Are you confused about the Apple watch black screen of death issue? You are facing this problem in your Apple watch but you don’t know what to do? Then read this article to solve Apple Watch black screen of death easily.
“My Apple Watch got into black screen and I can’t do anything to turn it on. I don’t know suddenly what happened so I’m really worried about it. Can someone help me to know how I can fix it?”
On the introduction of technology and gadgets, the majority of our day’s productive tasks and businesses are carried on these fancy yet valuable pieces of the gadgets. Since we all are familiar, that hardly any particular technology is perfect. Still, our reactions to turn-offs or partial workings have always been unacceptable and frustrating equally. Our situation tends to be like a pen in hand, without sufficient ink.
To brief up, Apple is a well-known and reliable company. They continuously offer us multiple useful gadgets and devices that provide the customer with a promising experience and a decent warranty period. Currently, Apple watches have stood strong and developed a powerful niche in the wearable electronic markets, which are daily increasing steadily. By chance, if you are facing the Apple Watch black screen of death issue, then you need to read this article to its full length and gain some important information to solve it.
There are several reasons why your Apple Watch is stuck on a black screen of death, and almost the majority of the fixations can be performed at ease. Let’s go through some of the prominent reasons why the Apple Watch appears dead or stuck on the black screen –
Apple Watch Black Screen of Death
Charge your Apple Watch by positioning the magnetic charging cable below the Watch. Wait till the chime sound appears, as it reflects the charging state of the Watch. Along with the sound, a lit green Bolt appears on the screen. Leave it for at least 30 minutes for it to get automatically switched on.
If it doesn’t, pay attention to the following helpful tips:
The initial fixation required to solve the stagnant dead battery face is, by connecting to a different charging cable and charger to know whether the battery or something else inside the charger is faulty. Wait for a good 1-2 hours to view any pop-ups. However, if still, the Apple Watch appears unresponsive, observe your charger and try to displace it with other charging cables. Before you decide to move on to another solution, here are some beneficial tips to ponder your attention to –
If you are facing the Apple Watch black screen of death issue, while still there’s some battery left, note that it’s in a frozen state. Doing a forced restart (also called a hard reset) can bring in the Watch’s functionality back. During this stage, there’s a change in the Watch’s operating system, which was an unintentional set previously.
A force restart is performed in a similar way, as with the iPhone or any other Apple device. It involves pressing and holding the side buttons that are the smaller oblong button, and larger, circular digital crown. Do it for 10 to 15 seconds continuously until the Apple logo appears, which indicates the boosting up of the Apple Watch. Conduct it slowly by restarting the device.
It is now expected to operate without any problem. Conducting a force restart doesn’t harm or erase any content or setting on the Apple device.
Only connect to a USB 2.0 or 3.0 port if you are planning to charge your Apple Watch via a computer, otherwise, there are fewer chances of it working. Also, make sure that the laptop or computer is awake during the charging process. Avoid plugging in your device to any external computer parts like the keyboard; it hampers the power transfer to the Watch.
Therefore, connecting the Apple Watch directly to the computer is a prudent option.
The power reserve mode is generally designed to save the power usage of the Apple Watch. Where, the Watch starts acting like a dead device by disabling all its access, features, and internal processes. This makes the apple Watch unable to unlock and halts all the exchanges with the iPhone. Only a bold red blot icon next to the 24-hour clock is visible to the user.
In order to switch off this power-saving mode, hold the long side button, and press it for a fair 8 to 10 seconds. On the popping up of the Apple logo, the Apple Watch is back to its normal mode.
In order to bring back the Apple Watch’s working mode and get rid of the Apple Watch black screen of death, upgrading your device to the latest iOS version might stand helpful. The process involved to upgrade your devices iOS version is as follows –
Step 1: Initially pair up your iPhone with your Apple Watch.
Step 2: On your iPhone, click on My Watch.
Step 3: Continue, by selecting General, where the Software update is mentioned.
Step 4: Type in the present Apple or iPhone password and continue the Download and Installation process with full-fledged Wi-Fi connectivity.
Post the restart episode of the Apple Watch, a dark screen appears once again. There are high chances, that you have accidentally landed on the screen curtain Accessibility mode. Every Apple Watch consists of this additional mode, where the display is disabled if the VoiceOver is used. It decreases the brightness, by making the screen appear darker, even when the functioning is regular. This mode only permits vocal interactions.
For switching off the screen curtain mode, grab your iPhone and slide into the Apple Watch.
Go to the General > click on the Accessibility option > tap on Voiceover and turn off the screen curtain mode.
However if not, contact Apple Support. You can easily reserve a genius bar appointment and get your Apple Watch serviced. Do check your warranty; it can be done by going to the coverage page. If you are within your deadline, you can benefit from its advantage and replace your Apple Watch within no time.
Ideally, it’s not a preferable option, but it may help you to get your Watch running back. As nothing is workable, erasing everything will surely help. Follow these steps after opening the Settings app –
Step 1: Go to the General and hit the Reset.
Step 2: Select Erase All Content and Settings.
Step 3: Enter the passcode.
Step 4: Tap on Erase All to confirm the operation.
After trying numerous fixations listed above in this article and nothing worked out, there’s a probability that there exists a hardware issue. Initially, observe your Apple Watch if anything unusual exists. There may be a likelihood that the screen is stuck on the Apple logo because it’s cracked. After a deep check, if nothing unusual appears, here are some points to infer to –
Hopefully, the provided information caters you to solve the Apple Watch black screen of death issue. If it’s doesn’t, even after some point of time, stop hustling around with all the methodologies and trying hard to fix your Apple Watch. You can
If your iPhone stuck or encountered some issues, you can solve them as quickly as you can with AnyFix – iOS System Recovery which is committing to fixing over 130 iPhone/iPad/iPod/Apple TV system issues. As a professional troubleshooter, you can use AnyFix to get your iTunes back to work normally. And the Apple Watch problems solutions are on its way to us.
AnyFix Overview
Warranty:
Third-party Store:
Second-degree Device Parts:
Hopefully, after reading all these solutions, you must already know how to solve the Apple Watch black screen of death issues easily. All you need to do is follow the solutions from this article in a step-by-step manner. There is nothing else you need to do. Also, we hope that we have provided you with all the information you need. Still, if you think that we might have missed something or you are still facing your problem then let us know in the comment section.
