Despite being an old device, the Apple iPhone 6 is one of the best devices to own out there. All thanks to the sleek design and robust security systems, iCloud Activation Lock tucked into the device. This security system is designed to protect your iPhone 6 from unauthorized access in a situation where it’s subjected to factory reset.
However, this system could sometimes pose a challenge to the real owner of a device, when you cannot remember the details used during configuration. If this is a problem you are faced with, and need a simple guide to direct you on how to bypass iCloud Activation Lock on iPhone 6, you are on the right page. The post will cover the top 3 ways to resolve iCloud activation lock on iPhone 6/6S with or without a password.
Also Read: How to unlock iPhone 6/6S passcode
As earlier stated, the iCloud Activation Lock is a security system established by Apple and tucked into its devices including iPhone 6 to prevent prying eyes access. It’s mostly triggered by a factory reset on a device with Find My enabled on it. What this means in essence is that you only get stuck on the Activation Lock screen when you subject your iPhone 6 to factory reset.
Unlock iCloud Locked iPhone
Sure, you can. Bypassing iCloud Activation Lock on your iPhone 6 is a pretty easy task to execute, regardless of whether you have your iCloud details or not. The next section of this post will focus on how you can do this.
Look through the methods recommended below and select any one that suits you to bypass iCloud Activation Lock:
AnyUnlock is a lifesaver when it comes to fixing iOS security challenges like iCloud Activation Lock. With this user-friendly software, you can bypass Activation Lock on your iPhone 6 with the snap of your finger without hassles. It doesn’t matter whether you are the real owner of the device or a secondhand user, the software removes Activation Lock and returns full control to you without requesting you to provide your credentials. Besides Activation Lock, AnyUnlock is also a wonderful tool for removing Apple ID, bypassing Face ID, removing SIM lock and more.
Key Features:
Steps to Bypass iCloud on iPhone 6 Using AnyUnlock
Start by initiating AnyUnlock installation via the official website. After that, apply the illustrative guide below to complete iCloud Activation Lock bypass on your iPhone 6:
Step 1: Run the AnyUnlock software and choose Bypass iCloud Activation Lock from the options on the quick start menu screen.
Choose Bypass iCloud Activation Lock
Step 2: Grab the iCloud-locked iPhone 6 and connect it to your computer using a workable lightning cord. Should AnyUnlock detect your connection, click Start Now on the subsequent screen that pops up.
Click on the Start Now to Go On
Step 3: Next, you will be requested to jailbreak your iPhone 6. Check the terms and conditions box and click on Jailbreak Now.
Follow the guide provided to jailbreak your device, then click on Next to proceed.
Jailbreak Your Device
Step 4: Finally, hit the Bypass Now icon on the following screen and AnyUnlock will initiate the iCloud Activation Lock bypass immediately.
Click Bypass Now Button
Kindly exercise patience till the process is finished, then disconnect your iPhone from the computer and start using it without any restriction.
iCloud Activation Lock Is Bypassed Successfully
Perhaps you purchased a second-hand iPhone 6 with iCloud Activation Lock on it and you still have a rapport with the previous owner, you can contact the person to help you bypass the security system. All he or she has to do is provide the Apple credentials signed in on the locked device and the restriction will be erased automatically.
Here’s the guide to follow to apply this method:
Another measure you could follow to reclaim control of your iCloud-locked iPhone 6 is to manipulate your DNS server to redirect the whole iCloud Activation process of your device from Apple server to another server. To apply this approach, here’s a simple guide to follow:
USA: 104.154.51.7
South America: 35.199.88.219
Europe: 104.155.28.90
Asia: 104.155.220.58
Australia and Oceania: 35.189.47.23
Others: 78.100.17.60
iCloud DNS Bypass
Having read through this post, bypassing iCloud Activation Lock on your iPhone 6 shouldn’t be a challenge. Choose and apply any of the 3 solutions recommended and get your desired result. However, mind you, the most preferred solution from the list is the one involving AnyUnlock. The software offers the quickest way to remove iCloud lock on your iPhone 6 without you having to provide any credentials. It’s worth downloading and trying out.
