View the most comprehensive guides to Remove Locked Screen, Bypass FRP Lock, Recover Lost Data, Fix System Issues, Extract Needed Data, Reinstall/Upgrade OS, Transfer Data and Clean System Junk. Download and try it now.
We would like to share some problems we collected.
“How to reinstall my android operating system?”
“How to update Android version? Is there any way?”
If you encounter the similar situations above, don’t worry. “System Reinstall” mode can help you reinstall or upgrade Android OS. Please refer to the detailed instructions to reinstall or upgrade Android OS easily.
Windows OS | Windows 11, 10, 8, 7, Vista (both 32bit and 64bit) |
macOS | macOS 10.13 (High Sierra) and above |
Windows system | All Samsung Devices with Android Version 5 and above. |
macOS system | Samsung Devices with Android Version 11 below |
Benefits | Free Version | Pro Version |
Auto-match Firmware | ![]() |
Download Firmware Package | ![]() |
Reinstall/Upgrade OS | 3 (times) | Unlimited |
Download and install DroidKit on your computer. Then, launch DroidKit on your computer and choose “System Reinstall” mode.
Choose“Reinstall/Upgrage OS” Mode
Then, please click “Start” button.
Click Start Button to Reinstall or Upgrade OS
It will automatically match the right system version once your device is connected. Please choose a version to download.
Access And Display All Androd Versions from Samsung Background
Then, it will start to download firmware. Please make sure the network is stable during the process. It will take some time. Please keep patient.
Wait for Downloading Firmare
After the download proces completes, you can see the interface below. Please click “Start to Reinstall” button.
Downloading Firmare Complete
Please follow instructions to put your device in Download mode.
Phone without Home Button:
1. Power off the phone or tablet.
2. Press and hold the Volume Up and Power buttons at the same time for more than 5 seconds.
3. When the warning screen appears, press Volume Up button to continue.
Follow Instructions to Put Your Device into Download Mode
Phone with Home Button:
2. Press and hold the Volume Down, Home, and Power buttons for more than 5 seconds.
3. Release all the buttons when you see download mode interface.
After putting your device in download mode, please click “Next” button. Then our software will ask you to disconnect and reconnect your device to computer and put your device to the Download mode again.
Put Your Device in Download Mode Again
The process may take some time. Please keep patient. Please keep your device connected stably.
Reinstall Android Version on Your Samsung Device.
When the reinstallation process completes, you will see the interface below. And your device will be restarted.
System Reinstallation Completed
