OK, got it
Normally, a permanently locked Snapchat indicates that you may perform some activities that are prohibited officially. This is to ensure Snapchat fun and safe to its users. However, you can still try several methods to unlock Snapchat permanently locked. Just read this post to learn how to unlock a permanently locked Snapchat account.
A few months ago, thousands of Snapchat users started receiving messages that their accounts had been either temporarily or permanently locked. This caused an outrage on social media as many of the app’s users claimed that Snapchat account was permanently locked for no reason and they hadn’t done anything that would require such a harsh penalty.
Seeing this message is by no means pleasant, and sometimes, crashing Snapchat may cause Snapchat data lost. Then, can you unlock a permanently locked Snapchat? Yes, you can still try some methods to unlock Snapchat. So, just read this article if you find Snapchat permanently locked. Here we are going to show you how to unlock a permanently locked Snapchat account.
Unlock a Permanently Locked Snapchat Account
It is currently unclear which criteria exactly determine how long a locked account last on Snapchat, as some users receive the notification that the account is temporarily locked, while others are informed that their accounts are locked permanently. According to Snapchat, there are 4 reasons for temporarily or permanently banned Snapchat:
Normally, other Snapchat users can report the username of your Snap account if you break the rules in the End-user License Agreements(EULA). After checking, you’ll receive a warning and be required to correct the mistake, if you do break the rules. However, if you fail to correct it in time, you might receive another report. Therefore, this is why many Snapchat users may ask how many reports does it take to get banned on Snapchat? The answer is 3 reports! That means if someone reports they find there is something wrong with your Snapchat account 3 times, your Snapchat account will be banned unexpectedly.
Also Read: Here is another Snapchat tip for you – How to Backup and Restore Snapchat Data >
Then, how to unlock a permanently locked Snapchat account? In the following sections, we will show you several proven ways to unlock permanently locked Snapchat. Just read on to try these methods.
In case you were using plugins and third-party apps associated with Snapchat, and you were notified that your account is temporarily locked, you should uninstall these apps and plugins before attempting to unlock Snapchat account.
Failing to do so can result in a long-term ban, so it is best not to access your Snapchat account before getting rid of the plugins and apps that may have been why the platform decided to suspend your account.
Snapchat Plugins and Apps
Reinstalling the Snapchat app will delete all data that could be causing the app to display the Snapchat permanently locked message when you attempt to log in. However, if the platform suspended your account because it thought you violated one or more of its rules, you won’t be able to accomplish much by reinstalling the app.
To better manage Snapchat plugins and reinstall the Snapchat application, you can take AnyTrans a try. As a professional iOS management tool, AnyTrans supports locating, installing or uninstalling applications on your iPhone. Besides, it can help you on updating and downgrade an app when it comes to managing apps on your iPhone.
Free install AnyTrans and try to reinstall Snapchat using the App Downloader feature.
Reinstall Snapchat on Your iPhone
You can also easily locate Snapchat along with Snapchat plugins and apps in the “Device Manager” feature, with which you can delete, archive, and reinstall your Snapchat-related apps.
How to unlock a permanently locked Snapchat account? Snapchat users whose accounts were locked will see the yellow unlock button below the notification informing you about the possible reasons why your account may have been locked. It is advisable to delete the apps or plugins you were using with Snapchat before clicking on the Unlock button.
Also, you shouldn’t expect to gain access to your account immediately after you click on the Unlock button, as it will take at least a few hours if not days before Snapchat sends you a new password in an email that is informing you that your account is unlocked.
Tap on the Unlock Button
Some glitches may also cause Snapchat account permanently locked, so you can try performing a hard reset of your iPhone. Although it will eliminate the glitch as a potential cause of the problem, in most cases this method is unlikely to resolve the issue.
Force Reset Your iPhone
Force resetting your iPhone always requires pressing a combination of keys. The specific combination may vary from model to model. Here we use iPhone 12 as an example, which is also applicable to iPhone X and iPhone 11. You can follow the steps below to see how to unlock a permanently locked Snapchat account via hard reset.
Also Read: How to Soft Reset iPhone >
If you cannot solve how to unlock permanently locked Snapchat with the above methods, reaching out to Snapchat’s customer support is arguably the fastest way to unlock Snapchat. Contacting a customer support agent will enable you to get more information about the reasons behind the ban and how long it will take to get access to your account.
Snapchat users who receive the Snapchat permanently locked message can try to clear the issue with customer support, as that is their only hope to continue using the same Snapchat account.
Snapchat’s Customer Service
Chances are that you will have to create a new Snapchat account if your old account is permanently locked and the dialogue with the platform’s customer support fails to produce the results you were hoping for.
Then, how to make a new Snapchat after being permanently locked? You have to create a new email address to continue using Snapchat. Please note that you won’t be able to use the same email address you used to create the previous permanently locked Snapchat. Also, you won’t be able to retrieve your Snapchat data if your Snapchat account is permanently locked.
Nevertheless, there are also some users who fail to create a new Snapchat account, and here we explain why you can’t make a new Snapchat.
Create a New Snapchat Account
As mentioned at the beginning of the post, there are several reasons why is Snapchat permanently locked. To prevent your Snapchat account permanently locked again, you should note that:
Stop Snapchat from Locking My Account
On one hand, Snapchat has strict rules to ban you from using third-party apps such as Sneakboo or SnapTool. This is because such apps might acquire users’ information via insecure links, which may further put other accounts at risk. In terms of this rule, uninstalling the unexpected third-party app may avoid Snapchat from being locked.
On the other hand, don’t continuously send a large number of Snap messages or we say spam messages to others, especially when they don’t show any interest in the information. Also, abusive behavior is also prohibited in the Snapchat community, which involves impersonating or bullying other users.
Snapchat permanently locked is most likely to stay that way, as only a small percentage of the app’s users manage to regain access to their accounts through dialogue with customer support. However, you can still try the above methods to solve how to unlock a permanently locked Snapchat account.
Temporarily locked accounts are usually unlocked after a few hours, although it may take a few days before Snapchat allows you to continue using your account. Was this article helpful? Leave a comment and let us know.
