How to set up Vozard on XBOX?
The following instructions will help you set up Vozard on XBOX.
Launch Vozard, then open XBOX.
Firstly, please open the Xbox Game Bar on your computer.
Open the XBOX Game Bar
Then, please switch to the VOICE option in the Audio panel. Go to Audio > Voice.
Switch the VOICE
Finally, please select Vozard Microphone from the Windows DefaultInput setting drop-down list.
Select Vozard Microphone
Then, you can use Vozard on XBOX successfully
1. This function needs to turn off noise reduction.
2. This function is only compatible with Windows OS.
3. If you still have questions after reading this post, please contact our Support Team for further help. We are here to help you!
iMobie Self-Service
End conversation
Share Your Feedback with Us
Select Feedback Method:
Please enter a valid email address
