Having encountered the problem that the Apple TV stuck on the Home Sharing screen when streaming the music, videos, photos, and movies, etc. to your Apple TV? In this article, six effective methods will be introduced to fix the Apple TV stuck on Home Sharing screen issues. Follow this article to learn more details.
Q: My Apple TV is stuck on the Home Sharing page. There are only settings and computer icons. What can I do to make it return to the normal interface? Help!
Q: Why is my Apple TV stuck at home sharing interface? I have tried to use my own personal hotspot to have a try, but it didn’t work. Please help!
Sometimes, we are not able to stream the photos, music, or other media-audio materials to Apple TV for some reason. Before we start talking about how to fix such issues, we would better figure out the reasons why Apple TV stuck on the home-sharing screen at first.
Generally speaking, the Apple TV encounters such problems are usually caused by an inconsistent Apple ID of your Apple TV, iTunes, and other Apple devices. What’s more, the internet connection and home-sharing settings are also the possible factors that may cause that you are not able to stream the contents from your iTunes to the Apple TV.
Therefore, when we are finding the solutions that are able to tackle this problem, we need to take the Apple ID, internet connection, and home-sharing settings into consideration at first. In the next part, I will show you the specific methods on how to address the problem of the Apple TV stuck on the Home Sharing page.
When you are streaming the contents from the devices to the Apple TV, the must do is to ensure that you have turned on the Home Sharing settings on both your devices and the Apple TV. Follow the below guide to learn how to turn on the Home Sharing settings on your Apple TV or other devices.
For Apple TV 4K & Apple TV HD:
Select Settings on your Apple TV > find and click Users and Accounts > turn on Home Sharing settings.
For Apple TV 3rd and Earlier Generations:
Choose Settings on your Apple TV > choose Computers > enable Home Sharing.
Here are the steps you can refer to:
Run iTunes on your PC > choose File option > choose Turn On Home Sharing > enter your Apple ID and password to open Home Sharing.
Turn on Home Sharing Settings
You can follow the steps below to enable the Home Sharing Settings:
Open Settings on your devices > find and choose Music or TV > select iTunes videos > turn on the Home Sharing setting > enter Apple ID and password as well to turn on home sharing setting.
Steps: Click the Apple menu icon on MAC > choose System Preferences > click Sharing > Media Sharing > choose Home Sharing > enter your Apple ID and enable Home Sharing settings on your Mac.
As we mentioned in the first part, one of the possible reasons for the Apple TV stuck on the Home Sharing screen is that the Apple TV didn’t enjoy the same internet connection with your devices.
Why it matters? Actually, if you want to use the Home Sharing feature, to ensure that the Apple TV and your devices are using the same internet is a must. Therefore, if the Apple TV stuck on such the Home Sharing interface, you have to check the internet connection as well.
Just like to maintain the same internet connection between your devices and Apple TV is a must for Home Sharing, to make sure that the Apple ID of your devices and Apple TV is the same is also an inevitable step for successfully streaming content from devices to Apple TV.
The steps to check the Apple ID of the Apple TV and your devices are the same as the steps of enabling Home Sharing settings mentioned in method 1.
Restarting the Apple TV is worth a trial as well. In most cases, it enables the users to fix some of the problems of Apple TV.
Follow the below tutorial to soft restart the Apple TV so as to fix the Apple TV stuck on the Home Sharing screen issue at ease.
Using Siri Remote:
Press the Menu and Home buttons at the same time > let go of the two buttons when the Apple TV flashes.
Using Apple TV Remote:
Press the Menu and Down buttons > release it when the Apple TV flashes.
Open Settings > select System > choose Restart.
For the 3rd and Earlier Generations:
Go to Settings > choose General > select Restart option.
You are also able to unplug your Apple TV and then plug it back in to reboot the Apple TV.
Resetting Apple TV to the factory settings is a possible solution that works as well. You are able to reset your Apple TV according to the generations of your Apple TV.
Go to Settings > choose System > then choose Reset.
For the 3rd and earlier Generations:
Head to Settings > choose General > select Reset option to reset your Apple TV so as to fix the Apple TV stuck on the Home Sharing page.
If the above-mentioned five methods still can’t solve the issues you face, you are able to give a professional Apple TV troubleshooter with various features a try. Here, I would like to recommend you AnyFix – iOS System Recovery, a professional system repair tool, that is able to fix 20 + Apple TV issues at ease. To put it more clearly, it not only can easily fix Apple TV stuck on the Home Sharing screen issue but also enable the users to fix Apple TV stuck on the airplay screen, Apple TV stuck on the Apple logo as well as some other Apple TV issues.
Now, follow the below steps to fix the Apple TV stuck on the Home Sharing page!
Step 1: Download and launch AnyFix on your computer > connect your Apple TV to your computer > tap on the System Repair option.
Tap on System Repair
Step 2: Select the 20+ Apple TV Problems option on the left side of the software > click Start Now button.
How to Fix Apple TV Issue- Step 2
Step 3: There are three modes you can choose to repair your Apple TV. Here, the standard repair mode would be recommended. Click Standard Repair at the bottom of the software.
Choose Standard Repair in System Repair
Step 4. You can follow the instruction on the screen and then click Download to download the firmware required to fix the Apple TV issues. When the Repair completed page occurs, the repair journey is completed.
System Repair Completed
There have mentioned 6 methods to fix the Apple TV stuck on Home Sharing issues. The first three are simple methods and are the necessary factors for successfully streaming content like music, video, etc. to your Apple TV. They are the first bunch of solutions that you need to take into consideration as well. If these three methods can’t solve the problem, then you are able to try another three methods to fix it. Anyway, hope this article can help you!
Please enter a valid email address
