Is there any easy ways to bypass iPhone 4 iCloud activation lock with ease? 3 solutions are given and 1 tip to bypass iCloud activation via only 1-click!
Are you struggling with an iPhone 4 locked to iCloud, unable to access its features due to activation lock? ‘iPhone 4 iCloud bypass’ can be a daunting task for users facing this issue, especially with older models where official support may be limited. In this comprehensive guide, we’ll explore the challenges posed by iCloud activation lock on iPhone 4, delve into the causes behind it, and provide step-by-step solutions to bypass iCloud activation and regain access to your device.
Bypass iCloud Activation Lock
The iCloud activation lock is a security feature designed by Apple to prevent unauthorized access to a lost or stolen iPhone. However, it can also lock out legitimate users who forget their iCloud credentials or inherit a locked device. For iPhone 4 users, the activation lock issue can arise when attempting to set up or reset the device without the original owner’s Apple ID and password. Here are some factors which may explain why you need to unlock iPhone iCloud:
No matter what reason you are out of when you want to get iPhone 4 iCloud bypass, here we have a collection of solutions for you.
Here are 3 effective methods to bypass iCloud activation lock on iPhone 4. Follow these detailed steps carefully to regain access to your device:
The Domain Name System (DNS) translates readable names into numeric IP addresses. It uses DNS servers to facilitate this process. If your device is iCloud locked, a method to alter its activation path involves redirecting it from Apple’s servers to an iCloud Bypass DNS server for validation.
Even if the activation screen is active and you cannot use the device, you can adjust the IP server path through Wi-Fi settings. By entering manual Wi-Fi settings and modifying the DNS address, you can perform an iCloud bypass for an iPhone 4 using DNS redirection.
Here is how you could do it:
Step 1. Insert a SIM card into the iPhone 4 and connect it to a Wi-Fi network.
Step 2. On the activation screen, select Language and Country, then tap on Next.
Step 3. On the Wi-Fi network page, tap the “i” icon next to the network you’re connected to.
Step 4. Scroll down and tap on “Configure DNS” > “Manual”.
Configure DNS Manual
Step 5. Enter one of the following DNS server addresses:
Step 6. Tap on “Back” > “Done”, then click on “Activation Help”. The iPhone 4 should now connect to the server and allow limited access to apps and features.
Step 1. Turn on your iPhone 4/4S and choose your language and region.
Step 2. On the iCloud activation screen, press the home button three times to activate Voice Command.
Step 3. Press the home button again and select Emergency Calls.
Step 4. Enter *#96274825*0000*1# and press the call button repeatedly.
Step 5. Change the last digit from 1 to 2 and press the call button again several times.
Step 6. Repeat the previous step. Follow all the instructions, then press the back button and return to the starting screen.
Step 7. Choose your language and region again. After selecting, you will bypass the iCloud activation screen.
This method is straightforward and quick, allowing you to remove your iCloud account from the iPhone 4 for free.
Step 1. Reach out to the previous owner if possible and request them to remove the device from their iCloud account.
Step 2. Once removed, perform a factory reset on the iPhone 4 to erase all data and settings.
Step 3. Set up the device again with your own iCloud credentials.
As one of the most popular and professional iCloud activation lock removal tools for iOS devices in 2024, AnyUnlock – iPhone Unlocker would be the best solution for your iOS device when it is stuck on the “Activation Lock” screen. As a complete iOS unlocking toolkit, AnyUnlock can easily meet your unlocking demands, no matter whether your iPhone is linked to an unknown Apple ID, you need to remove your Apple ID, or you forget your Apple ID email or password. By using its iCloud Activation Unlocker feature, you can easily bypass iCloud Activation Lock without Apple ID or Apple ID password. As a complete iOS unlocking software, AnyUnlock also allows you to unlock iPhone screen passcode, bypass MDM, unlock Apple ID, and unlock other iPhone passwords, quickly & effectively.
To bypass the iCloud Activation lock, please free download the AnyUnlock – iCloud Bypass Tool. AnyUnlock is compatible with both Windows PC and Mac. Here is the stepwise guide to bypass the iCloud activation lock:
Step 1. Launch AnyUnlock on your computer and choose “Bypass iCloud Activation Lock” mode directly.
Step 2. Then connect your iOS device to the computer via a USB cable. Once your device is detected, you will see the interface as below, then click on Start Now.
Connect Your iOS Device to the Computer
Step 3. Then, you will see the interface below. You can jailbreak your iOS device by yourself or use our recommended jailbreak tutorial to do it.
Jailbreak Your Device
Step 4. After you click the “Next” button on the prompt screen, you will see the interface as below. And you can view the basic info about your device. Then, please click the “Bypass Now” button.
Click Bypass Now Button
Step 5. Please wait patiently. When the bypassing process is over, you will see the interface as below.
iCloud Activation Lock Is Bypassed Successfully
Q: Can I bypass iCloud activation lock for free?
A: While some methods like DNS bypass are free, others such as using iCloud bypass tools or services may involve costs.
Q: Is iCloud bypass legal?
A: The legality of iCloud bypass methods varies by jurisdiction and Apple’s terms of service. It’s important to consider legal implications before proceeding.
Q: Will bypassing iCloud activation lock permanently unlock my iPhone 4?
A: Bypassing iCloud activation lock allows temporary access to the device. For permanent unlock, consider contacting Apple Support or the original owner.
To achieve the goal of “iPhone 4 iCloud bypass”, you can try 3 methods above. For uers who are seeking for more convenient and user-friendly method, try AnyUnlock! This tool is an all-in-one device unlock tools, offering freedom to unlock various screen passcode, Apple ID, SIM lock, bypass MDM and so on. Now try it by yourselves!
