Unable to add Apple Wallet to your iPhone or iPad? That’s nothing to worry about. Discover why Apple wallet is not working with your iOS device and the appropriate troubleshooting solution to fix it by reading through this post.
Hi,
I’m trying to link my credit card to my Apple Wallet on my iPhone 14 Plus but all efforts are futile. What could be the reason and how do I fix it? Kindly help a friend!
Apple Pay is a payment system established and integrated by Apple Inc into its mobile devices for seamless transactions. However, you need to link a credit or debit card to your Apple Wallet before the payment system could work.
The technique required to add cards to Apple Wallet is straightforward. But if you are facing difficulty trying to get this done, this is the right post you need to fix the problem. This post is structured to cover the reason why Apple Wallet fails to accept your card and how to resolve it.
Also Read: Fix iPhone Screen Freezes and Won’t Respond to Touch >>
Adding your card to Apple Wallet shouldn’t be a challenge. But if otherwise, then there’s something wrong. Here are the common reasons you can’t add your card to Apple Wallet:
Now you know why the add to Apple Wallet not working issue could occur on your iPhone or iPad, let’s delve into how to fix it. Below are the 6 regular/basic solutions to resolve the problem:
Since your internet strength is important when adding a card to Apple Wallet, checking your internet connection would be an effective way to fix this problem. To get this done, here are some pro tips to apply:
Checking your device for the Apple ID region is another effective solution worthy to fix add to Apple ID not working issues on your iPhone or iPad. This solution is suggested since we pointed region restrictions as one of the reasons why you experience difficulty connecting your card to Apple Wallet.
Following these steps below, you can check if your Apple ID region supports Apple Wallet:
Go to the Settings panel and choose General
Swipe down and click on Language and Region
Use the steps to change your Apple ID region if your current destination doesn’t support Apple Wallet:
Tap on your profile name
Choose Media and Purchases and select View Account
There’s a threshold on the number of cards you can link to your iPhone. However, this number varies from one phone model to another. For instance, the iPhone 8 and later models let you add up to 12 cards to your Apple Wallet, and a lesser number of cards is supported on older models. If this is the cause of add to Apple Wallet not working, checking and removing some cards that you don’t use would be helpful.
Here’s how to remove some cards from your iPhone:
Remove Some Cards on Phone
Alternatively, you can follow the guide below to complete this operation from the settings panel:
Choose a card to remove and click on Remove This Card
When Apple Pay server status is down, connecting your card to Apple Wallet could be challenging. Checking and confirming if the Apple server is up for Apple Pay is a helpful pro tip to fix the underlying issue. You can do this following these steps:
Check Apple Pay Server Status
Another easy peasy solution to fix add to Apple Wallet not working issues is updating your iOS firmware to the latest. Obsolete iOS version causes your device to malfunction and a common error you will likely come across is add to Apple Wallet not working.
Use these guide to update your iOS firmware:
Update Your iOS Firmware
Note: Make sure you have a stable internet service while updating your iOS firmware
Lastly on the regular solutions to fix the underlying issue, we suggest contacting your bank to help. The support team at the bank would direct you on what to do to connect your card to Apple Wallet without errors or better yet resolve it from their end.
If your iPhone still fails to add a card to Apple Wallet after implementing the solutions mentioned above, your iOS system may be corrupt and need fixing. You need an iOS system repairer to get this done and AnyFix – iOS System Recovery is a great one to use.
AnyFix is a top quality iOS repair software dedicated to fixing system related issues you may encounter on an iDevice, whether iPhone or iPad. Surprised why no data loss is incurred? Well AnyFix is trained such that it fixes the target problem and does not interact with the user’s data.
Step 1. Free get AnyFix and launch it > Select the System Repair mode.
AnyFix System Repair Option
Step 2. Locate and click on the App Issues tab on the left sidebar and click Start Now to continue.
AnyFix System Repair App Issues
Step 3. Proceed to choose a repair mode to fix the underlying issue on your iPhone. Choose Standard Repair from the options provided.
AnyFix Standard Repair
Step 4. Next, AnyFix will perform a quick scan and prepare a configuration file (also known as firmware package) to repair your iPhone. Hit the green Download button to proceed.
Step 5. Then. click on Start Standard Repair. AnyFix will act on your command. Kindly exercise patience while the repair is on. Once completed, you can disconnect the device from your computer and try to add your card to Apple Wallet without hassles.
Repair Is Completed
With Apple Pay, you can make payments right from the comfort of your home. But when issues like add to Apple Wallet not working occurs, it becomes difficult. Using any of the solutions recommended in this post should fix the underlying issue
What’s more, our best option is AnyFix. The software is capable of fixing add to Apple Wallet problems and many other iOS-threatening issues you may encounter. Download, install and try AnyFix out now to see the magic.
