Under Android 6 to 14, many users have expressed on the Internet that they are confused by the FRP lock of Vivo Y15/Y17 after forgetting their Google account password. This article details how to bypass the FRP lock, providing solutions without a computer and using a computer to help you quickly complete the Vivo Y15/Y17 FRP Bypass
Most smartphone users have experienced this: facing the problem of device lock due to forgetting Google account password. For users of Vivo Y15 and Y17, how to bypass FRP (Factory Reset Protection) lock has become a pressing need. Whether your device is running Android 6 or Android 14, with or without a computer, it is crucial to find a quick and effective solution. In this article, we will introduce in detail how to perform Vivo Y15/Y17 FRP Bypass to help you quickly restore your phone to normal use.
Vivo Y15 and Vivo Y17 are both very popular smartphones, each with its own advantages in design, performance and features. Below is a detailed comparison of the two phones from multiple aspects:
Attribute | Vivo Y15 | Vivo Y17 |
Release Date | May 2019 | April 2019 |
Display | 6.35-inch IPS LCD, 720 x 1544 pixels | 6.35-inch IPS LCD, 720 x 1544 pixels |
Processor | MediaTek Helio P22 | MediaTek Helio P35 |
Operating System | Android 9.0 (Pie) with Funtouch OS 9 | Android 9.0 (Pie) with Funtouch OS 9 |
RAM | 4GB | 4GB |
Storage | 64GB (expandable via microSD up to 256GB) | 128GB (expandable via microSD up to 256GB) |
Rear Camera | Triple: 13MP main + 8MP ultra-wide + 2MP depth sensor | Triple: 13MP main + 8MP ultra-wide + 2MP depth sensor |
Front Camera | 16MP | 20MP |
Battery | 5000mAh, supports reverse charging | 5000mAh, supports 18W fast charging |
Connectivity | 4G LTE, Wi-Fi 802.11 b/g/n, Bluetooth 5.0, GPS, Micro USB 2.0 | 4G LTE, Wi-Fi 802.11 b/g/n, Bluetooth 5.0, GPS, Micro USB 2.0 |
Weight | 190.5g | 190.5g |
Dimensions | 159.4 x 76.8 x 8.9 mm | 159.4 x 76.8 x 8.9 mm |
The Vivo FRP code is part of the Factory Reset Protection (FRP) system implemented on Vivo smartphones running Android. FRP is a security feature designed to prevent unauthorized access to a device after it has been reset to factory settings.
The FRP code is a password that can be used to bypass the FRP lock. The emergency code for the Vivo FRP bypass is *#812#.
Bypassing the FRP (Factory Reset Protection) on a Vivo Y15/Y17 can be achieved through several methods. Below, I provide a step-by-step guide to bypass the FRP lock using different techniques.
1. Connect to Wi-Fi:
– Power on your Vivo Y15/Y17 and connect to a Wi-Fi network.
2. Access the Google Account Verification Screen:
– On the verification screen, tap the text field to bring up the keyboard.
– Tap and hold the ‘@’ key to access the settings menu.
3. Open Settings:
– Select ‘Google Keyboard Settings’.
– Tap the three dots (or more) and select ‘Help & Feedback’.
4. Access the Chrome browser:
– In the Help section, tap ‘Use Google Keyboard’.
– Long press any text and click ‘Web Search’.
– Type ‘Settings’ in the search bar and open Settings.
5. Install FRP Bypass APK:
– In Settings, go to ‘Security’ and enable ‘Unknown Sources’.
– Download and install the Google Account Manager APK (compatible with your device’s Android version) using your browser.
– Install FRP Bypass APK.
7. Bypass FRP:
– Open FRP Bypass APK and tap on the three dots on the top right corner.
– Select “Browser Sign In” and sign in with the new Google account.
– Restart your device.
8. Complete the setup:
– After the reboot, you will be able to complete the setup without the FRP lock.
1. Enable TalkBack:
– On the Welcome screen, select your language and tap Vision settings.
