Free Download See Pricing
User Guide of DroidKit
View the most comprehensive guides to Remove Locked Screen, Bypass FRP Lock, Recover Lost Data, Fix System Issues, Extract Needed Data, Reinstall/Upgrade OS, Transfer Data and Clean System Junk. Download and try it now.
See PricingView Suitable Price Plan
Extract SIM Card Data
We would like to share some problems we collected about SIM card.
“I lost my phone Contacts unexpectedly. It was terrible situation for me without my contact list of 150+.”
“I lost contacts on my Samsung device. Is there any way to find device contacts back?”
If you encounter the similar situations above, don’t worry. “Data Extractor From SIM Card” mode can help you recover contacts stored on SIM Card and extract them to computer or device with 1 click.
Compatibility of Computer System
Windows OS Windows 11, 10, 8, 7, Vista (both 32bit and 64bit)
macOS macOS 10.13 (High Sierra) and above
Supported Device Types
Most common brands available in the market, like Huawei, Samsung, Vivo, Google, Oppo, Xiaomi, Sony, LG, Motoria, etc. with Android Version 5 and above..
Supported File Types
Only Contacts (with Number/Email/Address)
Differences between Free & Activated Version
Benefits Free Version Pro Version
Scan SIM Card Data
Preview SIM Card Data
Step 1. Select “Data Extractor From SIM Card” Mode.
Download and install DroidKit on your computer. Then, launch DroidKit on your computer and choose “Data Extractor From SIM Card” mode.
Select “ Data Extractor From SIM Card” Mode
Then, please click “Start” button.
Click “Start” Button
Step 2. Connect Your Android Device with SIM Card to Computer.
Connect your Android device with SIM card to the computer via following the steps below:
1. Connect your Android device to the computer with a USB cable.
2. Please confirm the USB debugging mode is enabled on your device.
3. Select the MTP/PTP mode on your device.
Once your SIM card is detected, you will see the interface below. Meanwhile, please turn on recovery permission on your phone. Then, please click “Start” button.
SIM Card Is Detected on Your Device
Step 3. Scan out the Contacts on Your SIM Card.
DroidKit will scan out the contacts stored on your SIM card automatically. Just be patient. Precious things are always worth waiting for.
Step 4. Preview the Data Scanned out from SIM Card.
After completing the scanning process, you can preview the data scanned out from SIM card.
Step 5. Extract the Contacts from SIM Card.
You can choose to extract the data scanned out “To Device” or “To PC”. If you choose “To PC”, you can make settings for the data before exporting.
The data will be transferred to computer as the format you need. Please wait for the extract process.
Wait for the Extract Process
Once the transfer process completes, you will see the interface below.
Extract Process Complete
