7 Best Apple Watch Alternatives for iPhone Users
Confused about Apple watch alternatives? If you are looking for the best alternative for Apple watch, then you need to read this article. We have listed 7 best Apple watch alternatives for you here that are pushing their boundaries in the market.
Author Avatar Joy Taylor Last Updated: Jun. 12, 2024
As an iPhone user, if you think that you want to use an alternative to Apple Watch, then you don’t need to worry anymore. With the help of this article, you’ll get to know about the 7 best Apple watch alternatives that are available in the market. So instead of being confused about the best alternative for the Apple Watch, follow this article till the end and we may help you reach a verdict.
There are many Apple watch alternatives available in the market right now! But how would you know which alternative watches are going to be best for you? Below we have assembled 7 best Apple watch alternatives that are really going to give you almost everything you need in a smartwatch.
Samsung Galaxy Watch Active 2
The Samsung Galaxy Watch Active 2 is a great smartwatch with long-lasting battery life and impressive performance. It has a circular display that might attract you comparing to the Apple Watch’s square design. It also has an interesting digital bezel to navigate menus. The fitness features of this smartwatch are similarly good as Apple watches but instead of using Apple Health, users have to use the Samsung Health app for iOS.
It is waterproof and it can use GPS to track various different workouts including outdoor runs. There’s also a 4G option available. You have to remember one thing that if you are using it with an iPhone, then it won’t give you a smooth experience as an Apple Watch.
Pros:
  • Great performance.
  • Two days of battery life.
Cons:
  • This gadget is really expensive.
  • App choice is limited.
Garmin Vivoactive 4
The Vivoactive 4 is a sport-focused smartwatch from Garmin. It’s specially designed to provide you the benefits of notifications and smart features with various sports tracking up to 20 activities. This smartwatch is one of the best Apple watch alternatives because of its great focus on sports tracking, that includes running (indoor, outdoor, treadmill), cycling (indoor and outdoor), swimming (pool only), golf, strength, cardio, elliptical, indoor rowing, yoga and more.
There is 5ATM water resistance is also available! You can track all these sports via an Apple Watch, but all Garmin watches and Garmin Connect puts much more focus on training and sports.
This smartwatch is more of a jack-of-all-trades gadget, which makes it an impressive smartwatch. The notification support of this watch is great, but you can’t reply to anything from the watch or take any calls like you can on the Apple Watch.
The fitness tracking of this device is good as well, and sleep mode is advantaged by the pulse ox sensor that can deliver advanced sleep stages and information on your respiration when you sleep. There is a seven days battery life as a smartwatch and straight 13 hours of GPS on the Garmin Vivoactive 4.
Garmin Vivoactive 4
Garmin Vivoactive 4
Pros:
  • Great running features.
  • It has built-in GPS.
  • Impressive 5 ATM water-resistance feature.
Cons:
  • The 45mm version of this watch has limited color options.
  • Garmin Pay needs more advancement.
  • It’s an expensive gadget.
Fitbit Versa 2
Fitbit Versa 2 is one of its best devices in years. It’s slimmer and smaller on the wrist than an Apple Watch and it offers a lot of useful fitness features including swim tracking, HIIT coaching, etc. So it’s basically this watch is also one of the best alternatives for the Apple watch. Also, this smartwatch is cheaper than Fitbit’s other watch called the Ionic, which makes Versa 2 as an attractive option that supports your wallet and your wrist as well.
Fitbit OS isn’t advanced as the Wear OS or Apple Watch devices because you get to use a limited amount of apps, but if you want to use a watch that can maintain your fashion and focus on the fitness features then you must enjoy this smartwatch.
You can listen to music on the move and you can use Fitbit Pay to make payments from your bank account if your bank supports it. It doesn’t have a GPS feature, but if you want to exercise with your phone in your pocket or strapped to your arm then it shouldn’t be a problem.
Fitbit Versa 2
Fitbit Versa 2
Pros:
  • It has a beautiful AMOLED display.
  • Alexa and Fitbit Pay are integrated with the watch.
  • It has excellent battery life.
Cons:
  • It doesn’t have any built-in GPS.
  • It lacks app availability.
Skagen Falster 3
Skagen Falster 3 is a stylish 42mm watch that is equipped with a good amount of features which makes it one of the best Apple watch alternatives. Wear OS has limited options and no matter which brand’s smartwatch you are using, it can do nothing about that. Leaving that part, it’s an excellent smartwatch for casual use.
