iPhone/iPad Lost Mode Unlock Full Guide 2025
Your iPhone and iPad come with many security features and one of these features is lost mode. This guide explains to you what the iPhone lost mode is, how it functions on your device, and how you can override lost mode when you got your iPhone or iPad back. Read this post carefully and you’ll have a better understanding about the lost mode for iPhone/iPad.
Author Avatar Joy Taylor Last Updated: Feb. 26, 2025
One of the most dreadful situations for Apple device users is that the iPhone end up being stolen. This can happen anytime and anywhere. You may lose your iPhone or iPad when forget to pick it up from the bench you were sitting on in a park. Or, you can drop it somewhere and later realize the phone is not in your pocket.
Luckily, your iOS device has a feature that lets you find it when it is lost. This feature is called Lost Mode and you can use it with iCloud to find the location of your device and show a message on your lost device’s screen.
This guide further explains what is and how to use Lost Mode in detail and accordingly, you can learn how to unlock iPhone in Lost Mode when you get your it back.
Further Reading: Fix Find My iPhone Online Not Sharing Location >
What is Lost Mode on iPhone/iPad?
Lost Mode is a feature of Find My iPhone that allows you to display a message along with a phone number on your lost device. This way, when someone finds your iPhone or iPad device, they know exactly who the device belongs to and they can even contact you by calling the number that you have added as a message to your lost iPhone.
How to Enable Lost Mode on iPhone?
You can turn on Lost Mode for your iPhone and iPad from either the iCloud website or the Find My app on your devices. It is fairly easy to activate the Lost Mode for tracking your lost device.
Enable iPhone Lost Mode in Find My App
If you have multiple iDevices and one of them is lost, you can use another iPhone/iPad to enable lost mode in the Find My app.
  1. Launch the Find My app on your iPhone.
  2. Tap on Devices and tap your lost device.
  3. Tap on Activate under “Mark as Lost”.
  4. Follow the instructions to finish the process of enabling Lost Mode on your iPhone/iPad.
Enable Lost Mode for Your Device
Enable iPhone Lost Mode in iCloud
If you don’t have an alternate iPhone to use Find My app, you can also use iCloud Find My app to turn on Lost Mode for your missing device.
  1. Go to iCloud.com in your browser and log into your account.
  2. Select the device in the device list.
  3. Click Mark as Lost for the selected device.
  4. Enter your phone number and press Next. Then, enter the custom message you want to add to your lost device’s screen and click on Done at the top.
How to Track Your iPhone in Lost Mode
The Lost Mode should now be activated on your chosen device, after which, all of the features on your device get disabled when you enable the Lost Mode. You can then track the location of your device using the live map on the iCloud website. As long as your device is connected to the Internet, you will keep getting the live location data on your screen.
Locate Your Device in Lost Mode
This location can be accessed using the Find iPhone feature on the iCloud website. You will see a green dot along with your device’s name on the map, and that is the location of your device. If you want, you can click on the refresh icon next to the device name to update the current location.
How to Unlock iPhone in Lost Mode?
For those who are lucky enough to get back their lost iPhones, it’s necessary to unlock lost mode and use the device normally. Once you have enabled the lost mode on your iPhone, there will be an alert saying iPhone unavailable on the locked screen. You may also need to stop lost mode for iPhone in iCloud Find My app.
To unlock iPhone from lost mode in iCloud:
  1. Go to your browser and open iCloud.com/find.
  2. Sign in with your Apple ID (Use the one you set in your lost iPhone).
  3. Choose the device that is currently in Lost Mode from the device list.
  4. Click on Lost Mode and select Stop Lost Mode to unlock Lost Mode on iPhone.
Stop Lost Mode
Stop Lost Mode
Then you can enter your iPhone passcode and unlock it to use. On some occasions, you may fail to use iCloud but you need to use the iPhone urgently, then you can factory reset your iPhone to get back to using it.
How to Bypass Lost Mode on iPhone/iPad without Password?
As you can see, unlocking lost mode could be quite easy if you can unlock your iPhone or iPad. However, what if you get back your iPhone but forget the screen password? Or you bought a second-hand iPhone online while the seller didn’t help you unlock iPhone from lost mode? In these circumstances, you need to find a way to get out of the lost mode on your own. If you fail to enter your device because of the screen passcode, you can put your iPhone/iPad in recovery mode and restore your device via iTunes first.
You can enter the recovery mode by pressing and holding the Power and Home buttons at the same time. If your iPhone doesn’t the Home button, press the side button and the volume up/down button simultaneously, instead. Then you will see the Apple logo on the screen. Hold down the buttons until you see the recovery mode screen as below.
Enter iPhone Recovery Mode
Then connect your iOS device to the computer. Launch iTunes and you’ll see a pop-up message, asking you to restore your iOS device.
