View the most comprehensive guides to Remove Locked Screen, Bypass FRP Lock, Recover Lost Data, Fix System Issues, Extract Needed Data, Reinstall/Upgrade OS, Transfer Data and Clean System Junk. Download and try it now.
We would like to share some problems we collected about Android lock screen removal:
"Is there a way to remove the lock of Android phone?"
“I've forgotten my Android phone's lock. Can you help you?”
“Forgot my lock screen. How could I recover access?”
If you encounter the similar situations above, don’t worry. “Screen Unlocker” mode can help you unlock Android lock screen. Please refer to the detailed instructions to unlock screen easily.
Windows OS | Windows 11, 10, 8, 7, Vista (both 32bit and 64bit) |
macOS | macOS 10.13 (High Sierra) and above |
Most common brands available in the market, like Huawei, Samsung, Vivo, Google, OPPO, Xiaomi, Sony, LG, Motorola, Nokia, Lenovo, Realme, ZTE, Redmi, POCO etc. with Android version 5 and above. |
Patterns, PINs, Digital Numbers, Fingerprints, Facial Recognition |
Benefits | Free Version | Pro Version |
Matched Device | ![]() |
Remove Lock Screen | ![]() |
Download and install DroidKit on your computer. Connect your Android device to computer with a USB cable. Then, launch DroidKit on your computer and choose “Screen Unlocker” mode.
Select Screen Unlocker Mode
This function will erase data on your device.
And you will see the interface below. Please click “Start” button.
Click “Start” Button
And then, please choose Device Connected button.
Choose Device Connected Button
Then, it will start preparing the configuration file for your device. Please keep patient.
Prepare Device Configuration File
Once the preparing process is completed, the below interface will be displayed. Please click Remove Now button.
Configuration File Is Prepared for the Device
Please follow the instructions of DroidKit interface to put your device in Recovery Mode based on device with/without home button/with Bixby button, and Wipe Cache partition on your device.
Put Device in Recovery Mode
If you are using Samsung device, you will see "Can your device be turned off normally" interface. Please select the appropriate option based on your device's capabilities. And follow the instructions to turn off the device.
After completing Wipe Cache Partition, it will start to remove Android screen lock. It will take some time. Please keep patient.
Remove Android Screen Lock
After the removal process completes, your device will be started. And you can access your Android device without entering any password and view all your data on the device with no limits.
Screen Lock Removal Complete
