View the most comprehensive guides to Remove Locked Screen, Bypass FRP Lock, Recover Lost Data, Fix System Issues, Extract Needed Data, Reinstall/Upgrade OS, Transfer Data and Clean System Junk. Download and try it now.
“I need to view my calendar on my Android device via the PC.”
“Can you help me transfer the calendar from my Samsung to the computer?”
If you just encounter the similar issue above, don't worry. You can try “Data Manager” mode to manage your calendar on Android device. The following instructions will help you do it.
Windows OS | Windows 11, 10, 8, 7, Vista (both 32bit and 64bit) |
macOS | macOS 10.13 (High Sierra) and above |
All Android Devices with Android Version 5 and above. |
Most common brands available in the market, like SAMSUNG, Google, HTC, SONY, LG, MOTOROLA, HUAWEI, ZTE, Xiaomi, OPPO, SHARP, ViVo, LENOVO, MEIZU, OnePlus, TCL, Gionee, Meitu, Nubia, Smartisan, etc. |
Feature | Free Trial | Full Version |
Transfer Calendar | Transfer 50 items | Unlimited |
Download and install DroidKit on your computer. Please make sure the network is stable while downloading and installing DroidKit on your computer.
Please launch DroidKit on your computer and choose Device Manager mode under Data Manager function, and click Start button.
Choose Data Manager Mode
Then connect your device to computer with the USB cable. Please make sure you have launched USB debugging option on your Android device (Take Samsung device as an example). By default, DroidKit will detect your Android device automatically. If you don't connect your Android device to computer or your device is not recognized, you will see the interface below:
Connect Your Device
If DroidKit is unable to recognize your Android device, you may try these troubleshooting to solve this problem.
After the loading process is completed, it will display the total number of calendar under the Calendar icon. If it shows empty in the Calendar icon, it indicates that there is no calendar in Android device. Then please click the Calendar option.
Select Calendar
Please select the calendar you want to transfer. And you can click To PC button to download them to your computer. You also can:
Search: Search the calendar you need.
Refresh: Refresh the interface to load calendar.
Delete: Delete the unwanted calendar.
Create: Create new calendar.
To Device: Transfer the calendar to another Android device.
Manage Your Calendar
And you can also edit your calendar with DroidKit.
Edit Your Calendar
Once the transferring process is completed, you will see Transferred Successfully page. To locate calendar exported on computer, please click View files button. To transfer more calendar, please click Transfer more button.
Transfer Completed
After clicking View files option, you can check the calendar, which is transferred from Android device to computer. Please see the interface below:
View the Transferred Calendar