Restore iPhone/iPad in the Recovery Mode
The restoration process will be complete until you see the hello screen on your iOS device. It will take some time to activate and set up your device. Finally, you may come to the Activation Lock screen. Now, you should use some professional toolkits to get rid of it. AnyUnlock – One-Stop iPhone Unlocker enables you to bypass iCloud Activation Lock on your own. With a professional team with 7 years of experience, it can unlock your iPhone/iPad in a few clicks without skills or techniques. Free install AnyUnlock – iPhone Password Unlocker, connect your iPhone to the computer (Win or Mac) and bypass iCloud Activation Lock in simple clicks.
Bypass iCloud Activation Lock on Windows Computer
Step 1. Download AnyUnlock and launch it on your computer. Choose the Bypass iCloud Activation Lock mode and tap on the Start Now button.
Click on Start Now to Bypass iCloud Activation Lock
Step 2. Connect your iPhone or iPad device and click the Start Now button to initiate the process.
Connect Your iOS Device to the Computer
Step 3. Now you need to jailbreak your device to allow AnyUnlock to bypass the Activation Lock. Watch the Jailbreak Tutorial to jailbreak your device on your own.
Jailbreak Your Device
Step 4. Click on the Start Now button after the jailbreaking process finishes. Wait until the bypassing process is finished, you will see the iCloud Activation Lock is bypassed successfully page as below.
iCloud Activation Lock Is Bypassed Successfully
Bypass iCloud Activation Lock on Mac Computer
Step 1. Download the AnyUnlock – iPhone Password Unlocker on your Mac. Get it installed > Click Bypass iCloud Activation Lock and connect your iPhone.
Choose Bypass iCloud Activation Lock
Step 2. You need to connect your iOS device to the computer now, and then click on the Start Now button to the next step.
Click on the Start Now to Go On
Step 3. Following the indication on the screen of the Bypass iCloud Activation Lock, you need to confirm your iOS device’s information. Put your iOS device into DFU mode, and then the jailbreaking process will start.
Start to Jailbreak Your Device
Step 4. When the jailbreaking process completes, you can click on the Bypass Now to start bypassing iCloud Activation Lock on your device.
Tap on Bypass Now to Start Bypassing
Step 5. Wait until the bypassing process is finished, and you will see the Bypassed Successfully page.
  1. Please do not factory reset the device or flash the firmware, or the device will be locked again.
  2. Feel free to log in to App Store and iTunes Store with your new Apple ID. Please do not log in to iCloud from settings.
Faqs About Lost Mode in iPhone/iPad
Last but not least, we collect some questions users always have about the lost mode on iPhone/iPad. Keep reading to have a better understanding of the lost mode on iPhone/iPad.
Can someone unlock my iPhone in lost mode?
YES, it’s possible for someone to unlock your iPhone if he knows your iPhone passcode or iCloud information. It’s better to keep your personal information carefully. Unluckily, if your iPhone is lost, remember to enable lost mode and change all of your account passwords as soon as possible.
What Happens When iPhone Goes into Lost Mode?
The following actions are taken when you enable the Lost Mode for your iOS device. These things ensure that the data stored on your device remains safe and that there is a way for the person who has got your device to reach out to you with your contact details.
Message and Phone Number: When you use iCloud to enable the mode, you are offered an option to add a phone number as well as a custom message to your lost device’s screen. This message and your phone number are immediately displayed on your device when you turn on the Lost Mode.
Call Button: If your lost device had phone call capabilities like if it was an iPhone, a Call button will appear on the screen allowing the user to call the specified number. This way, when someone finds the device, they can tap on this button to get in touch with you.
Apple Pay Deactivation: As soon as the Lost Mode is enabled, all Apple Pay functions are deactivated to ensure your money is safe. Anyone who finds your device will not be able to perform any transactions with this payment service.
Low Power Mode: Apple wants to keep the custom message and phone number displayed on your lost device’s screen for as long as possible. Because of that, Lost Mode enables the Low Power Mode on your iOS device so that your device runs for a maximum amount of time with the available battery charge.
No Access to Any Features on the Device
All other features of your device get deactivated when you use Lost Mode. This is to ensure anyone who gets access to your phone cannot read your messages and other app notifications.
When Should You Use Lost Mode?
Now that you have a good idea of what the Lost Mode is and what it does when you enable it, you will probably want to find out exactly when you should use this mode for your iPhone or iPad device.
When You Forgot the Device at a Cafe: If you go out somewhere, say at a cafe, and you forget your iOS device there, you can enable Lost Mode for your device. This will display your message, and when someone finds the device in the cafe, they will know who to return the device to.
When You Lost the Phone in a Park: If you missed picking up your device after putting it aside in a park, you can enable Lost Mode and someone who finds the device will then be able to return it to you.
When You Lost the Phone in a Bus/Train/Flight Journey: People often forget their devices while traveling, and it is likely for that to happen to you, too. If you ever forget your phone in a car, bus, train, or flight, you can quickly enable the Lost Mode and that will help the person who finds it to contact you.
Whether you are looking to enable the Lost Mode on your iPhone or iPad, or you are looking for a way to unlock the iPhone Lost Mode, the above guide will help you with your tasks. It tells you everything that you need to know about the Lost Mode on iPhone and iPad devices.
