View the most comprehensive guides to Remove Locked Screen, Bypass FRP Lock, Recover Lost Data, Fix System Issues, Extract Needed Data, Reinstall/Upgrade OS, Transfer Data and Clean System Junk. Download and try it now.
“I want to transfer photos from computer to my android device. Can you help?”
“ Help! How to add my computer data to my Samsung device?”
If you encounter the similar situations above, don’t worry. With "Add Content" mode, you can transfer data from computer to Android device with a few clicks. Please refer to the following guide to make good use of DroidKit.
Windows OS | Windows 11, 10, 8, 7, Vista (both 32bit and 64bit) |
macOS | macOS 10.13 (High Sierra) and above |
All Android Devices with Android Version 5 and above. |
Android phones and tablets of all manufacturers in the market, such as SAMSUNG, Google, HTC, SONY, LG, MOTOROLA, HUAWEI, ZTE, Xiaomi, OPPO, SHARP, ViVo, LENOVO, MEIZU, OnePlus, TCL, Gionee, Meitu, Nubia, Smartisan, etc. |
APK files, Contacts, Zip files, Documents, Books, Audio, Photos, Videos |
Benefits | Free Version | Pro Version |
Add Data from Computer to Android | 50 items | Unlimited |
Before you start the transfer, get the tool downloaded onto your computer. Please make sure the network is stable while downloading and installing DroidKit on your computer.
Please launch DroidKit on your computer and choose Device Manager mode under Data Manager function.
Select Data Manager Mode
Then, please click “Start” button.
Start Data Manager
Please connect Android device to computer via the USB cable, and make sure you have enabled USB debugging option on your device. By default, DroidKit will detect your Android device automatically. Once your device is detected, you will see the interface below.
Your Device Is Detected
If DroidKit is unable to recognize your Android device with USB cable, you may try these troubleshooting steps to solve this problem.
After clicking Add Content button, a window will pop out for you to add files from computer to Android device. If the files can be transferred, they will show as selectable. If not, the files will show as grey.
Select the Data You Want to Tranfer
The time to transfer contents varies based on the size of your contents. Please keep patient. Meanwhile, given the importance of your data, please do not disconnect your Android device before finishing transferring process for avoiding any possibility of data loss.
Wait for the Transferring Process.
When the transfer process was completed, the interface below will display.
Transfer Succeed
If you still have questions after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
