View the most comprehensive guides to Remove Locked Screen, Bypass FRP Lock, Recover Lost Data, Fix System Issues, Extract Needed Data, Reinstall/Upgrade OS, Transfer Data and Clean System Junk. Download and try it now.
“My Android phone is out of memory. I need to transfer all my messages to the computer. Can you help me?”
“There are thousands of messages on my Android device. Is there a way I can delete them quickly?”
If you just encounter the similar issue above, don't worry. You can try “Data Manager” mode to manage your messages on Android device. The following instructions will help you do it.
Windows OS | Windows 11, 10, 8, 7, Vista (both 32bit and 64bit) |
macOS | macOS 10.13 (High Sierra) and above |
All Android Devices with Android Version 5 and above. |
Most common brands available in the market, like SAMSUNG, Google, HTC, SONY, LG, MOTOROLA, HUAWEI, ZTE, Xiaomi, OPPO, SHARP, ViVo, LENOVO, MEIZU, OnePlus, TCL, Gionee, Meitu, Nubia, Smartisan, etc. |
Feature | Free Trial | Full Version |
Transfer Messages | Transfer 50 items | Unlimited |
Download and install DroidKit on your computer. Please make sure the network is stable while downloading and installing DroidKit on your computer.
Please launch DroidKit on your computer and choose Device Manager mode under Data Manager function, and click Start button.
Choose Data Manager Mode
Then connect your device to computer with the USB cable. Please make sure you have launched USB debugging option on your Android device (Take Samsung device as an example). By default, DroidKit will detect your Android device automatically. If you don't connect your Android device to computer or your device is not recognized, you will see the interface below:
Connect your Device
If DroidKit is unable to recognize your Android device, you may try these troubleshooting to solve this problem.
After the loading process is completed, it will display the total number of messages under the Messages icon. If it shows empty under the Messages icon, it indicates that there is no message in Android device. Then please click the Messages option.
Select Messages
Please select the messages you want to transfer. And you can click To PC button to download them to your computer. You also can:
Search: Search the messages you need.
Refresh: Refresh the interface to load messages.
Delete: Delete the unwanted messages.
To Device: Transfer the messages to another Android device.
Manage Your Messages
Once the transferring process is completed, you will see Transferred Successfully page. To locate messages exported on computer, please click View files button. To transfer more messages, please click Transfer more button.
Transfer Completed
After clicking View files option, you can check the messages, which are transferred from Android device to computer. Please see the interface below:
View the Transferred Messages
