Free Download See Pricing
User Guide of DroidKit
View the most comprehensive guides to Remove Locked Screen, Bypass FRP Lock, Recover Lost Data, Fix System Issues, Extract Needed Data, Reinstall/Upgrade OS, Transfer Data and Clean System Junk. Download and try it now.
See PricingView Suitable Price Plan
Transfer ZIP Files
“Can you help me to add zipped files from computer to my android phone?”
“I need to transfer zipped files from my android phone to computer. Any suggestion?”
If you encounter the similar situations above, don’t worry. DroidKit comes to help you manage ZIP files easily, including transferring ZIP files from device to computer, adding ZIP files from computer to your Android device, and even deleting unwanted ones with a few clicks. Please refer to the following guide to make good use of DroidKit.
Select “Recover from iOS Device” Mode
Compatibility of Computer System
Windows OS Windows 11, 10, 8, 7, Vista (both 32bit and 64bit)
macOS macOS 10.13 (High Sierra) and above
Supported Device System
All Android Devices with Android Version 5 and above.
Supported Device Type
Android phones and tablets of all manufacturers in the market, such as SAMSUNG, Google, HTC, SONY, LG, MOTOROLA, HUAWEI, ZTE, Xiaomi, OPPO, SHARP, ViVo, LENOVO, MEIZU, OnePlus, TCL, Gionee, Meitu, Nubia, Smartisan, etc.
Differencesbetween Free & Registered Version
Benefits Free Version Pro Version
Transfer ZIP Files 50 items Unlimited
Step 1. Download DroidKit on Your Computer.
Before you start the transfer, get the tool downloaded onto your computer. Please make sure the network is stable while downloading and installing DroidKit on your computer.
Step 2. Connect Your Android Device to the Computer via a USB Cable.
Please launch DroidKit on your computer and choose Device Manager mode under Data Manager function.
Select Data Manager Mode
Then, please click “Start” button.
Start Data Manager
Start Data Manager
Please connect Android device to computer via the USB cable, and make sure you have enabled USB debugging option on your device. By default, DroidKit will detect your Android device automatically. Once your device is detected, you will see the interface below.
Your Device Is Detected
If DroidKit is unable to recognize your Android device with USB cable, you may try these troubleshooting steps to solve this problem
Step 3. Select ZIP Files You Want to Transfer.
After the loading process completes, it will display the total number of ZIP files under the ZIP Files icon. If it shows empty in the ZIP Files icon, it indicates that there is no ZIP file on your Android device. Then please click ZIP Files icon and select the ZIP files you want to transfer.
Select the File You Want
Step 4. Wait for Transferring ZIP Files.
Please select the ZIP files you want to transfer. And you can click To PC button to download them to your computer. You also can:
Search: Search the ZIP files you need.
Refresh: Refresh the interface to load ZIP files.
Delete: Delete the unwanted ZIP files.
Add: Add new ZIP files from computer to device.
To Device: Transfer the ZIP files to another Android device.
Manage Zipped Files
Manage Zipped Files
Step 5. Succeed to Transfer ZIP Files.
You will see Transferred Successfully interface when transferring process completes. To locate zip files exported on computer, please click View files button. If you want to transfer more items, please click Transfer more button.
Transfer Succeed
Transfer Succeed
After clicking View files option, you can check the ZIP files, which are transferred from Android device to computer. Please see the interface below:
View the Transferred ZIP Files
If you still have questions after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
