View the most comprehensive guides to Remove Locked Screen, Bypass FRP Lock, Recover Lost Data, Fix System Issues, Extract Needed Data, Reinstall/Upgrade OS, Transfer Data and Clean System Junk. Download and try it now.
We would like to share some problems we collected about system crashed device.
“My phone is broken. I want to find my photos back.”
“My phone is unable to turn on anymore. Is there any way to access the data stored on it?”
If you encounter the similar situations above, don’t worry. “Extract Needed Data From System Crashed Device” mode can help you recover precious data stored on phone and extract them to computer or device with 1 click. Please refer to the detailed instructions to extract data from system crashed device easily.
Windows | Windows 11, 10, 8, 7, Vista (64bit) |
Mac | macOS Sonoma, macOS Ventura, macOS Monterey, macOS Big Sur, macOS Catalina, macOS Mojave, macOS High Sierra, macOS Sierra, OS X 10.11 |
Windows system | All Samsung Devices with Android Version 5 and above |
macOS system | Samsung Devices with Android Version 11 below |
Media Data | Photos, Videos, Audio | Both Existed and Deleted |
Personal Data | Messages&Attachments, Contacts(Number/Email/Address) , Call Logs, Calendar, Documents , Books , ZIP Files , APK Files | Only Existed |
Social Data | WhatsApp Attachments, LINE Attachments | Only Existed |
Benefits | Free Version | Pro Version |
Scan Device Data | ![]() |
Preview Device Data | ![]() |
Extract Device Data | ![]() |
Download and install DroidKit on your computer. Then, launch DroidKit on your computer and choose “From System Crashed Device” mode.
Select “From System Crashed Device” Mode
“From System Crashed Device” mode can extract 13 types of data from system crashed Android device. By default, it has checked all the file types. You can just select the type of data that you'd like to extract. And then please click “Start” button.
Select Data to Extract from System Crashed Device
Please refer to instructions as interface to put your Android device into recovery mode. Then, please click “Next” button.
Device without Home Button:
1. Press and hold the {Power button} to power off the device.
2. Press and hold {Volume Up +Power button} at the same time.
3. Release the button after the Samsung logo appears.
4. When the Recovery screen appears, click the button below.
Put Your System Crashed Device into Recovery Mode
Device with Home Button:
1. Press and hlod the {Power button} to power off the device.
2. Press and hold {Volume Up +Power button+Home button} at the same time.
DroidKit will access the PDA code of your Samsung Device. Please enter the PDA code in the box. After that, please click “Download Firmware” button.
Find And Enter the PDA Code of Your Samsung Device Manually
The program starts downloading the firmware package. Please keep your device connected all the time.
Download Firmware
After downloading and verifying the firmware, please click Fix Now button. Then, please put your device into Download Mode. There are two ways to put your device in Download mode – device without Home button and device with Home button. Please choose one way based on your device status.
Put Your Device in Download Mode
After putting your device in Download mode, please click “Next” button. If your device failed to be detected, our software will ask you to disconnect and reconnect your device to computer and put your device to the Download mode again.
Put Your Device in Download Mode Again
Then, it will automatically start repairing your Android system. Please wait for a moment.After completing the fixing process, you will see the interface below. And your Android device will be restarted.
Repair the Android System Complete
Once your device is detected, you will see the interface below. Then, please click “Next” button.
Connect Your Android Device to Computer
DroidKit will scan the existed and deleted data from your Android device quickly.
Scan out Your Data Quickly
After completing the scanning process, you can preview the data scanned out.
Preview the Data Scanned out from System Crashed Device
You can choose the data scanned out to extract “To Device” or “To PC”.
Extract the Data from System Crashed Device
Once the transfer process completes, you will see the interface below.
Quick Recovery Process Complete
