View the most comprehensive guides to Remove Locked Screen, Bypass FRP Lock, Recover Lost Data, Fix System Issues, Extract Needed Data, Reinstall/Upgrade OS, Transfer Data and Clean System Junk. Download and try it now.
We would like to share some problems we collected about SD Card recovery.
“Please help! I want to recover data from a SD card. I've specifically trying to grab a few photos.”
“The SD card is from 8 months ago in Vietnam- I wasn't at any place to where I could sit down and figure out the best method for recovery.”
“I just deleted data on my SD card (photos) accidentally.”
If you encounter the similar situations above, don’t worry. “Data Recovery from SD Card” mode can help you recover deleted data on your SD card. Please refer to the detailed instructions to recover SD Card data easily.
Windows OS | Windows 11, 10, 8, 7, Vista (both 32bit and 64bit) |
macOS | macOS 10.13 (High Sierra) and above |
FAT32, FAT16, exFAT |
Standard Recovery | Quickly scan and recover data deleted by mistake in the shortest time. |
Advanced Recovery | Fully scan to recover lost/format data with the highest success rate. |
Benefits | Free Version | Pro Version |
Scan SD Card Data | ![]() |
Preview SD Card Data | ![]() |
Recover SD Card Data | ![]() |
Download and install DroidKit on your computer. Then, launch DroidKit on your computer and choose “Data Recovery from SD Card” mode.
Choose “Data Recovery from SD Card” Mode
Then, please connect your SD card to the computer. Please get your SD card connected: using a card reader.
Get Your SD Card Connected: Using a Card Reader
DroidKit provides two modes for SD card recovery. You can try the “Standard Recovery” mode first. If you can't find what you want, you can try the “Advanced Recovery” mode later. Using “Standard Recovery” mode, you can choose to scan for only deleted files or scan for all files on your SD card. “Advanced Recovery” mode will help you find more complete files.
Take “Standard Recovery” for an example. Please select “Standard Recovery” mode and then please click “Next” Button.
Select a Recovery Mode to Scan Your SD Card
You will see the interface below. Please continue to click “Next” button.
Select SD Card to Recover Data
Using “Standard Recovery” mode, you can choose to scan for only deleted files or scan for all files on your SD card. The time to scan SD card varies based on the size of data. Please keep patient.
Wait for the Scanning Process
After the scanning process, all found files will be displayed in categories. From the left sidebar, you can click different data types to display the corresponding results. You can selectively check or un-check the files and then click "To PC" to start the data recovery process.
Preview And Recover Data from Your SD Card
The scanned data can only be restored to PC instead of SD Card itself currently because of SD Card principles. If you want to transfer data recovered to Android device, you can give Data Manager a try.
