Apple TV has been reported stuck on an airplay screen recently. How would this happen and how to fix it quickly and easily? In this post, we’ll list 5 efficient ways which can solve the s annoying problems. Keep on reading and get the most suitable one for your situation.
Apple is committed to providing his users with better smart life experience. Apple TV+, Apple Arcade, and more Apple’s subscriptions are coming for most smart-home-life users. A true life long experience for all, there is nothing last a forever perfectness. Problems are inevitable in smart home living. Apple TV stocks on an airplay screen issues are becoming more and more common recently. How to get rid of it? In this post, we presented several solutions to conquer the problem, and a few tips were given to avoid such an annoying issue.
Keep on reading, and get the most suitable solution for your Apple TV.
Apple TV stuck on the airplay screen issue is not a big problem. To some degree, this issue often due to the TV got into the conference room mode. Once you enabled the conference mode each time you turn on the TV, it won’t respond to you even you smash the Home button. That is to say, you can get the Apple TV out of the airplay screen easily.
1. Apple TV 4K or Apple TV HD.
2. Apple TV (3rd generation and earlier).
1. Siri/Apple TV Remote
2. Apple Remote
If both the methods don’t restart your device, you can unplug your Apple TV from power. And wait for a while, then plug it back in.
1. Head to Settings > Choose the System > Click on Reset.
2. You can choose the most suitable reset option for your Apple TV:
Keep your Apple TV plugged into power until the Reset process finishes.
1. Select Settings > click the General > Tap on Reset.
2. Now you can choose one of these options:
Some Apple TV users fixed the device stuck on an airplay screen through using another Apple device. Therefore, if all these methods mentioned above are failed to solve the typical problem, you may consider giving your iPhone a try.
Connect your iOS device to the same Wi-Fi network with Apple TV.
Step 1. Get an iOS device and head to the Apple store to download the Apple TV Remote.
Apple TV Remote
Step 2. Open the Apple TV Remote on your iOS device and then select add Apple TV > Tap the Apple TV or enter the code on the TV.
Step 3. Once the pairing works well, you can use the iOS device to remove the AirPlay screen.
This is the last but not the least tip for most Apple TV users as Apple support works 24 hours a day. You can get rid of the airplay screen issue with the guidance of a professional. Sure, if your Apple TV is stuck on a hardware issue, you will spend a lot on this problem. What’s more, with the soring of the COVI-19, ask for a replacement or an after-sale repairing won’t be a good tip during the quarantine. Hence, we are highly recommending the best alternative tip for Apple after-sale service.
As for all, Apple’s products are quite precise and high qualified. Even it happens to get stuck in problems, it won’t be a big deal. That is to say, it rarely is a hardware problem. Many of Apple’s users get the issue fixed with a restart or the factory resetting. But some can’t make it. Here we recommend you AnyFix, a professional system issue troubleshooter, which is easy to use. You can solve the problem with a few clicks.
Steps below will lead you to fix the Apple TV stuck on the airplay screen problem.
Step 1. Download AnyFix on your computer > launch it on your computer > connect your Apple TV to your computer > choose the System Repair on the top of the front page.
System Repair to Eliminate Error
Step 2. Tap on the 20+ Apple TV Problems > Click on Start Now to the next page.
Step 3. You can choose the most suitable repair mode for your Apple TV. Here we recommend the Standard Repair which won’t risk any data loss.
Choose the Standard Repair to Go on
Step 4. Keep on clicking the buttons which will lead you to the Repair Completed page.
Repair Completed Page
That’s all for the Apple TV stuck on an Airplay screen issue. If you did fix the issue through the tips mentioned above, you can share this post with your friends. This issue is not so severe. You don’t have to panic. Also, with the help of AnyFix, you can figure this out quite soon.
Please enter a valid email address