  • It has an AMOLED display with nice and vivid details, also the internal components of the watch make an overall good package.
  • It has a built-in GPS that helps the watch to handle tracking any route on the run.
  • It has integrated Google Assistant’s effective voice support and with NFC, you can make payments by tapping your wrist.
  • If you want to track activity then it will mostly depend on your app usage, but to be frank, this smartwatch is more than enough if you want to keep tabs on an average day.
The battery life is average that lasts about a day, so heavy-duty users will definitely face problems in this department. The design and styling of this watch are unique and it fits right in for most situations. Though compared to the features and what it provides you, the pricing may seem a bit too much, still it’s a great smartwatch.
Skagen Falster 3
Skagen Falster 3
Pros:
  • It has an excellent design.
  • It has built-in GPS and NFC.
  • It has an internal space for storing music.
Cons:
  • Battery life isn’t good.
Michael Kors Access Bradshaw 2
Michael Kors Access Bradshaw 2 is released with sizes and styles for both men and women, and this smartwatch initially stands out for looking more than a typical smartwatch. With the classy look and a variety of colors, some extra design tweaks add some flair to the overall outlook of this device.
  • It has a 1.7-inch AMOLED screen which makes the smartwatch different from a standard watch with a similar design. It runs on Wear OS, so it comes with access to Google Assistant and Google Play.
  • It’s not the best thing to wear for strict workouts or runs.
  • The silicone bands are way better at absorbing your sweat. But it does the job normally as a daily activity tracker.
  • It also has a good waterproofing level, so it’s possible for you to take it for a short swim.
  • It’s obvious that you might want to turn on the always-on display option to show off the outlook.
  • It doesn’t have an exceptional battery life, so the always-on display will eat the charge faster and you’ll get a maximum of 24 hours per charge.
Pros:
  • It has a classy and elegant design.
  • Includes Michael Kors custom watch faces.
Cons:
  • It’s not good for sweaty workouts.
  • It can be big for some wrists.
  • The battery life isn’t good.
AmazFit Bip
You may mistake AmazFit Bip as an Apple Watch clone, because of the resemblance at first glance. It has a squared 1.28-inch display doesn’t show off its highest quality, because it’s only a $100 smartwatch. If you can make compromises in your smartwatch in the overall user experience, then you should go for this one. This doesn’t run on Wear OS, Tizen, Fitbit OS, or any other known platform.
So, there are no apps that you can integrate to expand the feature set of the smartwatch. But you’ll get a decent collection of features that you may expect from any smartwatch, such as GPS tracking, heart rate monitoring, step counting, etc. and more.
The battery life is really excellent and eye-catching because it lasts up to 30 days with regular use or up to 45 days with limited notifications! If you have a tight budget and reasonable expectations, then the AmazFit Bip can cover you well.
AmazFit Bip
AmazFit Bip
Pros:
  • It almost looks like an Apple Watch.
  • It has GPS and heart rate monitor.
  • It has outstanding battery life.
Cons:
  • There is no app store available.
  • There is no way to respond to notifications.
  • There are limited strap options available.
TicWatch Pro
You can easily use the TicWatch Pro smartwatch with your iPhone. Though TicWatch is not a famous brand so far, it comes with two different displays which definitely makes this one stand out from the other smartwatches on the market. You’ll find a transparent LCD display at the top of the watch and a full-color OLED panel below it. So basically you can get a full Wear OS watch experience with it, but when the battery of the watch dies off then you can still get some details like heart rate, date, and time from the secondary display.
This is definitely a good feature but it also has GPS, NFC for Google Pay, and the Snapdragon Wear 2100 chipset. The best part of this smartwatch is the low price comparing to a lot of other top-end smartwatches. All these advantages make this smartwatch as one of the best Apple watch alternatives.
TicWatch Pro
TicWatch Pro
Pros:
  • It has an innovative screen tech.
  • The design quality is premium.
Cons:
  • It has limited app support.
  • There is no LTE feature available.
Conclusion:
After reading this article, your confusion regarding the best Apple watch alternatives must be gone by now. You can use any of these 7 best alternatives for the Apple Watch because all of them are unique and stylish in their own ways. All these smartwatches have unique advantages and features. Some of them are cheap at price but provides some impressive features and some of them are expensive but provides great value for the price. So good luck choosing an alternative to the Apple watch!
