How to Bypass Xiaomi/Redmi/Poco FRP [Solved]
Don’t worry if you are locked out of the FRP lock on your Xiaomi, Redmi, or POCO phone. This detailed guide will let you know how to bypass it. It will also share a bonus tip on bypassing the screen lock without a password. So keep on reading this guide about POCO/Xiaomi/Redmi FRP bypass!
Author Avatar Joy Taylor Last Updated: Aug. 12, 2024
Read in: Read This Article in
DroidKit – Xiaomi/Redmi FRP Bypass in Clicks
How to bypass Redmi/Xiaomi FRP? Free download DroidKit to bypass FRP lock in simple clicks now. It supports Android 6-13 and can offer customized FRP bypass solutions according to the system version. No skills are needed. Just in a few clicks and minutes, you can bypass FRP successfully. Supports all Xiaomi, Redmi, POCO, OPPO, and Samsung devices.
Are you locked out of your Xiaomi device by FRP lock? Worry no more! Whether it’s a Xiaomi, Redmi, or POCO phone, this detailed guide is your key to bypassing FRP lock. You’ll find everything you need to know, from what FRP lock is to removing FRP to access to your locked phone.
The Factory Reset Protection (FRP) feature, designed to secure your device, can sometimes become a hurdle. But with our solution to Xiaomi/Redmi FRP bypass, this security feature won’t hold you back any longer. So are you ready to regain full access to your phone today? If yes, let’s get started!
POCO/Xiaomi/Redmi FRP Bypass in Simple Clicks
When you forget your Google account details, you look for the easiest way to Xiaomi FRP bypass. Here is the solution: DroidKit FRP Bypass. It offers a powerful Xiaomi/Redmi FRP bypass tool and can help you solve all Android problems, including bypassing FRP lock. Its user-friendly interface makes it easy to bypass FRP lock even if you forget your Google account and password. After bypassing, you can regain full access to your device again, and if needed, you can also log in with another Google account. And you can learn more about what DroidKit can do for you in FRP bypass Xiaomi.
  • Bypass FRP easily and quickly – Just follow the on-screen instructions to bypass FRP in a few minutes. No skills are needed. No waiting.
  • Super high success rate – DroidKit provides customized FRP bypass solutions for different Android systems and devices. Maximally ensure that you can successfully bypass FRP lock.
  • Support multiple devices – It supports all Xiaomi, Redmi, Samsung, OPPO, and POCO devices running Android 6 and above.
  • 100% Safe – It will not cause any damage to your device. The data on the device will not be leaked. You can use it with confidence.
Besides, this amazing tool also assists you in unlocking screen lock and recovering lost or deleted data. It also fixes known and unknown system issues and provides various device management features.
So just free download DroidKit. Next, let’s look at how to use this tool for Xiaomi/Redmi FRP bypass.
Step 1. Open DroidKit on your PC/Mac and select the FRP Bypass mode from the interface.
Choose FRP Bypass Mode
Step 2. Next, connect your Xiaomi/Redmi device to your computer using a USB cable and click the Start button.
Step 3. Now, DroidKit will ask you to choose your device brand. Click Xiaomi and proceed.
Choose Device Brand
Choose Device Brand
Step 4. After selecting Xiaomi as your device brand, the tool will start preparing the configuration file for your Android device. Once prepared, select Start to Bypass.
Click Start to Bypass
Step 5. Then just follow the on-screen instructions to complete some settings.
Follow the Steps on Xiaomi
Step 6. Then, DroidKit will bypass the FRP lock. You will see the below interface as the process completes.
FRP Bypass Complete
FRP Bypass Complete
Following all these steps will help you to unlock Xiaomi FRP lock with DroidKit. However, you can also try other ways mentioned in the next section.
Bypass FRP on Xiaomi/Redmi/POCO without PC or FRP Tool
If you don’t have access to a PC, don’t worry! You can still bypass FRP on Xiaomi/Redmi/POCO devices. Two built-in features: voice recognition and Google keyboard, can also act as an effective POCO/Redmi/Xiaomi FRP bypass tool. Follow these steps for Xiaomi FRP bypass right now.
Step 1. First of all, go to network settings. Then click Add Network at the bottom of the screen.
Step 2. In the SSID section, enter any random text. Then long press the text to select it. Next, tap the share icon, and share it with your Gmail.
Enter any Random Text in SSID Section
Enter Random Text in SSID Section
Step 3. Next, tap on Notifications > Additional Settings. Now, in the top right corner, click the three-dot icon and tap “Help and Feedback.”
Step 4. In the search section, click “Delete and disable apps on Android.” Next, tap on “Tap to go to Application Settings.”
Click Tap to go to Application Settings
Step 5. Now select Settings > Additional Settings > Accessibility > Accessibility Menu to enable the Accessibility Menu shortcut.
