPhone, iTunes could not connect to this iPhone, iPhone not showing up in iTunes, etc. can all be fixed by AnyFix. Check some of its main features below.
Follow the below step-by-step guidance on how to downgrade iOS via AnyFix.
Step 1: Download and launch AnyFix on your PC > choose the Upgrade/Downgrade iOS option at the bottom of the software’s interface.
AnyFix Upgrade/Downgrade iOS Option
Step 2: Connect your iOS device to AnyFix > select 1 click to downgrade iOS/iPadOS option on the right side of the interface > click the Start Now button at the bottom of the interface.
AnyFix Downgrade iOS
Step 3: AnyFix will automatically analyze the firmware packages that are lower than the newest iOS version. After the firmware packages available are presented on the software’s interface, choose the .ipsw file package you prefer > click the Downgrade button to start the downgrading process.
Step 4: After you finished step 3, AnyFix will automatically start its downgrading process. You just need to wait for a moment until the Downgrade Completed interface shows.
Downgrade Completed Page
iMyFone Fixppo is also one of the .ipsw files installation tools. It can help the users to install the .ipsw files in a convenient and easy-to-use way.
Pros:
Cons:
iMyFone Fixppo
U.Fone iOS Toolkit tool is a tool I’d like to recommend as well. It can be regarded as one of the best alternatives for IPSW file install tools in 2020. Below are the detailed pros and cons of it.
Pros:
Cons:
U.Fone iOS Toolkit
TinyUmbrella tool is the software that allows you to downgrade the iOS to the previous version with simple steps. In addition to that, it also has some limitations. I will brief you on its pros and cons as follows.
Pros:
Cons:
TinyUmbrella
If you would like to install the .ipsw files on your iPhone/iPad/iPod, etc. so as to upgrade or downgrade the operating system, the above-mentioned top 4 IPSW install tools in 2020 can be the best choice. Personally speaking, if you prefer a user-friendly and easy-to-operate tool with various features, AnyFix would be the best one for you. You can download AnyFix and give it a try!
