3 Ways to Unlock Moto G Pure Without Password
Unlocking your Moto G Pure without a password can be challenging, but it’s not impossible. In this comprehensive guide, we explore three effective methods to regain access to your device, even if you’ve forgotten your password.
Author Avatar Joy Taylor Last Updated: Jun. 19, 2024
The Moto G Pure is a popular smartphone known for its affordability, reliability, and impressive features. However, finding yourself locked out of your device can be a frustrating experience. Whether you’ve forgotten your password, PIN, or pattern, this guide will show you how to regain access to your Moto G Pure. We will explore three effective methods to unlock your Moto G Pure without a password and also provide a detailed guide on unlocking the SIM using your device’s IMEI.
Also Read: Motorola FRP Bypass Without Computer
Can I Unlock Moto G Pure Without Password?
Yes, it is possible to unlock your Moto G Pure without a password. Modern smartphones, including the Moto G Pure, come with various built-in recovery and reset options designed to help users regain access to their devices in case they forget their passwords. However, it’s important to note that these methods might result in data loss, so it’s recommended to back up your data regularly.
Moto G Pure Unlock Guide
Method 1: Unlock Moto G Pure Directly with DroidKit
Without a password or pattern, it’s difficult to unlock Moto G Pure directly. So an Android screen unlocker can be a better choice. DroidKit is a comprehensive Android toolkit that offers a user-friendly solution to unlock your Moto G Pure without a password. Here’s how you can do it:
Download and Install DroidKit: Visit the official DroidKit website and download the software on your computer. Install and launch the application.
Connect Your Moto G Pure: Use a USB cable to connect your Moto G Pure to the computer. Ensure that USB debugging is enabled on your device.
Select the Unlock Screen Feature: On the DroidKit interface, click on the “Unlock Screen” option.
Choose Screen Unlocker
Start the Unlock Process: Follow the on-screen instructions to begin the unlocking process. DroidKit will automatically detect your device and initiate the process.
Click Remove Now Button
Complete the Unlocking: Once the process is complete, your Moto G Pure will be unlocked, and you will have access to your device without needing a password.
Lock Screen Removal Completed
Method 2: Factory Reset Moto G Pure in Find My Device
Android Device Manager, also known as Find My Device, is a Google service that allows you to remotely locate, lock, and erase your device. This method will erase all data on your Moto G Pure, so it should be used as a last resort. Here are the steps:
Access Android Device Manager: On a computer or another device, go to the Android Device Manager website and sign in with the Google account linked to your Moto G Pure.
Select Your Device: From the list of devices, select your Moto G Pure.
Erase Your Device: Click on the “Erase Device” option. Confirm your choice and the process will begin.
Set Up Your Device Again: After the reset, your Moto G Pure will reboot. Follow the on-screen instructions to set up your device as if it were new.
Method 3: Wipe Moto G Pure in Recovery Mode
If you cannot use DroidKit or Android Device Manager, Recovery Mode is another effective way to unlock your Moto G Pure. This method also erases all data on your device.
  • Power Off Your Device: Ensure your Moto G Pure is completely turned off.
  • Enter Recovery Mode: Press and hold the Volume Down button and the Power button simultaneously until the Motorola logo appears. Use the Volume buttons to navigate to “Recovery Mode” and press the Power button to select it.
  • Wipe Data/Factory Reset: In Recovery Mode, use the Volume buttons to navigate to the “Wipe Data/Factory Reset” option and press the Power button to select it.
  • Confirm the Reset: Navigate to “Yes” and press the Power button to confirm. The device will start the reset process.
  • Reboot Your Device: Once the process is complete, select “Reboot System Now.” Your Moto G Pure will restart, and you will be able to set it up again without a password.
How to Unlock SIM on Moto G Pure
Unlocking the SIM on your Moto G Pure allows you to use it with any carrier. This can be done using the device’s IMEI number. Here’s a detailed guide on how to do it:
Find Your IMEI Number: Dial *#06# on your Moto G Pure to display the IMEI number. Alternatively, you can find it in the device settings under “About Phone.”
Contact Your Carrier: Reach out to your carrier’s customer service and request a SIM unlock. Provide them with your IMEI number. Depending on the carrier’s policy, they might provide you with an unlock code.
Enter the Unlock Code: Once you receive the unlock code, power off your Moto G Pure and insert the new SIM card from a different carrier. Power on the device.
Enter the Code: When prompted, enter the unlock code provided by your carrier. Your Moto G Pure should now be unlocked, allowing you to use it with any carrier.
Unlocking your Moto G Pure without a password is possible using several methods, including DroidKit, Android Device Manager, and Recovery Mode. Each method has its pros and cons, with DroidKit being the most user-friendly and least destructive. Additionally, unlocking your SIM using your device’s IMEI allows you to switch carriers easily. Regularly backing up your data can save you from potential data loss during these processes. By following this guide, you can regain access to your Moto G Pure and enjoy its full capabilities.