Enable the Accessibility Menu Shortcut
Step 6. Go back to the app info screen by tapping the back button a few times. Next, click More and select Show System.
Step 7. Choose Android setup, tap Disable, and Disable app. Then tap force stop and OK.
Step 8. Return to the App info page to choose Carrier Services. Next, select Disable and Disable app, choose Force to stop, and OK.
Step 9. Go back to the App info screen and choose Google Play services. Tap on Diable and Disable App, Force Stop, and Click OK.
Step 10. Press the back button and the next icon to go back to connect to the network screen.
Step 11. In the lower right corner of the screen, click the person icon to access Google Assistant > Settings on the Checking for Updates page.
Step 12. Repeat this process multiple times to access the Google Play Services App information page. Then select Enable to enable Google Play Services.
Step 13. Return to the Checking for Updates page and wait for the process to complete. As the process completes, select more and Accept.
Step 14. When the Setup Complete page appears, you can turn off Xiaomi’s Google Account verification.
That’s all about this method. Undoubtedly, it is a lengthy process. If you don’t want to Redmi bypass FRP using this method, let’s jump to the next one.
Bypass FRP on Xiaomi/Redmi/POCO with ADB
What is the free FRP bypass tool for Xiaomi? If you are looking for a Xiaomi/Redmi FRP bypass tool free, you can consider ADB. ADB stands for Android Debug Bridge. It is an effective way that a computer can communicate with an Android device. You can remove the Google FRP lock using a variety of commands depending on the OS version. Follow the below steps to bypass FRP on Xiaomi/Redmi/POCO with ADB.
Step 1. First of all, download the ADB setup file. Now, extract the toolkit files to a folder on your PC.
Step 2. Next, run adb.setup.exe, and then press Y to accept the prompt. Thus, you will be able to install the ADB drivers.
Step 3. After installing the ADB drivers, type Y once more. It will close the command window.
Step 4. Next, turn on your Android phone and connect it to your Personal Computer using a USB cable. Also, ensure your USB debugging mode is on.
Step 5. Then, hold down the Shift key and right-click somewhere empty in the ADB folder. Now, select the Open command window here.
Step 6. Next, run the following lines one at a time at the command prompt to delete the FRP. Then press enter after each line. Below is the code for CMD.
Enter Code for CMD
Enter Code for CMD
Step 7. Your device’s FRP lock will be bypassed as the process completes.
Let’s keep the momentum going and discuss how you can disable the FRP feature on your Android device.
How to Disable Xiaomi/Redmi/POCO FRP
With the above FRP bypass tool Xiaomi/Redmi, you can remove FRP lock easily. However, there are still risks in being locked by it again. Therefore, you can also choose to disable Xiaomi/Redmi/POCO FRP. You can effortlessly do this by removing the Google account from your device. Thus, you will no longer need to Redmi FRP bypass. Below are the steps that you can follow to disable Xiaomi/Redmi/ POCO FRP:
Step 1. Go to settings from the menu of your Android device.
Step 2. Go down the page and Click “Accounts & Syn.”
Step 3. Tap on the Google account to delete it.
Tap on Google Account to Delete it
Step 4. Click Confirm to remove your Google account.
You may need to enter your device PIN or password to complete the process. So let’s look at removing the screen lock if you forget the password.
Bonus Tip. Bypass Screen Lock on Xiaomi/Redmi/POCO without Password
Are you tired of trying to remember the screen lock of your Android device? Here is a bonus tip for you. DroidKit can also help you if you forget your lock screen. As a powerful Android screen unlocker, it can help you bypass the screen lock on any Android device, including Xiaomi/Redmi/POCO without entering a password. So you can get access to your Android phone.
It removes all types of screen locks such as PIN, password, pattern, facial recognition, or fingerprint. The best part is DroidKit to unlock your device in only 1 click. Anyone can use this tool with ease.
The following steps will assist you in unlocking your screen lock without hassle. But before starting the process, free download and install DroidKit on your computer.
Step 1. Connect your device to your computer > Launch the app on your computer > Select Screen Unlocker mode > Click the Start Button.
Choose Screen Unlocker
Step 2. Then, it will continue preparing the configuration file for your device. After that, tap on Remove Now.
Click Remove Now Button
Step 3. Put your device in the Recovery Mode by following the on-screen instructions.
Finish Settings on Samsung
Step 4. After that, it will start removing your screen lock.
Lock Screen Removal Completed
Hopefully, you can effortlessly bypass your Android screen lock by following these steps.
In conclusion, being locked out of your Xiaomi, Redmi, or POCO device need not be a dead end. With the detailed methods provided for Xiaomi/Redmi FRP bypass and other lock solutions, you have the keys to get back in control. If you want to bypass the FRP lock immediately and easily, we highly recommend you try DroidKit for free first. Don’t let a forgotten password or FRP lock slow you down. Follow this guide and regain full access to your phone today!
