How to Jailbreak Locked iPhone [Proven Ways]
It is upset to buy a second-hand iPhone that is still locked by the iCloud Activation Lock. In this case, some users may seek to jailbreak iCloud locked iphone to unlock it. Can you jailbreak a locked iPhone? And how to jailbreak? This post will give you the answer and effective ways to jailbreak locked iPhone and bypass iCloud Activation Lock.
Author Avatar Joy Taylor Last Updated: Jul. 22, 2024
AnyUnlock – Jailbreak Locked iPhone and Bypass Activation Lock
If your iPhone is locked by iCloud activation lock, just free download AnyUnlock to jailbreak iCloud locked iPhone and bypass iCloud activation lock on it. Only simple button-clicks are needed. And it only takes a few minutes to do that.
All iOS-based devices come with a security feature called iCloud Activation Lock. This lock is enabled when you turn Find My iPhone on on your device and you erase the device. You then need to enter your correct iCloud logins before you can start using the new device. The purpose of this feature is to prevent unauthorized users from using the device.
However, sometimes it happens that you forget your iCloud logins, or you buy a second-hand iOS device but find that it has the Activation Lock enabled on it. In this case, many users will try to jailbreak locked iPhone to bypass iCloud Activation Lock.
Can you jailbreak an activation locked phone? And how to jailbreak locked iPhone and remove that activation lock? This guide gives you all the information that you need to know to jailbreak iCloud locked iPhone and remove activation lock.
Can You Jailbreak A Locked iPhone
Yes, you can use professional jailbreaking tools to jailbreak locked iPhone. After that, you can get rid of some restrictions set on your device.
Can you jailbreak an iPhone to remove activation lock? No, jailbreaking iPhone won’t help remove the iCloud activation lock, unless you use some additional tools or steps to bypass activation lock.
If you know anything about jailbreak, you probably know that jailbreak basically gives you access to the restricted parts of your iPhone. This means you can install apps from unauthorized sources, access the system files of your device, and make other tweaks to your iPhone. This is all possible by jailbreaking your phone.
However, you would be disappointed to know that you cannot jailbreak iCloud locked iPhone to remove the lock with any of the jailbreak methods. This is because to jailbreak activation lock is not the purpose of jailbreak; the purpose of it is to help you add new content and tweak your phone.
Fortunately, there are still many methods to get rid of the iCloud Activation Lock. In the following sections, we will show you proven ways to jailbreak locked iPhone as well as some proven ways to remove iCloud activation lock on iPhone.
Jailbreak iCloud Locked iPhone and Bypass Activation Lock via iOS Unlocker
How to jailbreak activation locked iPhone and bypass iCloud activation lock? In this case, you should use some professional iCloud Activation Unlocking tool to do that. And AnyUnlock – One-Stop iPhone Unlocker, which offers the most effective iCloud Activation Unlocker, is worth trying!
This all-in-one iOS unlocker can help you easily get rid of the iCloud Activation Lock screen and bypass the iCloud Activation Lock on iPhone/iPad/iPod touch without Apple ID or password. And the whole process can be completed within only 3 steps. It is easy to use and all you need to do is to free install the tool, connect your iPhone to the computer and click on buttons as steps below to bypass the iCloud Activation Lock.
AnyUnlock – iCloud Activation Unlocker
AnyUnlock – iCloud Activation Unlocker can help you jailbreak iCloud locked iPhone and bypass the iCloud activation lock without the Apple ID or password. It can also help you check if the iCloud activation lock is on or if the device is changed, quickly find logged-in Apple ID and information if you forgot, etc.
In addition, AnyUnlock can also help you unlock Apple ID without password, get rid of iOS screen lock, remove MDM restrictions, etc.
Detailed instructions are offered below. Now you can jailbreak locked iPhone to remove activation lock on either your Windows computer or Mac computer.
Steps for Windows Computer
Step 1. Free download and launch AnyUnlock – iCloud Activation Unlocker on your computer > Click the Bypass iCloud Activation Lock.
Click on Start Now to Bypass iCloud Activation Lock
Step 2. Connect your iPhone to the computer with a USB cable > Check the device information and tap on the Start Now button.
Connect Your iOS Device to the Computer
Step 3. Now, click on Jailbreak Now to jailbreak iCloud locked iPhone. You can follow the Jailbreak Tutorial since there is no direct jailbreak tool for the Windows system in the market currently. If your device is jailbroken successfully, please go back to the software and click on the Next button to continue.
Jailbreak Your Device
Step 4. Then, please confirm your device information and tap on Bypass Now. AnyUnlock will bypass iCloud Activation Lock, and please wait for a moment.
Bypassing iCloud Activation Lock
Step 5. When the iCloud Activation Lock is bypassed successfully, you can see the page below.
iCloud Activation Lock Is Bypassed Successfully
Steps for Mac Computer:
If you are a Mac computer user, just follow the steps below to bypass the iCloud Activation Lock on your iPhone:
Step 1. Free download AnyUnlock – iCloud Activation Unlocker on your Mac computer > Choose Bypass iCloud Activation Lock option.
Step 2. Connect your iPhone to the computer and click the Start Now button to start the process.
Click on the Start to Go On
Step 3. Then download the jailbreaking tool matching your iPhone. During the whole process, please ensure your iPhone is well connected to the computer.
