“I have a Note 8 that I use as a spare phone, and it’s been a while since I last used it so I forgot the PIN. Any way to unlock it?” Many Samsung users may face the same difficulty as this user raised this query- how to unlock Samsung Note 8 without password? Fortunately, this article will offer 5 effective methods.
Capable of removing any type of screen lock on your phone or tablet without entering the password. You can thus fully access your locked device again in minutes.
Released in 2017, the Samsung Galaxy Note 8 remains a powerful and versatile smartphone, known for its sleek design and high-quality features that continue to attract users even in 2025. However, one common issue users face is Samsung getting locked out due to forgotten PINs, patterns, or passwords, which is a challenge especially when buying a second-hand Samsung Note 8. This article outlines five effective methods to effortlessly unlock Samsung Note 8.
Also Read: Top 6 Samsung Unlock Tools to Remove Samsung Lock
One of the most recommended tools for screen lock removal on Samsung Galaxy Note 8 is DroidKit. As an all-in-one mobile solution designed for Android devices, DroidKit supports 2000+ models of phones and tablets. Its powerful Screen Unlock feature can help you unlock Samsung Note 8 without passwords in minutes. Due to its user-friendly interface and easy steps, DroidKit is more suitable for beginners than other competitors. DroidKit also contains other features, including FRP bypass, Data recovery, Android System fixes, etc.
Main Benefits of DroidKit:
Here is stepwise guidance on how to unlock Samsung Note 8 without a password:
Step 1. Free download and launch DroidKit on your computer. Click on the Screen Unlocker mode on the main interface.
Select Screen Unlocker Mode
Step 2. Connect your phone to the computer. Then click Start button.
Connect Your Samsung Note 8 to Computer
Step 3. Prepare the configuration file, and click Remove Now button.
Preparing Configuration File for Note 8
Step 4. Select your device’s brand and click Next.
Select your Device Brand
Step 5. Following the steps below. Then it will start to remove the screen lock on your Samsung Galaxy Note 8.
Finish Steps on Samsung Note
Step 6. After the process is completed, you will see Screen Lock Removal Completed page. Then Your Samsung will be started and you can access your Android device again.
Unlock Samsung Note 8 Screen Successfully
DroidKit is a good choice for unlocking Samsung Galaxy Note 8. It can help you solve this problem with a few clicks, which can save you much time with fewer easy operations to be done. And you don’t need to worry about privacy invasion and data security thanks to its service policy.
Another method to unlock Samsung Note 8 is through Google’s Find My Device. This tool is ideal if your Google account is still active on the device and you can access another device to manage the process. Attention, unlocking Samsung Note 8 with Find My Device only supports Android phones running Android 7.1.1 or older. And if you cannot remember your Google credentials, this method is not suitable for you.
Step 1. Steps to Unlock Samsung Note 8 via Find My Device:
Step 2. Visit Google’s Find My Device website on a computer or another mobile device.
Find My Device Unlock Samsung Note 8
Step 3. Log in with the Google account associated with your locked Samsung Note 8.
Step 4. Select your Note 8 from the list of devices linked to your Google account.
Step 5. Choose ‘Erase Device’. This will reset your Note 8 and remove the lock screen.
Samsung’s Find My Mobile tool is similar to Google’s Find My Device but offers specific support for Samsung devices. If you have a Samsung account linked to your device, this is an excellent option for unlocking it. Likewise, this methods also require Samsung account credentials. If you don’t meet this condition, you can choose other methods provided in the article.
Step 1. Steps to Unlock Samsung Note 8 with Find My Mobile:
Step 2. Use a browser to visit the Find My Mobile website.
Find My Mobile
Step 3. Enter the credentials for the Samsung account registered on your Note 8.
Step 4. Choose your Note 8 from the list of devices linked to your account.
Step 5. Unlock your Note 8 directly.
Performing a Factory Reset on a Samsung Note 8 is a widely used solution for unlocking the device, especially when you don’t have any access to accounts linked to the device. This way is quite easy, but it will erase all your data and there is no way to recover the data. Except for that, if you have logged in Google account on the device and forgot the credentials, you will locked by a more challenging difficulty: How to bypass Google account verification after reset.
Here are steps to Unlock Samsung Note 8 with Factory Reset:
Step 1. Power off your Samsung Galaxy Note 8.
Step 2. Enter Recovery Mode by pressing and holding the Volume Up, Bixby, and Power buttons simultaneously.
Step 3. Use the volume buttons to highlight ‘Wipe Data/Factory Reset’ and press the Power button to select it.
Choose Wipe data/factory reset
Step 4. Choose ‘Yes’ to confirm, and wait for the process to complete.
If your Samsung Note 8 is locked by a third-party app rather than the built-in lock screen feature, Safe Mode is another trick that can work to unlock your Samsung Note 8, while the application range is limited.
Here is a guidance on how to unlock Samsung Note 8 in Safe Mode:
Step 1. Press and hold the Power button until the Power Off option appears.
Step 2. Press and hold ‘Power Off’ until the Safe Mode prompt appears.
Step 3. Tap ‘OK’ to boot into Safe Mode.
Boot into Safe Mode
Step 4. Uninstall the third-party app caused the lock in Safe Mode.
Step 5. Exit Safe Mode by restarting the device normally.
1. How to SIM Unlock the Samsung Galaxy Note 8?
To SIM unlock your Samsung Note 8, you may need to contact your carrier to request an unlock code. Or you can seek help from some SIM unlock software.
2. What is the General Code to Unlock Samsung?
There isn’t a universal unlock code for Samsung devices, as each carrier often has unique codes. However, the most common Samsung factory reset code is *2767*3855#, which will factory reset Samsung and unlock it in certain cases.
In this article, we mentioned 5 methods to unlock Samsung Note 8 without password, including DroidKit, Google Find My Device, Find My Mobile, Factory Reset Samsung, and unlock Note 8 in Safe Mode. Each way contains its own limitations. Among them, DroidKit stands out for its easy steps and high success rate. With its intuitive interface, it can help users remove the screen lock on Samsung Note 8 in minutes. Download it now!
