You may wonder why a used Apple Watch is asked for Apple ID and passcode to log in, or a second-hand iPhone is bundled with an Apple Watch so that you can’t pair yours. This article will explain what Apple Watch activation lock is and how to remove activation lock on Apple Watch without effort.
“my friend gave me their watch they don’t use no more I reset it but now every time I try to pair it has activation lock and they no longer have the login information what do I do”? Someone posted on Apple Discussion.
It’s annoying to set up an Apple Watch only to find that it is prevented from logging in with the activation lock. You can remove Apple Watch activation lock as long as you enter the correct Apple ID and password. Is it possible to bypass Apple Watch activation lock without the previous Apple ID information? Yes, here we introduce 3 ways for Apple Watch activation lock removal with or without the previous Apple ID.
You may also like: Unlock Apple Watch without Passcode
Activation lock is a security feature for Apple devices to prevent personal information from any unauthorized access if they are lost or stolen. Apple Watch activation lock is included in Find My and once you have enabled the Find My function, your Apple Watch will ask for Apple ID and password when you want to do the following things.
With the activation lock enabled on your Apple Watch, your data will be protected with your Apple ID.
The Activation Lock on An Apple Watch
Also read: What Does iCloud Lock Mean >
It’s quite easy to turn on the activation lock on Apple Watch. As long as you have enabled Find My features on your iPhone, you can pair your Apple Watch and iPhone. Both your iPhone and Apple Watch will be protected with the activation lock. Check if your Apple Watch activation lock is enabled with the following steps:
Look for a Find My Apple Watch option. If you see it, your Apple Watch’s activation lock is turned on.
There are 2 ways you can try to turn off Apple Watch activation lock if you want to sell it or give it away. One is to turn off activation lock in Apple Watch app, the other is to turn off activation lock in iCloud Find My app.
Then your Apple Watch will be unpaired with your iPhone.
If you can’t access your iPhone or if your Apple Watch isn’t paired with your iPhone, you can turn off Apple Watch Activation Lock on iCloud.
Then your Apple Watch activation lock will be turned off on iCloud.
If you have bought the Apple Watch from someone as a second-hand device, or if someone has gifted it to you and it has the activation lock on it, the following methods will help you complete Apple Watch activation lock removal. Once the lock is removed, you will be able to pair the Watch with your own Apple ID and iPhone.
If you received the Apple Watch from your friend, relative or someone you know, the best choice is to ask the previous owner for help. They can use the Apple ID and password to turn off activation lock on the Apple Watch quickly and safely. Then you will be able to pair and use it with your iPhone without previous Apple ID.
Step 1. Bring both your iPhone and your Apple Watch close to each other.
Step 2. Start the Apple Watch on the iPhone, tap the My Watch, and tap on the info icon next to the locked Watch.
View The Apple Watch Details
Step 3. Select the option that says Unpair Apple Watch. This will remove the Watch from the iPhone.
Unpair An Apple Watch From The iPhone
Step 4. Enter the iCloud logins and your Watch will be removed.
The activation lock should be removed and your Apple Watch is now ready to be paired with any iPhone.
If the original Apple Watch owner cannot come and unpair your Apple Watch, or if they have lost their iPhone and they have no means to remove the Watch, they can use iCloud to remove Activation Lock and unlock Apple Watch remotely. iCloud has an online interface where you can use pretty much all the iCloud features that you use on your iOS devices.
Use iCloud to Remotely Remove Apple Watch Activation Lock
One of these online features is to find your Apple ID-linked devices, like your Apple Watch, and erase and remove Apple Watch from account. Using this method, the original owner can remotely wipe off the Watch and unpair it from their account.
Once the online unpairing process is finished, your Apple Watch will sync with Apple servers and the servers will help unlock it. That is because Apple will no longer see any iPhones that bind this Apple Watch with them. Your Watch is then free to be linked with any account. Here is how to unlock Apple Watch in this way.
To get rid of Activation Lock on Apple watch in iCloud, you can try:
Step 1. Launch your web browser and access the iCloud website. Sign in to your iCloud account.
Step 2. You should now see various options on your screen. Click the option that reads Find iPhone to view and access the settings for the locked Apple Watch.
Step 3. Click on All Devices at the top and choose your Apple Watch from the list.
Access Find iPhone on iCloud
Step 4. On the following screen, click the Erase Apple Watch option followed by Remove from Account.
Your Apple Watch will be wiped off and removed from the original owner’s account. It can then be associated with your own Apple ID.
You may wonder if it’s possible to bypass activation lock on Apple Watch without the Apple ID and password. Yes, some activation unlock tools are available to remove Apple Watch activation lock. Here we introduce the Apple iPhone Unlock service. You can check the following steps to bypass Apple Watch Activation Lock without Apple ID.
Step 1. Open the Apple iPhone Unlock website in one of the browsers on your computer.
Step 2. Find the serial number written on the case of your Apple Watch and note it down.
Step 3. Enter the serial number on the site you have opened, select your Apple Watch from the dropdown menu, and click on Remove Activation Lock.
Remove The Apple Watch Activation Lock Online
Step 4. Proceed further, make a payment, and your order will be confirmed.
In a few days, you will receive an email saying that your Apple Watch is unlocked and you can use it with your account.
With the above methods, you may successfully solve how to remove activation lock on Apple Watch. Besides, you may also need to get rid of activation lock on your iPhone or iPad. A complete solution to iOS locks, AnyUnlock – One-stop iPhone Unlocker, comes for you.
Acting as a professional iCloud Activation Unlocker, AnyUnlock is developed to help you get rid of Activation Lock on iPhone without Apple ID or password. There are no technical requirements to use this tool and the whole unlocking process only takes a few minutes. Now, Windows PC and Mac computers are all supported. In addition, locks like screen lock, Apple ID, MDM lock, SIM lock, etc. can be unlocked by AnyUnlock as well.
The whole unlocking process is simple and easy to follow:
Step 1. Free download and install AnyUnlock on your computer > Choose Bypass iCloud Activation Lock option.
Click on Start Now to Bypass iCloud Activation Lock
Step 2. Connect your iPhone and click Start Now > Tap on Jailbreak Now button to jailbreak your device > Once jailbroken, click Next.
Jailbreak Your Device
Step 3. Click on Bypass Now and the activation bypass process will start immediately.
Bypassing iCloud Activation Lock
Step 4. Wait for a while and iCloud activation lock is bypassed successfully. Click Done to complete.
iCloud Activation Lock Is Bypassed Successfully
Step 1. Get AnyUnlock for free on your Mac > Tap on Bypass iCloud Activation Lock option on the bottom > Connect your iPhone, iPad, or iPod touch to the computer.
Step 2. Once your iOS device is connected to the computer, click on the Start Now tab start the unlocking process.
Click on the Start Now to Go On
Step 3. Wait until AnyUnlock has finished downloading the jailbreak tool.
Download the Jailbreaking Tool
Step 4. Put your iOS device into DFU mode when the jailbreak tool is well-prepared. And then it will move to the jailbreak process. When the jailbreak process is finished, you are expected to click on Bypass Now to bypass the activation lock from your iPhone/iPad/iPod touch.
Tap on Bypass Now to Start Bypassing
In a word, you can remove Apple Watch activation lock with the help of its previous owner, through iCloud or using a third-party tool. Kindly choose the way you’d like to use for Apple Watch activation lock removal. Moreover, you are recommended to bypass iPhone activation lock with AnyUnlock. Download AnyUnlock now and remove any password in your iPhone, iPad or iPod Touch.
