OK, got it
Best iCloud Activation Lock Removal Software 2025
Are you looking for the best iCloud activation lock removal software? Don’t know how to bypass iCloud activation lock when you fail to recall the login information? Read this article to get the top iCloud removal tool and the detailed guide on the iCloud unlock. Paid and free iCloud activation lock removal tools are all introduced here.
Author Avatar Joy Taylor Last Updated: Apr. 24, 2025
AnyUnlock – iCloud Activation Lock Removal Software
Searching for the best iCloud bypass tool 2025? Try AnyUnlock! It allows you to bypass iCloud activation lock on iDevices with simple clicks. Available for Windows & Mac users.
When you factory reset your iPhone without using the Apple ID, you will be stuck on the iCloud activation lock page. In this case, you may wonder if there is an iCloud activation lock removal tool available for use. Yes, there are several tools you can try to bypass iCloud activation lock on iPhone. With these iCloud bypass tools, you won’t need to provide the Apple ID information to regain access and set up your iPhone. Check the following 11 iCloud activation lock removal tools and try your preferred one effortlessly.
Top 1. AnyUnlock – iCloud Activation Unlocker [Professional]
The first recommended tool for iCloud activation lock bypass is AnyUnlock. It is an all-in-one iPhone unlocker that works for iCloud bypass, iPhone screen unlock, Apple ID unlock, and more. As a professional iCloud activation unlocker, AnyUnlock does not have any complicated operations and technical requirements, allowing you to easily unlock your iCloud activation lock just by tapping the button as instructed.
Free download AnyUnlock and connect your iCloud-locked device to the computer. Then you can either watch the video tutorial below or take the detailed steps to bypass iCloud Activation Lock in simple clicks and on your own. You can use this iCloud removal tool either on your Windows computer or your Mac to bypass iCloud Activation Lock.
Features:
  • iPhone/iPad activation lock removal without password and Apple ID
  • Only need a few minutes to remove iCloud activation lock in simple clicks
  • Find the Apple ID that is linked to iCloud Activation Lock on your iPhone
  • Unlock Apple ID, screen passcode easily.
  • Also support to remove SIM lock.
Pros:
  • Enjoy the highest success rate of bypassing
  • Sign out of iCloud without any risk of privacy leakage
  • An iCloud bypass tool for Windows and Mac
Cons:
  • It may take some time to complete the steps.
Steps for Windows Users
Step 1. Free install AnyUnlock on your computer. Launch it and choose the Bypass iCloud Activation Lock mode on the left panel of its homepage to get started.
Click on Start Now to Bypass iCloud Activation Lock
Step 2. Connect your iCloud-locked device and click the Start Now button.
Click Start Now Button
Connect Your iOS Device to the Computer
Step 3. Then, you need to jailbreak your device if you haven’t. You can jailbreak your iOS device by yourself or use our recommended jailbreak tutorial to do it.
Jailbreak Your Device
Step 4. Then the tool will start to bypass after clicking the Bypass Now button. Wait until the process is finished, you will get iCloud Activation Lock is bypassed successfully page as below.
iCloud Activation Lock Is Bypassed Successfully
Steps for Mac Users
Step 1. Download AnyUnlock on your Mac computer, install and run it on your computer > Choose Bypass iCloud Activation Lock.
Step 2. Connect the iCloud-locked device to the computer and hit the Start Now button to get initiated.
Click on the Start to Go On
Step 3. Take the on-screen instructions to confirm and download the jailbreaking tool to get your iOS device jailbroken.
Download the Jailbreaking Tool
Step 4. After the jailbreak tool is downloaded, you should put your iOS device into DFU mode. When the jailbreaking is completed, you can choose Bypass Now to continue.
Tap on Bypass Now to Start Bypassing
Step 5. Wait for a few minutes until AnyUnlock finished the bypassing process. Now, you will see the interface on the screen below.
Please DO NOT log into iCloud from the Settings on your iPhone iPad iPod touch or factory reset your device which will lock the device again.
Now you can log in to the App Store to download whatever applications you like and go to the iTunes Store to get the music and movies you found with your new Apple ID.
Top 2.  iPhone Approved Unlock
iPhone Approved Unlock is another iCloud activation lock removal software that can help you to remove the iPhone activation lock. It can be handled by newbie users without facing too many challenges. Here are some features of this Apple activation lock removal tool.
iPhone Approved Unlock to Unlock iCloud Lock
Features:
  •  Remove Activation Lock for either your iPhone or iPad device.
