Free Download See Pricing
User Guide of DroidKit
View the most comprehensive guides to Remove Locked Screen, Bypass FRP Lock, Recover Lost Data, Fix System Issues, Extract Needed Data, Reinstall/Upgrade OS, Transfer Data and Clean System Junk. Download and try it now.
See PricingView Suitable Price Plan
Transfer Videos
We would like to share some problems we collected about transferring videos:
“Can you help me transfer the videos from my Android phone to computer?”
“I want to add videos from computer to my Android phone. Can DroidKit help me?”
If you encounter the similar situations above, don’t worry. “Transfer Videos” mode can help you to transfer videos from your Android device to computer, add videos from computer to device, and even delete unwanted videos. Please refer to the detailed guide to make good use of DroidKit.
Select “Recover from iOS Device” Mode
Compatibility of Computer System
Windows OS Windows 11, 10, 8, 7, Vista (both 32bit and 64bit)
macOS macOS 10.13 (High Sierra) and above
Supported Android Versions
All Android Devices with Android Version 5 and above.
Supported Android Brands
SAMSUNG, Google, HTC, SONY, LG, MOTOROLA, HUAWEI, ZTE, Xiaomi, OPPO, SHARP, ViVo, LENOVO, MEIZU, OnePlus, TCL, Gionee, Meitu, Nubia, Smartisan, etc.
Differences between Free & Activated Version
Benefits Free Version Pro Version
Transfer Videos Transfer 50 items Unlimited
Step 1. Download DroidKit on Your Computer.
Before you start transferring videos, get the tool downloaded onto your computer. Please make sure the network is stable while downloading and installing DroidKit on your computer.
Step 2. Choose Data Manager Mode.
Please launch DroidKit on your computer and choose Device Manager mode under Data Manager function.
Step 3. Connect Your Android Device to the Computer via a USB Cable.
After you choose the function you want to use, you can connect Android device to computer with USB cable (This guide uses the Samsung device as an example.). Please make sure you have launched USB debugging option on your Android device. By default, DroidKit will detect your Android device automatically. If you don’t connect your Android device to computer or your Android device isn’t recognized, you will view the interface as below:
Please Connect Your Android Device
Once your device is detected, you will see the interface below.
Your Device is Detected
If DroidKit is unable to recognize your Android device with USB cable, you may try these troubleshooting steps to solve this problem.
Step 4. Select the Videos You Want to Transfer.
After the loading process completes, it will show you the total number of videos. If it shows empty in videos icon, it indicates that there is no any videos in device. Please select the videos you want to transfer. And you can click To PC button to download them to your computer. You also can:
Search: Search the videos you need.
Refresh: Refresh the interface to load videos.
Delete: Delete the unwanted videos.
Add: Transfer videos from computer to device.
To Device: Transfer videos to another Android device.
Change Preview Mode: Change the display mode for better management of videos.
Select Videos
Select Videos
Step 5. Start to Transfer Videos.
Now, the transfer will start. The time to export the videos varies from data size. Please wait patiently.
Transferring Process
Step 6. Succeed in Transferring Videos.
Once the transferring process is completed, you will see Transfer Completed interface. To locate the data exported on computer, please click View files option. If you want to continue to transfer the data, please click Transfer more button.
Transfer Completed
Transfer Completed
After clicking View files option, you can check the videos, which are transferred from Android device to computer. Please see the interface below:
View the Transferred Videos
