Free Download See Pricing
User Guide of DroidKit
View the most comprehensive guides to Remove Locked Screen, Bypass FRP Lock, Recover Lost Data, Fix System Issues, Extract Needed Data, Reinstall/Upgrade OS, Transfer Data and Clean System Junk. Download and try it now.
See PricingView Suitable Price Plan
Transfer Data from Android to Android
“How to transfer musics from my Samsung A71 to my Huawei device?”
“I’d like to transfer all messages between my Android devices. Could you please give me the user guide?”
If you just encounter the similar issue above, don't worry. You can try “Android to Android” mode to transfer data between Android devices. The following instructions will help you do it.
Select “Recover from iOS Device” Mode
Compatibility of Computer System
Windows OS Windows 11, 10, 8, 7, Vista (both 32bit and 64bit)
macOS macOS 10.13 (High Sierra) and above
Supported Android Versions
All Android Devices with Android Version 5 and above
Supported Android File Types
Media Data Music, Audios, Videos, Ringtones
Personal Info Contacts, Messages, Call Log, Calendar, Document, APK Files, Zipped Files, Apps
Photos Photos
Differences between Trial Version & Activated Version
Benefits Trial Version Activated Version
Transfer Data between Android Devices
Step 1. Download DroidKit on Your Computer.
Before you start transferring process, get the tool downloaded onto your computer. Please make sure the network is stable while downloading and installing DroidKit on your computer.
Step 2. Choose Data Manager Mode.
Please launch DroidKit on your computer and choose Data Manager mode. Then, please choose the Android Mover option.
Choose Android Mover Option
After that, you will see the Android Mover interface like below. Please choose Android to Android and click Migrate Now option.
Choose Android to Android Option
Step 3. Connect Your Android Devices to the Computer.
After you choose the function you want to use, you can connect Android devices to computer with USB cable. Please make sure you have launched USB debugging option on your Android devices. By default, DroidKit will detect your Android devices automatically. If you don’t connect your Android devices to computer or your Android devices are not recognized, you will view the interface as below:
Please Connect Your Android Devices
Once your devices are detected, you will see the interface below. Then, please click Migrate Now button.
Succeed to Connect Your Devices
If DroidKit is unable to recognize your Android device with USB cable, you may try these troubleshooting steps to solve this problem.
Step 4. Choose File Category You Want to Transfer.
After clicking Migrate Now option, DroidKit will load all your files in source Android phone automatically. If it shows no data beside category icons, that means there is no such files in your source Android phone.
Load Data Type in Android to Android Option
After the loading process is completed, please choose the file category you want to transfer and click Next button.
Choose the File Category
Step 5. Wait for the Transferring Process.
After clicking Next button, the transferring process will be initiated. The transferring time may vary based on the size of your selected data. Please keep patient to wait for the transfer process.
Transferrring Data between Android Devices
Step 6. Complete the Transferring Process.
Once the transferring process is completed, you will see Transferred Successfully page.
Transfer Completed
Transfer Completed
If you still have questions after reading this guide, please refer to FAQs page to check more solutions. Or you can contact our Support Team to get further help. We are here to help you!
