Download DroidKit to Get Various Samsung Solutions.
Free Download See Pricing
User Guide of DroidKit
View the most comprehensive guides to Remove Locked Screen, Bypass FRP Lock, Recover Lost Data, Fix System Issues, Extract Needed Data, Reinstall/Upgrade OS, Transfer Data and Clean System Junk. Download and try it now.
See PricingView Suitable Price Plan
Extract Data from Google Account
We would like to share some problems we collected about google account.
“Is there any way to extract WhatsApp from Google Drive?”
“I want to export messages, call logs from Google Backups. Can you help me?”
If you encounter the similar situations above, don’t worry. “Extract Needed Data from Google Account” mode can help you locate precious data stored on Google account and extract them to computer or device with 1 click. Please refer to the detailed instructions to extract data from Google account easily.
Select “Recover from iOS Device” Mode
Compatibility of Computer System
Windows OS Windows 11, 10, 8, 7, Vista (both 32bit and 64bit)
macOS macOS 10.13 (High Sierra) and above
Supported Device Types
All Android Devices with Android Version 5 and above.
Supported File Types
Google Drive WhatsApp
Google Backups Messages, Call Logs, Wi-Fi Password
Google Account Photos, Contacts, Calendar
Differences between Free & Activated Version
Benefits Free Version Pro Version
Download Google Data
Scan Google Data
Preview Google Data
Extract Google Data
Part 1. Extract Needed Data from Google Drive.
Step 1. Select From Google Account Mode.
Download and install DroidKit on your computer. Then, launch DroidKit and choose “From Google Account” mode.
Step 2. Select Google Drive Option.
Please select Google Drive option. Then, please click “Next” button.
Step 3. Sign in with Your Google Account.
Please sign in with your Google Account with email and password. Please make sure the network is stable. Meanwhile, please make sure that you enter the correct email and password.
If your Google account is turned on 2-Step Verification, please turn it off before signing in. Please refer to this post to turn it off.
Sign in your Google account in your browser, click on “Continue” and wait for the authorization to be successful. After that, please click “I have authorized” button.
Step 4. Select a Backup to Download.
You can view the contents of the backup files. Please select a backup to download. And please make sure the network is stable. Then, please click “Next” button.
The time to download varies based on the size of backup. Please keep patient.
Wait for the Downloading Backup
Once the downloading process finishes, you can click “View” option to check the complete contents in backup.
View the Complete Contents in Backup
Step 5. Scan Data from Backup.
After you click Next button, it will automatically scan out data from Google Drive.
Scan Data from Google Drive
After scanning, you can directly view the data of WhatsApp Attachment.
Review WhatsApp Attachment
As for WhatsApp and Call log, please follow the steps to access to them. At first, please connect your Android device. After connecting, please click “Start” button.
Connect Your Device
Connect Your Device
If there is no WhatsApp app on your Android device, please follow the instructions of DroidKit to install WhatsApp in Google Play, and log in WhatsApp account on WhatsApp app.
Install WhatsApp on Your Device
After that, the scanning process will start.
Scanning Process
Scanning Process
Please ensure the WhatsApp account logged on your phone is the same as the the account of downloaded backup.
Step 6. Preview the Data Scanned out.
After scanning out, you can preview the data.
Scanning Results
Scanning Results
Step 7. Extract the Data You Need.
You can choose the data scanned out to extract “To Device” or “To PC”. Please wait for the extract process.
Once the extract progress completes, you will see the interface below.
Extract the Data Complete
Part 2. Extract Needed Data from Google Backups.
Step 2. Select Google Backups Option.
Please select Google Backups option. Then, please click “Next” button.
If your google account is turned on 2-Step Verification, please turn it off before signing in. Please refer to this post to turn it off.
Select a Backup to Download from Google Backups
Step 5. Preview the Data Scanned out from Google Backups.
After completing the scanning progress, you can preview the data scanned out.
Step 6. Extract the Data You Need from Google Backups.
You can choose the data scanned out to extract “To Device” or “To PC”. If you choose “To Device”, you will see the pop-up message below. Please connect your Samsung device to computer with a USB cable.
Connect Your Samsung Device to Computer
Once your device is detected, you will see the interface below. After that, you can extract data from Google backup to your device.
Your Device Is Connected
Part 3. Extract Needed Data from Google Account
Step 2. Select Google Account Option.
Please select Google Account option. Then, please click “Next” button.
Step 3. Authorize Your Google Account.
Authorization is required to obtain your Google Account data. Please click “Authorize” button to complete the authorization.
Step 4. Scan Data from Google Account.
It will automatically scan out data from Google account.
Step 5. Preview the Data Scanned out.
After completing the scanning progress, you can preview the data scanned out from Google account.
Step 6. Extract the Data You Need.
