View the most comprehensive guides to Remove Locked Screen, Bypass FRP Lock, Recover Lost Data, Fix System Issues, Extract Needed Data, Reinstall/Upgrade OS, Transfer Data and Clean System Junk. Download and try it now.
“How can I transfer Android data to my computer easily and fast?”
“I want to transfer my data from my Android device to my current computer. Any suggestions?”
If you just encounter the similar issue above, don't worry. You can try “Export Content” mode to transfer Android data to computer with a few clicks. The following instructions will help you do it.
Windows OS | Windows 11, 10, 8, 7, Vista (both 32bit and 64bit) |
macOS | macOS 10.13 (High Sierra) and above |
Android phones and tablets of all manufacturers in the market, such as SAMSUNG, Google, HTC, SONY, LG, MOTOROLA, HUAWEI, ZTE, Xiaomi, OPPO, SHARP, ViVo, LENOVO, MEIZU, OnePlus, TCL, Gionee, Meitu, Nubia, Smartisan, etc. |
All Android Devices with Android Version 5 and above. |
Personal Info | Document, ZIP Files, APK Files, Apps |
Media Data | Photos, Audio, Videos, Ringtones |
Benefits | Free Version | Pro Version |
Export Data from Android to Computer | Transfer 50 items | Unlimited |
Before you start the Android data transfer process, get the tool downloaded onto your computer. Please make sure the network is stable while downloading and installing DroidKit on your computer.
After downloading and installing DroidKit on your computer successfully, please launch DroidKit on your computer and choose Device Manager mode under Data Manager function. After that, please click Start button and connect your device with the USB cable.
Connect Your Android Device to Computer
Once your device is detected, you will see the interface below.
Succeed to Connect Your Device
If DroidKit is unable to recognize your Android device, you can try to fix this issue by following troubleshooting steps:
1. Check whether you are using the latest version of DroidKit. If not, please download it from our website.
2. Check if you have enabled USB debugging option in Settings.
3. Reconnect the Android device or give another USB cable a try.
4. Please make sure your Android device can be detected by the computer.
5. Check whether you have the latest version of USB Driver and ADB Driver on your computer and device. If not, download and update from your Android device official website.
The supported file category will be loaded automatically. DroidKit only lists the file icon for you to select when your Android device has such file types. Please choose file category you want to transfer(Including photos, videos, messages, etc.).
Choose File Category to Transfer
Then, please click Start button to start the transfer process.
Click Start Button to Transfer Data
After clicking Start button, the transfer will be started. The time to transfer contents varies based on the size of your contents. Please keep patient. Meanwhile, to improve the success rate of transferring Android data to computer, please do not disconnect your Android device before finishing transferring process.
Wait for the Transferring Process
When the transfer was completed, the interface below will display. You can click View files button to locate data exported on computer and Transfer more button to go back to the previous interface.
Succeed to Transfer Android Data
After clicking View files, you can check the data which are transferred from Android device to computer. Please see the interface below:
View the Transferred Android Data
