In this post, we will talk about how to back up Samsung phone to pc via Samsung Smart Switch and introduce 3 alternative backup methods. Let’s take a look at how to back up & restore your Samsung Galaxy phone with a few clicks.
Do you need to back up Android phone to PC or Mac, such as contacts, photos, files, music, or other vital documents? Here, we are going to show you to backup Samsung Galaxy devices to PC. Normally, you can use the Smart Switch Samsung software to back up your data from an old smartphone to a new Galaxy smartphone. All you need to do is simply backing up all the content and then restore it on the new Samsung android.
Here is a short tutorial on how to back up data on your Samsung Android to your PC or Mac computer. If you would like to learn about various different alternatives to back up your Samsung Galaxy to PC, check out our article with detailed step-by-step instructions. At the end of this post, we also introduce how to restore data on a Galaxy device.
Many users may wonder how do I backup my entire Samsung phone? Well, Smart Switch permits you to easily back up or transfer your images, files, music, or other types of vital documents. You can even create a backup for your old Samsung phone’s files on your PC or Mac and then transfer or restore it onto your new Samsung phone.
Prior to starting to gather all your data, firstly you have to make sure your PC meets the requirements to use Smart Switch. If your PC or Mac supports Smart Switch, you should visit the Smart Switch page, and select Requirements under Overview to check whether your Samsung device supports using Smart Switch. If you meet the requirements, download the latest version of the Samsung Smart Switch.
After installing Smart Switch, you’ll need to back up Samsung phone or transfer files from Samsung to PC or Mac computer.
Use Samsung Smart Switch to Backup Samsung Phone to PC
When you back up your old phone’s data on a PC or Mac, the files are automatically stored in a default location (unless you’ve chosen a different location). Here are the default locations, so you can understand where the backup is stored:
Prior to start transferring your data, make sure the data types are supported by Smart Switch on PC or Mac.
Transferring the backup files on your computer onto your new phone, you can enjoy all your videos and images. But firstly, turn off or temporarily disable your anti-virus, anti-malware, and other security tools on your PC or Mac so that all your files can able to transfer.
You may need to allow permissions on your Samsung Phone to complete the backup.
Here’s another way to get content from your computer onto a new Samsung phone – you can sync data on your phone with your pc. Syncing ensures you have the same data on your PC or Mac and your phone.
On a Mac, Click Sync on the Smart Switch Screen
If you seek to preview the backup content so as to selectively back up Samsung phone to PC, you can turn to DroidKit – Android Solution Toolkit. As a professional Android data manager, its newly-developed feature – Data Manager can help you take a closer look at the data before backing it up to your computer. You can either use it on your PC or Mac computer. Besides transferring and backing up Samsung data, you can also take its Data Recovery function to recover up to 13 kinds of data, if you delete them from your Samsung phone or SD card unexpectedly. What’s more, transferring data to a new Android phone is easy and fast with DroidKit. Free try DroidKit and figure out DroidKit’s impressive features and highlights as below.
Now please take the following steps to back up Samsung phone to PC selectively.
Step 1. Launch the program once you’ve installed DroidKit on your computer > Choose the Data Manager mode > Select Device Manager option.
Choose the Device Manager
Step 2. Connect your Samsung phone to the computer via a USB cable > Once DroidKit detects your Samsung phone, it will scan the data on your device and navigate to the following interface.
Choose Export Content
Step 3. Choose the Export Content mode and access the interface showing the specific data on your Samsung device. Now, you can preview and selectively backup Samsung phone to PC.
Choose Data You Want to Transfer
Although many Samsung users would like to install Samsung Smart Switch to back up or transfer content, they find it complex to complete the whole backup process. Also, quite a few users have reported that their Samsung Smart Switch fails to work sometimes.
As a matter of fact, besides Samsung Smart Switch, you can use other Samsung backup software to get your device backed up. You can choose PhoneTrans to back up Samsung phone to PC in 1 click. Allowing you to decide what contents to back up, PhoneTrans makes it easier and more flexible to back up from your Samsung phone to your PC. When it comes to its Back-Up feature, PhoneTrans has the following outstanding feature:
Freely download the latest version of PhoneTrans on your computer, follow the steps and back up your Samsung phone in your own way.
Step 1. Launch PhoneTrans on your computer > Select Phone Backup > Choose Selective Backup > Click Start Backup.
PhoneTrans Phone Backup Overview
Step 2. Connect your Samsung device to the computer > Tap on the Back Up button.
Connect Your Android Phone to the Computer
Step 3. View and click the types of data you seek to back from your Samsung to pc > Click on Back Up Now.
Backup Samsung Phone with PhoneTrans
Every Samsung device user is familiar with this name. Kies refers to ‘Key Intuitive Easy System’ and is usually used to backup data Samsung phone to PC. Install Kies on your device and follow these easy steps
This can also connect to Kies wireless by selecting the “Wireless Connection” option on its home screen. Kies would also be used to upgrade your device’s firmware and perform other important tasks. However, it can be a little complex at times and you might get a good experience using other interfaces.
With DroidKit, you can also restore data on a Galaxy device. If you use a Samsung phone, you can easily restore the Samsung backup. It would be much easier if you have backed up data to your computer before. Simply click “Add Content” and then you can selectively restore data from your computer according to your demands.
Choose Add Content
If you getting a new phone are having to manually transfer all your credentials. So, worry not, Smart Switch allows you to easily transfer images, files, music, or other vital documents and other types of files. But make sure to use Smart Switch, your phone must run Android 4.3 or iOS 4.2.1 or later version. You can also create a backup for your old Samsung phone’s files with DroidKit. Free download DroidKit to your computer and give it a try.
