“I noticed this a few weeks ago and it’s frustrating because I need to go back and look for the password to add it manually. ”
Is autofill not working on iPhone?Stuck with the issue can be frustrating. But take it easy, this page will walk you through the possible causes and six easy ways to solve this issue quickly. We’ve got covered from simple settings to try tools like Anyfix to handle the problem with one click.
Anyway, there must be one perfect for you! Let’s explore how to fix autofill malfunction on iPhone in this detailed guide:
If autofill is not working on your iPhone, the first step should be to check what has caused this issue. Then you can get the right way quickly. Below are some possible reasons for this problem:
No matter what causes this issue, we have according fixes to get Autofill to work again. Following we provide you with six simple and user-friendly ways. Can’t wait anymore? Let’s go to check!
Having explored various potential causes for why Autofill doesn’t work, maybe you have had your own judgment about why your Autofill doesn’t work. Then follow this detailed guide to help you find the one that fits your needs best, take action, and make it.
The Autofill malfunction error may happen when you don’t set up the Autofill feature correctly. So go to the settings, check it, and turn on the Autofill feature.
It can be done easily. Here are the steps for it.
Steps to Enable Autofill on iPhone
Step 1. Open Settings, then click on Passwords & Accounts or Passwords, which depends on your iOS version.
Step 2. Next, hit Passwords Options.
Step 3. Then tap the “AutoFill Passwords” icon again to turn it on. It should turn green now. You may be prompted to use your iPhone password or Touch/Face ID for verification.
Step 4. Finally, below the toggle, you can choose where Filling from, iCloud keychain, or 1Password if installed. Remember to select “iCloud passwords & Keychain” in SET UP VERIFICATION USING.
Now, you may have enabled your Autofill, so open any app or website to check whether it works. If not, don’t lose heart, Let’s see another effective method!
The most simple and direct way is to restart your iPhone. In many cases, people choose this method. Definitely, it is useful most times. Follow the steps to restart your iPhone(this depends on your iPhone model, taking iPhone 8 and later models as an example):
Steps to force restart your iPhone
Step1. First, press and quickly release the volume up button on your iPhone.
Step2. The second step is to press and quickly release the volume down button.
Step3. Next, press and hold the side button.
Step4. Now, release the side button as the Apple logo appears.
Step5. Wait for it to restart your iPhone completely, then check whether the Autofill is working.
Does it work? This should help you resolve some random bugs and glitches with iOS system. However, it doesn’t work all the time, so keep going to see other ways.
Apps sometimes may not be compatible with your iOS system, so it is a must to have a look at them when Autofill doesn’t work for a particular app or website. There are several easy steps for you to follow:
Steps to check app compatibility
Step 1. Open Settings.
Step 2. Type on Gneral>About>Applications.
Step 3. Enter into the APP Compatiblility page.
Step 4. Check the “No Updates Available” section and you can know which app is not compatible with your iPhone. Click the app for more information.
Step 5. Download the suitable version of iOS or update your app. In general, the latest version is always the best.
By following these steps, whether the app is compatible with your iOS system is very obvious. However, if it is, there must be something wrong with other aspects such as outdated iCloud Keychain. Let’s see how to fix it.
iCloud Keychain is used to store your user names or passwords, so issues with syncing or outdated information in the iCloud Keychain may lead to Autofill not working. Here are some steps for you to have a look at it:
Steps to check iCloud Keychain
Step 1. Tap on Settings and then hit your name or Apple ID profile picture to access your Apple ID settings.
Step 2. Click “iCloud” > “ Keychain” > “iCloud Keychain”.
Step 3. Toggle the switch next to “iCloud Keychain” and turn it on. You may need to enter your iPhone password for verification. Then tap on “Advanced” to view saved passwords and websites.
Step 4. Turn on “Sync this iPhone“. Make sure iCloud Keychain is enabled on all devices to sync passwords and other secure information.
Through the process, you can enable your iCloud Keychain to be sync.
If you have tried each of the above solutions and they still don’t work, you may have to factory reset your iPhone. However, this way will erase all your data, which makes it the last resort. So remember to transfer and store your data first before you do that.
Steps to factory reset iPhone
The following steps will help you reset your iPhone effortlessly.
Step 1. First, go to Settings and hit the General option.
Step 2. Secondly, click on the Reset option and proceed.
Step 3. Select Reset All Settings. Enter your passcode for verification if prompted. After completely resetting your iPhone, check whether Autofill works.
Considering factory resetting iPhone will lead to data loss, it is the last resort. If you are unwilling to transfer and store your data before you reset your iPhone, below is a better way for you.
Can’t bother to recover your data before resetting your iPhone? Still stuck in Autofill malfunction? You may think there is no perfect way for you to fix this issue.
But don’t lose heart, a specialized iOS system repair tool can help you. AnyFix is an advanced system repair tool that removes all the issues with your iOS system, such as WiFi not working on iPhone, iPhone screen not working, iPhone won’t turn off, and so on. With the standard repair option, you can fix your iOS system without erasing your data!
Interested? Come and experience hassle-free troubleshooting with just a few clicks and get back a nicely working Apple device in minutes.
Let’s see how to use AnyFix to get past the Autofill malfunction error in several simple steps.
Below are the steps.
Step 1. First of all, download and install AnyFix on your computer.
Step 2. Launch AnyFix and choose the System Repair mode. Then choose the Device Bug mode and click Start Now to keep on.
Step 3. Next, select Standard Repair.
Step 4. Download Firmware Package for your iOS device.
Step 5. Click the Start Standard Repair button to repair your iOS system issues instantly and easily. Now, AnyFix will start repairing your iPhone. Don’t disconnect your device until it restarts. Once the repair process is completed, click “OK.”
You’ve seen how simple it is to fix an iOS system using AnyFix.
So far, we have discussed six practical methods to fix Autofill malfunction errors, let’s conclude them.
With this detailed guide, you now must have learned more about the causes and solutions for autofill not working on iPhone.From enabling the Autofill feature, and restarting your iPhone to using an advanced iOS system repair tool AnyFix, there are specific steps for you to follow. Specifically, if you want a versatile iOS repair tool, AnyFix is recommended for it can fix 150+ iOS system issues.
Go ahead and use these methods to get your Autofill back in action!
