View the most comprehensive guides to Remove Locked Screen, Bypass FRP Lock, Recover Lost Data, Fix System Issues, Extract Needed Data, Reinstall/Upgrade OS, Transfer Data and Clean System Junk. Download and try it now.
“Can DroidKit help me add the books to my Android device?”
“I am trying to transfer Android books to my computer. Can you help me?”
If you encounter the similar situations above, don’t worry. “Transfer Books” mode can help you to transfer books from your Android device to computer, add books from computer to device, and even delete unwanted books. Please refer to the detailed guide to make good use of DroidKit.
Windows OS | Windows 11, 10, 8, 7, Vista (both 32bit and 64bit) |
macOS | macOS 10.13 (High Sierra) and above |
All Android Devices with Android Version 5 and above. |
SAMSUNG, Google, HTC, SONY, LG, MOTOROLA, HUAWEI, ZTE, Xiaomi, OPPO, SHARP, ViVo, LENOVO, MEIZU, OnePlus, TCL, Gionee, Meitu, Nubia, Smartisan, etc. |
Benefits | Free Version | Pro Version |
Transfer Books | Transfer 50 items | Unlimited |
Before you start transferring books, get the tool downloaded onto your computer. Please make sure the network is stable while downloading and installing DroidKit on your computer.
Please launch DroidKit on your computer and choose Device Manager mode under Data Manager function, and click Start button.
Choose Data Manager Mode
After you choose the function you want to use, you can connect Android device to computer with USB cable (This guide uses the Samsung device as an example.). Please make sure you have launched USB debugging option on your Android device. By default, DroidKit will detect your Android device automatically. If you don’t connect your Android device to computer or your Android device isn’t recognized, you will view the interface as below:
Please Connect Your Android Device
Once your device is detected, you will see the interface below. After the loading process completes, it will show you the total number of books. If it shows empty in books icon, it indicates that there is no any books in device. Please choose Books category.
Your Device is Detected
If DroidKit is unable to recognize your Android device with USB cable, you may try these troubleshooting steps to solve this problem.
Please select the books you want to transfer. And you can click To PC button to download them to your computer. You also can:
Search: Search the books you need.
Refresh: Refresh the page.
Delete: Delete the unwanted books.
Add: Add the books to device.
To Device: Transfer the books to another Android device.
Select Books
Once the transferring process is completed, you will see Transferred Successfully interface. To locate the data exported on computer, please click View files option. If you want to continue to transfer the data, please click Transfer more button.
Transfer Completed
After clicking View files option, you can check the books, which are transferred from Android device to computer. Please see the interface below:
View the Transferred Books
