OK, got it
Button with music note
How to Remove Encrypted iPhone Backup in iTunes?
Since Apple values user's privacy, it won't let iMobie product detect user's encrypted backup. There are three influenced iMobie products: AnyTrans, PhoneClean and PhoneRescue fo iOS.
Thus, customers will fail to finish backup process when using these products. To fix this issue, you can turn off iTunes backup encryption option temporally. Well, how to uncheck encrypt local backup on iTunes? Please refer to detailed instructions to remove encrypted backup option in iTunes.
Step 1: Connect your iOS device to computer and open iTunes.
How to Remove Encrypted iPhone Backup Option in iTunes- Step 1
Step 2: Click your device icon in the interface of iTunes.
How to Remove Encrypted iPhone Backup Option in iTunes- Step 2
Step 3: Uncheck Encrypt local Backup option and then you will see a pop-up box.
How to Remove Encrypted iPhone Backup Option in iTunes- Step 3
Step 4: Enter the password to unlock your iPhone backup and click on OK.
How to Remove Encrypted iPhone Backup Option in iTunes- Step 4
Note: If you unfortunately forgot your iTunes backup password, you will fail to uncheck your encrypt backup option in iTunes. Please try all possible passwords or turn to some  iTunes backup password unlocker software to get it back.
Step 5: After that, iTunes will backup your device once again. Then you’ll see the option of “Encrypt iPhone Backup” is unchecked when the backing up process is finished.
How to Remove Encrypted iPhone Backup Option in iTunes- Step 5
Did you find this article helpful?
+1Yes+1NoYou have given a feedback, thank you.
Still Have Troubles? Leave a Comment Here to Ask for Help
Cell phone home screen
#1 iPhone Backup Extractor That Saves Everything for You
Download Now Buy Now 60 Days Money Back Guarantee Blue circle with letter A
