View the most comprehensive guides to Remove Locked Screen, Bypass FRP Lock, Recover Lost Data, Fix System Issues, Extract Needed Data, Reinstall/Upgrade OS, Transfer Data and Clean System Junk. Download and try it now.
“How can I transfer Android device documents easily and fast?”
“I have some documents and I want to transfer to my computer, any suggestions?”
If you just encounter the similar issue above, don't worry. You can try “Transfer Document” mode to transfer documents with a few clicks. The following instructions will help you do it.
Windows OS | Windows 11, 10, 8, 7, Vista (both 32bit and 64bit) |
macOS | macOS 10.13 (High Sierra) and above |
Android phones and tablets of all manufacturers in the market, such as SAMSUNG, Google, HTC, SONY, LG, MOTOROLA, HUAWEI, ZTE, Xiaomi, OPPO, SHARP, ViVo, LENOVO, MEIZU, OnePlus, TCL, Gionee, Meitu, Nubia, Smartisan, etc. |
All Android Devices with Android Version 5 and above. |
Benefits | Free Version | Pro Version |
Transfer Document | Transfer 50 items | Unlimited |
Before you start the data transfer process, get the tool downloaded onto your computer. Please make sure the network is stable while downloading and installing DroidKit on your computer.
After downloading and installing DroidKit on your computer successfully, please launch DroidKit on your computer and choose Device Manager mode under Data Managerfunction, and click Start button.
Choose Data Manager Mode
After you choose the function you want to use, you can connect Android device to computer with USB cable. Please make sure you have launched USB debugging option on your Android device. By default, DroidKit will detect your Android device automatically. If you don’t connect your Android device to computer or your Android device isn’t recognized, you will view the interface as below:
Connect Your Android Device
Once your device is detected, you will see the interface below.
Succeed to Connect Your Device
If DroidKit is unable to recognize your Android device, you can try to fix this issue by following troubleshooting steps:
1. Check whether you are using the latest version of DroidKit. If not, please download it from our website.
2. Check if you have enabled USB debugging option in Settings.
3. Reconnect the Android device or give another USB cable a try.
4. Please make sure your Android device can be detected by the computer.
5. Check whether you have the latest version of USB Driver and ADB Driver on your computer and device. If not, download and update from your Android device official website.
After the loading process completes, it will display the total number of document under the Document icon. If it shows empty in Document icon, it indicates that there is no any document on your Android device. Then please click Document icon.
Choose the Document Option
Please select the documents you want to transfer. And you can click To PC button to download them to your computer. You also can:
Search: Search the documents you need.
Refresh: Refresh the interface to load document.
Delete: Delete the unwanted document.
Add: Transfer document from computer to device.
To Device: Transfer the document to another Android device.
Choose the Document You Want to Transfer
Once the transferring process is completed, you will see Transferred Successfully interface. If you want to locate the exported documents, please click View files button. To transfer more items, please click Transfer more button. To go back to the Home Page, please click Home Page button.
Succeed to Transfer Document
After clicking View files, you can check the documents which are transferred from Android device to computer. Please see the interface below:
View the Transferred Documents