Download the Jailbreaking Tool
Step 4. Once the jailbreaking process is finished, please tab on Bypass Now to start the bypassing process. And then you just need to wait for the process to be finished.
Tap on Bypass Now to Start Bypassing
Jailbreak iCloud Locked iPhone [Video Tutorial]
Here is a video guide for you to jailbreak locked iPhone. Just watch to jailbreak iPhone and bypass activation lock.
Jailbreak Locked iPhone via Online iCloud Unlock Service
How to jailbreak a phone that is locked? In addition to the above ways to jailbreak activation locked iPhone. Another way is to use a web-based service to get rid of the activation lock from your iPhone. There are many online services that let you remove the lock from your device remotely.
All you need to do is provide these websites with your phone’s IMEI number and some other details. You then need to make a payment. Once that is done, your phone is unlocked within the given time frame.
One big disadvantage of this method is that you will need to pay quite a hefty fee for the unlock service. This is one of the things that hold most people back. If you are fine with it, the following shows you the steps to jailbreak locked iPhone.
Step 1. Head over to the IMEI Unlock SIM website using your browser.
Step 2. Select your iPhone model from the Device dropdown menu and enter your phone’s IMEI number in the IMEI field. You can dial *#06# on your iPhone to reveal the IMEI number.
Unlock the iPhone Online
Step 3. Click on Unlock Now and follow the on-screen instructions to unlock your iPhone.
You will receive an email when your iPhone is unlocked. Then, you will be able to use the device with your own iCloud account.
Jailbreak Locked iPhone via Jailbreak Tool
How to jailbreak iPhone without passcode? If you’re using a Mac or Linux PC, Checkra1n is also a good option to jailbreak locked iPhone. This is a jailbreak tool specially developed for iPhone, and currently, it supports iPhone 5s to iPhone X running Ios 12.3 and above. If you want to jailbreak iPhone locked to owner, you might as well follow the steps below to try it out.
Step 1. Download Checkra1n on your Mac or Linux PC and connect your device to the computer.
Step 2. This tool will detect your device. After that, it will put your iPhone into recovery mode automatically.
Step 3. Then, you need to follow the on-screen guide to enter DFU mode.
Step 4. When your device enters DFU mode successfully, it will start jailbreaking your device.
Step 5. When it finishes the process to jailbreak iCloud locked iPhone, your device will reboot.
Remove Activation Lock from iCloud Locked iPhone
If you pay attention to what the iCloud lock says on your iPhone, you will find that it asks you to enter the Apple ID or iCloud login details on the device. Once the correct details are entered, your device gets unlocked and it no longer has the Activation Lock turned on for it.
Therefore, before you jailbreak iPhone locked to owner, you can first try to contact the original owner of the device to remove the Activation Lock from your device. This is the person whose Apple ID is being used on your iPhone. And, because this person has added their ID to your device, they are the one who probably knows the password for it and they can help unlock the phone.
Input the iCloud Password to Unlock the iPhone
Get in touch with the person whose Apple ID is being used on your device and ask them to enter their password on the phone. Once they have done that, the lock will be removed. You can then remove the existing Apple ID from your iPhone and add your own ID to it, or you may need to take other measures to remove Activation Lock without previous owner.
Unlock iCloud Locked iPhone via iCloud Web
There is a possibility that the previous owner of the device cannot be met in-person. If the previous owner lives in another country, or if they are out of town, you will need to wait for them to come back before you can unlock your device. However, Apple has another option that lets you remove the activation lock from your device online.
This method uses Apple’s iCloud web service, and if you already know, this service has a tool that lets you remotely perform actions on your iPhone. The previous owner of your iPhone can actually log-in to this site and remove your iPhone from their account. This way, the lock will be gone from your iOS device in no time.
If the previous owner does not know how to do that, you can ask them to follow the following steps.
Step 1. Launch the iCloud website in a new tab in your web browser. Then, log in to the original owner’s iCloud account.
Step 2. Once you are logged in, click the option that says Find iPhone. This will let you remotely remove the device from your account.
Use Find iPhone on iCloud Web
Step 3. On the resulting screen, click on All Devices at the top and choose the locked iPhone.
Step 4. When you see the locked iPhone, click on the option that says Erase iPhone followed by Remove from Account.
Erase and Remove iPhone From the Account
The above will erase the iPhone, as well as remove it from the linked iCloud account. This will remove the iCloud lock and you can now use your own account with your iPhone.
Unlock iCloud Locked iPhone via Apple Support
If the above methods fail to solve how to jailbreak locked iPhone for some reason, your last and only option is to visit the Apple support center. While this is a pretty tricky method and you will require some documentation, you might be able to get your iPhone unlocked with this last method.
Visit An Apple Center to Unlock the iPhone
Basically, you need to gather evidence that proves you are the owner of the device. You can show your phone’s bill, receipts, or anything that tells the Apple team the phone belongs to you. If you have bought the phone from your relative, you can present documents that show your relationship with that person.
If the Apple team is satisfied with the submitted documents, they might be able to remove the activation lock from your iPhone for you.
If you are looking for ways to jailbreak locked iPhone to ultimately remove the activation lock, the above guide should tell you if this is possible and offers some other methods for you to perform. And we highly recommend you use AnyUnlock first for its convenience and the highest success rate. All you need to do is to free download AnyUnlock and click buttons and then you will jailbreak iCloud locked iPhone and bypass activation lock in minutes. We hope it helps you out.