  • You need to offer your device’s IMEI number to the website.
Pros:
  • It offers an easy and safe method to unlock iOS devices that have been locked.
  • It’s easy to use and user-friendly.
Cons:
  • Some users found that their devices cannot be detected.
  • You have to pay for the service.
Top 3. iCloud Bypass
Want to complete iCloud activation lock removal free online? Another free iCloud unlock service is iCloud Bypass, which allows you to easily remove your iCloud activation lock. Apart from that, this tool can also help you unlock the network carrier and remove the Apple ID. And you can learn what it can do for you in iPhone activation lock removal free.
iCloud Removal Tool - iCloud Bypass
iCloud Removal Tool – iCloud Bypass
Features:
  • Supports unlocking iCloud activation lock, Apple ID and SIM card.
  • Detailed guide to put the device into DFU mode.
Pros:
  • Easy to operate, suitable for novices.
  • Supports Windows, Mac and Linux.
Cons:
  • Takes a long time to unlock.
  • It will erase your original iCloud account.
Top 4. iCloudin
Want to achieve iCloud activation lock removal free? Then you cannot miss iCloudin, an easy-to-use and totally free iCloud activation lock removal tool. As its name says, this tool is specially designed to bypass Apple Activation Lock. Although compared with other software, it does not have so many complicated functions, with this feature alone, it can rank among the best Apple activation lock removal tools.
Use iCloudin to Remove iCloud Activation Lock
Features:
  • Support to remove and disable iCloud activation lock.
  • The interface is simple and intuitive, which is convenient for users to learn.
Pros:
  • This is a completely free activation lock removal software.
  • The operation is simple and user-friendly.
Cons:
  • Poor compatibility, only applicable to iOS 9 and earlier system versions.
  • It is difficult for you to find a safe and official way to download this tool.
Top 5. GadgetWide
Can I find iCloud activation lock removal free? GadgetWide is also a recommended Apple activation lock removal tool that has received many good reviews from people. By linking to an iCloud external server, GadgetWide can help you easily bypass activation lock, so you can enjoy all the services brought to you by your phone without limitation.
GadgetWide iCloud Activation Removal Tool
Features:
  • Connect to external server to remove iCloud Activation Lock.
  • It provides users with a detailed operation guide, so you don’t have to worry about not being able to operate it.
Pros:
  • Works fast, so it won’t take too long to bypass iCloud Activation Lock.
  • This is a free software, so you can use it to complete iPhone activation lock removal free.
Cons:
  • Only supports iOS 11 and below system versions.
  • Mac users cannot use this tool.
Top 6. Try DNS Method
If you want to make iCloud activation lock removal free, DNS can help you to do that. DNS is not strictly an Apple activation lock removal tool, but a domain name server. However, by changing it, you can easily unlock your iCloud activation lock. Most importantly, this method only requires you to operate on your phone, so it will be a very suitable method for those who want to complete iCloud activation lock removal free online without computer. But you need to note that it only works on iOS 12 and iOS 13.
Try DNS Method
Try DNS Method
Features:
  • Remove iCloud activation lock by changing DNS.
  • Does not require a computer, only needs to be operated on iPhone.
Pros:
  • Easy to operate.
  • There is no need to download additional tools, it is a completely free activation lock removal tool.
Cons:
  • High requirements for network and DNS stability.
  • Only for iOS 13/12.
Top 7. Doulci iCloud Unlocking Tool
To bypass iCloud activation lock, Doulci is another useful iCloud removal tool. It is easy to use and it works on all iOS devices, including the iPod Touch. It is not a UI tool and therefore, it should allow you to run your iCloud bypass server.
Doulci Activator
Doulci Activator
Features:
  • It is very compatible with Windows and Linux.
  • You don’t need to offer any extra information such as IMEI or any screen passcodes to bypass the iCloud activation lock.
  • It supports all of the iOS devices including the iPhone X series, iPhone 11 series, iPad Pro, iPad Mini.
Pros:
  • It’s user-friendly.
  • This Tool’s website has support with tutorials.
Cons:
  • It supports limited Apple versions and is not updated regularly.
  • You have to complete a survey to be allowed to download this tool and the download speed is slow.
Top 8. iCloud Activation Bypass Tool 1.4
Another recommended iCloud lock removal tool is iCloud Activation Bypass Tool 1.4. This is one of the best Apple activation lock removal tools which is using by many people nowadays. This tool directly connects to the Apple servers to unlock iPhone activation lock and is very easy to use. And you can learn more about this iCloud removal tool below.
Features:
  • It can be very useful to you when you are looking to iCloud activation lock remove an iCloud account, and uniform bypasses the iCloud lock.
  • One-click iCloud Bypass process. No need to install other tools to your PC. After the bypass of your device, you will be able to use new Apple ID, Apple Store ID on your device
  • Support all iPhone series.
Pros:
  • Users can get 24/7 support for any issues.
  • It can be used for more than just one purpose.
  • It works with a lot of iOS devices normally.
Cons:
  • It is slightly more complicated to use than other tools.
  • It stops suddenly sometimes while performing the process.
Top 9. Open My iCloud Easy Unlock Tool
Open my iCloud Easy unlock tool is also a widely used Apple activation lock removal tool to help unlock or bypass iCloud lock. It is easy to use and comes with a tutorial to help users figure it out effectively. Just read on to find out the features of this iCloud unlock software.
Features:
  • Supported all iOS versions.
  • Unlock the iCloud activation lock using the IMEI of the device.
  • It works on Mac, Linux, and Windows.
  • This tool can be used OFFLINE.
  • This Cloud unlock method uses a mirror activation server that can activate your iPhone/iPad/iPod when connected to iTunes.
Pros:
  • Works on all iOS devices.
  • It allows you to use your phone’s IMEI code to unlock your iPhone.
Cons:
  • Sometimes it only comes with a Windows download.
  • It’s too slow and it hasn’t customer support to resolve the issues.
Top 10. iRemove Unlocking Software
In addition to the above iCloud removal tools, iRemove is also a powerful tool worthy of your choice to unlock iCloud Activation Lock, which supports the Mac, iPhone, and iPad activation lock bypass. Read below to see its features.
iCloud Removal Tool - iRemove
iCloud Removal Tool – iRemove
Features:
  • You only need to click the button to unlock iCloud activation lock.
  • Provide you with a simple and fast IMEI query service.
Pros:
  • The interface is intuitive and concise, which is convenient for users to use.
  • iRemove is still available even if your SIM card is locked.
Cons:
  • No built-in jailbreak tools and tutorials.
  • The price is a little bit expensive.
  • Not supports iOS 15.
Top 11. CheckM8
Another iCloud activation lock removal tool we are going to introduce is called CheckM8. With this tool, you can quickly bypass your iCloud activation lock with one click. Apart from iPhone, CheckM8 also supports iCloud activation lock removal on iPad. The following are the specific functions of this iCloud removal tool.
CheckM8 iCloud Activation Removal Tool
Features:
  • Remove iCloud Activation Lock with just a click of a button.
  • You can also use this tool to bypass screen lock, unlock Apple ID, bypass MDM lock, etc.
Pros:
  • The types of supported locks are more diverse.
  • The latest version supports both Windows and Mac computers.
Cons:
  • The latest version only supports iOS 15 and earlier systems. You cannot use it if your system is iOS 16.
  • The functions of the free version are limited.
In addition to the iCloud removal tool mentioned above, we have also compiled some other questions about iCloud and iOS device unlocking. Below are the answers to these questions.
What is the best iCloud activation lock removal software?
Among all iCloud removal tools, AnyUnlock can be the best activation lock removal software. You don’t need to contact the previous owner if you bought a second-hand iPhone, or provide any device information such as the IMEI number or your purchase invoice.
What is the activation lock bypass code?
Activation lock bypass code is used to unlock or erase iOS device instead of using password, and you can find it in your device by following the steps below:
Find Profile Manager > Click Devices in the sidebar > Select your device and click About > Finally click Security and you can find your activation lock bypass code.
The above iCloud activation lock removal tools have been tested workable for Apple users. You can compare and try out the best one to remove the iCloud activation lock. For an easy and safe choice, AnyUnlock is highly recommended for its high success rate and clear instructions. Download AnyUnlock now and slove your iPhone being stuck on the iCloud activation lock issues.