– Enable TalkBack.
2. Access TalkBack settings:
– Draw an “L” on the screen to open the TalkBack settings menu.
– Double-tap TalkBack settings.
3. Turn off TalkBack:
– Scroll down with two fingers to navigate.
– Double-tap TalkBack to turn it off.
4. Open Chrome browser:
– In the settings menu, go to Help & Feedback.
– Select Get started with Voice Access.
– Tap on a video and select the three dots, then select Watch later to open the browser.
5. Download and install FRP Bypass APK:
– In the browser, search for and download FRP Bypass APK.
– Go to Downloads and install the APK.
6. Bypass FRP:
– Open the FRP Bypass APK and use it to sign in to a new Google account.
– Restart your device and complete the setup.
If the above two methods do not work for you, you can also try the following method: Use DroidKit to bypass FRP lock on Vivo Y15/Y17. DroidKit has a deep understanding of FRP lock bypassing algorithms and has rich experience in FRP lock bypassing, which has won a lot of praise from users.
In addition to Vivo devices, it also supports bypassing Google account verification on Samsung, Xiaomi, Redmi, POCO, OPPO, Motorola, Lenovo, Realme, SONY, and OnePlus devices.
Download DroidKit now and follow the steps below to quickly bypass FRP lock on Vivo Y15/Y17!
Step 1. Free download DroidKit and launch it, click FRP Bypass.
Choose FRP Bypass Mode
Step 2. Connect your Vivo Y15/Y17 to your PC via a USB cable. Click the Start button and select the device brand (Samsung in this case) and continue.
Step 3. Wait while the process is preparing configuration file for your device. On completion of the process, the following window will appear. Click on the Start to Bypass button.
Click Start to Bypass
Step 4. Select the operating system and device model according to the screen interface and click on the Next button.
Choose System Version
Step 5. Proceed to the device’s current password interface and follow the on-screen directions to finish configuring the appropriate settings.
Complete Corresponding Settings
Step 6. Wait for the process to finish. Eventually, the device will restart, and the FRP lock will be removed successfully.
FRP Bypass Complete
This tool not only makes it easy to bypass FRP locks, but also has powerful data recovery, system repair, and file management capabilities. Whether you have forgotten your Google account password or need to repair system problems, DroidKit provides a one-stop solution. Download DroidKit now to experience fast and efficient FRP bypass capabilities.
1. Can I bypass FRP lock by doing a factory reset?
No. FRP lock is designed to protect the device after a factory reset. FRP lock cannot be bypassed by a simple factory reset, and you will need to enter the previously synced Google account and password to regain access to the device.
2. Is it safe to bypass FRP lock using DroidKit?
Yes, it is safe to bypass FRP lock using DroidKit. DroidKit uses high standards of security measures. The tool has been verified many times and has good user reviews.
3. How long does it take to bypass FRP lock using DroidKit?
Usually, it only takes a few minutes to bypass FRP lock using DroidKit.
In this article, we have introduced several methods to bypass the FRP lock of Vivo Y15 and Y17 in detail.
1. Using Google Account Manager and FRP Bypass APK: No external tools are required, but the operation is cumbersome and the steps are complicated. It is not suitable for newcomers without professional background.
2. Bypass Vivo Y15 and Y17 FRP lock using TalkBack and Accessibility: There is no need to download additional applications, but the process is relatively complicated. If you have some technical knowledge, you can try this method.
3. Bypass Vivo Y15/Y17 FRP lock using DroidKit: Easy to operate, user-friendly interface; supports a wide range of devices and system versions; efficient and safe, without complicated steps.
In summary, DroidKit provides a simpler and safer solution to bypass Vivo Y15/Y17 FRP lock, which is suitable for most users. Using DroidKit, you can not only easily bypass FRP lock, but also enjoy other powerful features such as data recovery, system repair, etc.
For more information about how to bypass FRP lock on different devices, you can also refer to the following links:
