You may have seen countless users on Reddit complaining about the complicated and time-consuming issues when trying to bypass the Vivo V20 FRP lock. This article provides you with a simple and quick method, among which DroidKit is widely recommended, to help you unlock the device easily.
The annoyance of being unable to use your Vivo V20 due to FRP lock is a common problem faced by many users. This article provides you with effective solutions to regain access to your device. From using professional software like DroidKit to utilizing recovery mode, we explore the most effective and reliable methods to help you unlock your Vivo V20 quickly and safely. Whether you are a tech savvy or a novice, this article will ensure that you can bypass FRP lock easily.
The Vivo V20 is an excellent smartphone that combines elegant design with cutting-edge technology. Released in October 2020, it has grabbed people’s attention with its excellent camera capabilities, stylish design, and user-friendly features.
Feature | Details |
Display | 6.44-inch AMOLED, 2400×1080 pixels |
Processor | Qualcomm Snapdragon 720G |
RAM | 8 GB |
Storage | 128 GB, expandable via microSD |
Rear Camera | 64 MP (primary), 8 MP (ultrawide), 2 MP (depth) |
Front Camera | 44 MP with eye autofocus |
Battery | 4,000 mAh, 33W fast charging |
Operating System | Funtouch OS 11 based on Android 11 |
Security | In-display fingerprint sensor, Face unlock |
Connectivity | 4G LTE, Wi-Fi, Bluetooth 5.1, USB Type-C |
There are several ways to bypass Factory Reset Protection (FRP) on Vivo V20. Here are some common solutions.
This is one of the most common ways to bypass FRP lock, using OTG cable and a dedicated FRP Bypass APK file.
Steps to Bypass Vivo V20 FRP:
1. Prepare tools:
2. Connect Wi-Fi:
Power on Vivo V20 and connect to a stable Wi-Fi network.
3. Connect OTG cable and USB drive:
4. Install FRP Bypass APK:
5. Run FRP Bypass app:
6. Perform a factory reset:
7. Restart your device:
Restart your phone and follow the prompts to set up a new account.
DroidKit FRP Bypass allows you to remove Google account verification on Samsung, Xiaomi, Redmi, VIVO, SONY and other devices running Android 6 to Android 14. Whether you have a phone or tablet, whether it is the latest model or an old one, you can remove FRP lock without using a password.
Main features of DroidKit:
Steps to bypass VIVO V20 FRP:
Step 1. Download the latest version of the DroidKit software, install and launch it for operation. Select FRP Bypass.
Choose FRP Bypass Mode
Step 2. Connect your Vivo V20 to your PC via a USB cable. Click the Start button and select the device brand (Samsung in this case) and continue.
Step 3. Wait while the process is preparing configuration file for your device. On completion of the process, the following window will appear. Click on the Start to Bypass button.
Tap on Start to Bypass
Step 4. Select the operating system and device model according to the screen interface and click on the Next button.
Choose System Version
Step 5. Proceed to the device’s current password interface and follow the on-screen directions to finish configuring the appropriate settings.
Complete Corresponding Settings
Step 6. After completing the steps above, the device will be restarted and the FRP Lock is also removed successfully.
FRP Bypass Complete
This versatile tool simplifies the complex task of bypassing FRP lock, making it easy for users to bypass FRP lock without extensive technical knowledge. With its user-friendly interface and powerful bypass capabilities, DroidKit ensures that the process is completed quickly and safely, minimizing the downtime and frustration typically associated with FRP lock issues.
This method is for more advanced users and requires entering the recovery mode of your phone to operate.
1. Turn off your phone:
Press and hold the power button and select Power off.
2. Enter recovery mode:
Press and hold the power button and volume up button at the same time until the Vivo logo is displayed and enter recovery mode.
3. Select Wipe Data:
Use the volume buttons to navigate to the “Wipe Data” option and press the power button to confirm.
4. Perform a factory reset:
Select “Wipe Data/Factory Reset” and confirm.
5. Restart your phone:
There are online services that provide FRP bypass tools and codes that work on various Android devices.
1. Visit FRP bypass website:
Visit the website that provides FRP bypass service on your computer or phone.
2. Enter device information:
Enter your device information (such as model, IMEI, etc.).
3. Download bypass tool or code:
Download the corresponding FRP bypass tool or code according to the prompts.
4. Follow the instructions:
Follow the specific steps provided by the website to bypass FRP lock.
In this article, we discussed several methods to bypass FRP lock. Through the following table, we can clearly compare the advantages and disadvantages of these methods to help you better choose the right solution:
Method | Pros | Cons | Recommendation Level |
Using OTG Cable and FRP Bypass APK | – No computer required – Convenient |
– Requires external device (OTG cable) – Complex process, prone to failure – Technical knowledge needed |
Using DroidKit FRP Bypass | – Simple and user-friendly – Supports multiple devices, high compatibility – Offers comprehensive features: data recovery, system repair – Secure and reliable, no risk of data loss |
– Requires downloading and installing software | ★★★★★ |
Bypass FRP Using Recovery Mode | – No additional tools needed – Uses built-in device functions |
– Complex process – Potential data loss – Requires some technical knowledge |
Using FRP Bypass Websites and Codes | – Free resources and codes available online | – Low success rate – High risk – Possible security and privacy issues |
In a comprehensive comparison, DroidKit excels in simplicity, security, and functional diversity, and is the best choice for bypassing Vivo V20 FRP lock. Whether you are a technology novice or an experienced user, DroidKit can provide you with a fast and effective solution. Choosing DroidKit will save you time and effort and give you peace of mind when dealing with FRP lock issues.
